| Simonbt |
 Simonbt Nitrous Nuisance
 Posted: 21:24 - 10 Mar 2005 Post subject: |
I bet you problem number two is due to an air leak at the rubber inlet manifold which will have mouldered in the sunlight and now either be cracked or so rigid it doesn't seal. Either replace it, heat it up and get the seal clamped down whilst it is still warm and pliable or use lots of silicone RTV (In decending order of bodge). ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| swampy |
 swampy World Chat Champion
 Posted: 21:29 - 10 Mar 2005 Post subject: |
And to answer number one, the choke is on with the lever pulled up  ____________________ "I hate to advocate drugs, alcohol, violence or insanity to anyone, but they've always worked for me." Hunter S Thompson
"Faster, faster, faster, until the thrill of speed overcomes the fear of death..." Hunter S Thompson |
| Simonbt |
 Posted: 22:26 - 10 Mar 2005 Post subject: |
I have seen a fault on the needle valve of some small jap bikes that can cause the float height to appear too high.
There is sometimes a tiny little sprung pin (maybe 3mm long) in the top of the needle valve which the floats bear against. Sometimes this gets stuck in (such as in a bike that has sat for a long time) and effectivley raises the float height by 3mm (ie a lot). If you don't know it is supposed to be there, you wouldn't notice. WD40 and working it back and forth soon frees them off.
You can see said item on the far left of the picture below.
https://www.parkeryamaha.com/ProductImages/pwc/threadedsm.jpg ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Simonbt |
The last post was made 21 years, 213 days ago. Instead of replying here, would creating a new thread be more useful? |
