MZ rebuild- the hard part is done
lingeringstin...
PostPosted: 11:05 - 03 Sep 2017    Post subject: MZ rebuild- the hard part is done Reply with quote
Well I hope it won't be any worse than it was with the MZ engine on it. Pretty much the only shit left that's MZ is most of the frame, the headlight and the tail light now. Been far more work than it's worth but once I got stuck in I couldn't stop because I just couldn't allow the thing to get the better of me. Been fighting with this POS like that ever since the day I bought it and it will no doubt continue to annoy me until rust and general deterioration finally gets one of us.
https://s26.postimg.org/5te3qn7m1/stinkybob.jpg
Waiting for a few more bits to arrive in the post but I can't forsee any real difficulties in getting it going soon.
stevo as b4
PostPosted: 14:34 - 03 Sep 2017    Post subject: Reply with quote
The engine seems to sit in there quite nicely, with room to spare. Also very much looks like theres space for twin carbs too! Smile
trevor saxe-coburg-gotha
PostPosted: 14:52 - 03 Sep 2017    Post subject: Reply with quote
dem wheels
pepperami
PostPosted: 14:55 - 03 Sep 2017    Post subject: Reply with quote
Mr Stnk, you are going into the top league of proper bikers when you get that back on the road Smile .
Ten out of ten!
I love the way it's made out many other bikes/parts.
UnspeedySam
PostPosted: 21:06 - 03 Sep 2017    Post subject: Reply with quote
Such an interesting project! Keep us up to date on it. Any idea what kind of horsepower the engine makes?
lingeringstin...
PostPosted: 22:08 - 03 Sep 2017    Post subject: Reply with quote
Unfortunately the engine probably won't be in there exactly like that. The rear motor mounts are modified MZ mounts and actually hinge where they connect to the swingarm gubbins and although they keep the engine from moving laterally I had to make a front down tube to suspend it all from and it's not quite finished.
There's a temporary brace from the head to the frame that will be a tad shorter when I make a real one and the whole engine will be rotated slighty rearward by an inch or two which is JUST enough to cause problems fitting carbs. It's the funny shape of the MZ frame behind the tank.
I tried a few different carb attempts and the only thing that actually fits without any insane routing or other trouble is the stock manifold from the quadbike that takes a single PZ30. I've already bought a new carb, which was quite cheap, so I'm going to use that initially to get up and running. I might start mucking about with other carbs later after I know it goes.
I've ended up using the quadbike two into one exhaust which will be piped through a couple of VW tailpipe baffles connected end to end in more or less a straight line from front to back, sort of high level style.
I was going to use Honda Rebel twin exhaust and even sourced a decent set but when they arrived they weighed a fucking ton and the header pipes turned out to be too long for my low bike and I'd have to cut about three inches out of each one for ground clearance. Then I'd have to weld them back together and they're double walled pipes so it could get ugly since I'm no master welder and it just all looked like too much work that had the potential to end badly so I just decided to go with the sawed off quadbike pipes and flog the Honda exhaust later.
The wiring is all done apart from the coil wires. I'm using a tractor ignition switch (with a real key and everything!) because of the electric start. I had to remove the MZ battery box so that's where I stuck all the electrical shit and the battery will live in a box on the side now.
Where the battery goes now:
https://s26.postimg.org/s6aekmtl5/CAM_1087.jpg
https://s26.postimg.org/5vmjknwax/CAM_1093.jpg
lingeringstin...
PostPosted: 22:18 - 03 Sep 2017    Post subject: Reply with quote
In standard trim they claim to make only about 18hp but I've seen scope for tuning when I was rebuilding it so I might start mucking about making another engine with strange modifications after I get it going first. 18hp isn't much but the bike weighs nothing, certainly very much less than a Honda Rebel, and the MZ engine was only about 20hp and it got me by for a long time. I'm used to it.
pepperami
PostPosted: 23:30 - 03 Sep 2017    Post subject: Reply with quote
Err am I missing something or are those rear shocks really skinny? Smile
lingeringstin...
PostPosted: 23:54 - 03 Sep 2017    Post subject: Reply with quote
Rear shocks? What's rear shocks? Is it some sort of newfangled motorbicycle accoutrement they put on modern rubbish? I'll have to go down to the library and peruse The 1933 Book Of Knowledge to see what that's all about.
PostPosted: 11:10 - 04 Sep 2017    Post subject: Reply with quote
They look like a significant upgrade from the last time I saw the bike. Pretty sure it used to have rusty box section in there.
lingeringstin...
PostPosted: 13:54 - 04 Sep 2017    Post subject: Reply with quote
Oh yes, I've gone all fancy pants on it now. Those are brand new turnbuckles so I can have some slight adjustment for height. Bottom end is a rod eye and the top end is the top of some MZ shocks stuck on with some threaded bar, all with lock nuts and washers even. Very posh.
pepperami
PostPosted: 16:09 - 04 Sep 2017    Post subject: Reply with quote
Why no shock absorbers?
Just interested.
lingeringstin...
PostPosted: 21:45 - 04 Sep 2017    Post subject: Reply with quote
Well you asked. It all started about 20-odd years ago when the bike was due for an MOT and the shocks were leaking. Somebody told me if you didn't have shocks they couldn't fail it so I cut up some dead straight handlebars and welded the old shock mounts to the ends of a length of straight handlebar section. I was just skint at the time and didn't want to have to pay out for shocks and this seemed like a cheeky way to get through the MOT.
Then once I started going around on the bike like that I grew to really like it and I just never went back to rear shocks. Over the years I learned what the perfect air pressure was for the tyres I was using to give me just enough squish over bumps but not feel all sloggy and slithery on the road. The problem with that was that once a year I had to pump my rear tyre up to 32PSI for the MOT and then let it back down again afterwards for road use.
I discovered that when riding on iced over roads it was actually a lot better because it was lower but it was also stiffer and therefore more manageable and I found my bike could go places normal bikes would struggle to go when the roads were packed ice. It was my winter courier hack of choice. It was low to the ground and much more useful on ice and snow.
Over the years people always said I was crazy and that it must hurt my back but it was actually a million times more comfortable than having MZ shocks. My seating position had me actually bent leaning forward slightly (straight handlebars, low seat) which meant my body just flexed over road bumps as opposed to being kicked right up the spine the way apehanger hardtails do you.
I actually found that distance journeys were far more comfortable than they were when I had shocks. I could go all day without ever stopping and I didn't feel knackered or have a sore back. It was great. Of course nobody believed me but I didn't care. I just never ever went back to shocks again. It also made my chains last longer and my tyres wear more evenly. And being low to the ground was a lot more stable in sketchy conditions. The only time I didn't like it was when I went green laning and parts of our route took in things like rough ploughed fields, stream crossings, deep muddy uphill ruts and paths strewn with chunky boulders but I could forgive that as it's not really what my bike was designed for. It did do me proud though.
I'm just used to it now. Every time I'm on a bike with shocks now it seems strange and I don't really feel like I'm in control as much. It does require getting to know what's the right tyre pressure to run for any given rear tyre but once you get it right it works great. The lower air pressure even means better grip on dodgy surfaces and will naturally low gear you if carrying a heavy load by the tyre squishing down more.
I think there's a lot to be said for properly set up hardtail bikes. Hardtail is great for all kinds of reasons, on and off the track, that people don't even think about anymore since virtually everything nowadays is automatically designed with suspension. I absolutely love this hardtail setup with the dead straight handlebars and forwardly bent posture. I've never had a more comfortable bike for long distances or all day courier work. But hardtail sat bolt upright over the rear wheel with ape hangers is just terrible in every way.
UnspeedySam
PostPosted: 21:25 - 05 Sep 2017    Post subject: Reply with quote
All hail Teffers mk2, ratbike edition!
edit: Actually read the post now. Laughing I think I'm hardtail curious now...also I kind of want to know how your contraption rides when it's back on the road.
lingeringstin...
PostPosted: 00:04 - 06 Sep 2017    Post subject: Reply with quote
Hardtail used to be the way it was done. Back in the day there were even hardtail trials bikes but once hardtails became fashion statements and copies of Easy Rider choppers it all went to hell. If you sit bolt upright with your legs akimbo and your arms reaching up for the apehangers then every road bump will pound your spine to death.
On my bike you actually lean forward to the straight handlebars with a slightly bent back and you flex with the road bumps instead of fight against them. I doubt you'll ever come across a hardtail without an idiotic seating posture nowadays. Mine is an improvement on the way it was, but that's usually not the case. Maybe some drag bikes are hardtail but most every other hardtail you'll ever see is pretty much just a fashion statement that rides worse than if it had shocks. They might be fun to look at but they're probably not great to ride.
The last post was made 9 years, 41 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.89 - MySQL Queries: 13 - Page Size: 91.1 Kb
