| redeem ouzzer |
 redeem ouzzer World Chat Champion
 Posted: 19:47 - 04 Sep 2017 Post subject: Battery Issue |
Hi A/all.
In my YR5 project bike https://www.bikechatforums.com/viewtopic.php?t=315359 i'm using a 1.2 ah battery to save space and weight.
https://i.imgur.com/H4w4uki.jpg
I did about 40 miles of thrashing tonight in order to get a feel for the engine after the dyno set up. Coming back home the bike cut out at the top of the street, having ran out of electricity. Multimeter showed 5v, not good. I put the battery on charge but it wasn't really willing to take much charge, however i got 12v into it and the bike showed signs of life. Got it fired up and it seems the charging system is fine (lights going bright, 13.9v across pos / neg which is the rated maximum of the regulator). Then all of a sudden it pigged again, battery flat must be under 7 volts to stop the CDI firing so it seems the voltage has bottomed out again.
I'm thinking knackered battery but i'm not sure exactly how it's gone from fine to this in the space of one ride
I get the recovery light on my optimate when i try to charge it. ____________________ Be a REAL MAN! |
| doggone |
 doggone World Chat Champion
| redeem ouzzer |
| Islander |
 Islander World Chat Champion
| Kawasaki Jimbo |
 Kawasaki Jimbo World Chat Champion
| jaffa90 |
 jaffa90 World Chat Champion
| Polarbear |
 Polarbear Super Spammer
 Posted: 23:39 - 04 Sep 2017 Post subject: |
I doubt that battery can handle the amount of power you are shoving through it in normal running. You are just killing it.
Read this..............
It is reasonable, though, to consider the maximum current a battery can safely deliver. That value will depend on all kinds of things, including the chemistry of the battery, but the maximum discharge rate is almost always tied to the capacity. That means that given a particular technology, a battery with double the capacity can deliver double the maximum current. Batteries are often specified with a discharge rate in terms of C, where C is the capacity of the battery divided by hours. For example, for a 2Ah battery, C is 2A. If the battery has a maximum discharge rate of 10C, the maximum current is 20 amps. It’s good to keep in mind that a 10C discharge rate means a battery life of less than 1/10th of an hour, and with the loss of capacity that a high discharge rate generally causes, the battery life would be less than five minutes. ____________________ Triumph Trophy Launch Edition |
| ThatDippyTwat |
 ThatDippyTwat World Chat Champion
 Posted: 01:03 - 05 Sep 2017 Post subject: |
Tiny battery, big (in relative terms) charge. You are on the way to doing this...
https://www.zbattery.com/Overcharging-SLA-Batteries
You need a bigger battery, or a way to dump a significant portion of your stator's output. A bigger battery is a metric fuckton easier, and cooler than a bank of power resistors, which is the simple way to create a dummy load and "suck up" some of that output. ____________________ '98 VFR800 (touring) - '12 VFR800 Crosrunner (Commuting) - '01 KDX220 (Big Green Antisocial Machine) |
| redeem ouzzer |
| ThatDippyTwat |
| Johnnythefox |
 Johnnythefox Traffic Copper
| Tankie |
 Tankie Crazy Courier
| redeem ouzzer |
| jjdugen |
 jjdugen World Chat Champion
| Johnnythefox |
| redeem ouzzer |
| jjdugen |
 Posted: 09:30 - 05 Sep 2017 Post subject: |
https://data.energizer.com/pdfs/nickelmetalhydride_appman.pdf
https://en.wikipedia.org/wiki/Nickel%E2%80%93metal_hydride_battery
I used these on a sixties Honda I had to re-engineer the (not) charging electrics. To get a bit Teff on you. Back then, there were no regulators, the rectifiers were plates of Selenium stacked up on top of each other. Because there was no regulation, the alternator output was designed to only peak at around max RPM, running around town at lower revs, with lights on, use of brake lights, soon began to flatten the battery. A modern reg/rec helped, but I had to re-wind the stator to give a higher output. Even so, the battery was tiny, Like you, space was very restricted. One use of the electric starter and the lead acid battery was severely drained.
I put in a bank of metal hydrides and cranking capacity was as good as a modern system.
The only mod that I incorporated was a thermal resistor clamped to the battery cells in the charging line from the reg/rec. As these batteries reach full charge, they heat up, the thermal resistor acting to reduce the incoming voltage supply. I did have to do some research, it was on a long defunct lap top so I'd have to start racking my brains again for full details.
Hope this helps.
Cheers. ____________________ The CBR900RR has been sold. Aprilia Falco worms its way into my heart.
Try Soi 23 on Amazon for a good read.... Self promotion? Moi? |
| ThatDippyTwat |
| jjdugen |
| lingeringstin... |
 lingeringstin... Spanner Monkey
| ThatDippyTwat |
| redeem ouzzer |
| jjdugen |
The last post was made 8 years, 109 days ago. Instead of replying here, would creating a new thread be more useful? |
