Oil grades
Wheezybiker
PostPosted: 14:43 - 05 Sep 2017    Post subject: Oil grades Reply with quote
Can you mix different grades of oil in a bike.
My manual says I should put 15/40 or 15/10 in I don't know what oil is in there already as I haven't changed it since I bought t
arry
PostPosted: 14:49 - 05 Sep 2017    Post subject: Reply with quote
Yes - and mixed oil is always better than low oil.
But the obvious answer is to just change it, so you know what's in there and how old it is. It's not big cash.
PostPosted: 14:51 - 05 Sep 2017    Post subject: Reply with quote
Pretty sure there is no such thing as 15/10.
Did you mean 15w/40 or 10w/40? Those would be common grades of oil.
I can think of no significant issues which would come about from mixing brands or grades of oil providing they are listed as appropriate for your bike.
I do try to top-up my sportsbike with the same oil I filled with but I'm not aware of anything that would react oddly between modern engine oils. I just throw whatever is lying around in the enfield.
The only real (as opposed to fabricated by manufacturers) issue I've ever been aware of on mixing oils is if you mix a vegetable based oil with a mineral based one. Veg based oils are uncommon and expensive and usually for very specific applications. If you were in a position to be using one, you would know about it.
Wheezybiker
PostPosted: 15:24 - 05 Sep 2017    Post subject: Reply with quote
Thanks for answers and yes finger trouble on iPad gave 15/10
Oil doesn't need changing yet / isn't low and I just thought of it whilst reading book and just wanted to check
Thanks again
PostPosted: 15:55 - 05 Sep 2017    Post subject: Re: Oil grades Reply with quote
Then it needs changed. It needed changed the moment you got it home.
Oh, the service book is stamped? Custom ink stamp, eBay, under a tenner.
Wheezybiker
PostPosted: 16:42 - 05 Sep 2017    Post subject: Reply with quote
Fair point roger if I had bought from an unknown
However bike was bought from family friend and I believe him when he said he had just had it changed backed up with paperwork
Triton Thrasher
PostPosted: 16:56 - 05 Sep 2017    Post subject: Reply with quote
They're the biggest liars of the lot.
Oil is thicker than blood.
Rrrrrrrrrrrrrrrrrr
PostPosted: 20:36 - 05 Sep 2017    Post subject: Reply with quote
He's probably diddling your missus as well.
Wheezybiker
PostPosted: 14:23 - 06 Sep 2017    Post subject: Reply with quote
A bit blunt but I see your point
ThatDippyTwat
PostPosted: 15:26 - 06 Sep 2017    Post subject: Reply with quote
For what it costs, it's cheap peace of mind. Always factor in oil/filter when buying a bike, it's exceedingly rare that you *know* how they have been treated.
The last post was made 8 years, 106 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.91 - MySQL Queries: 13 - Page Size: 64.26 Kb
