What connector is this?
sickpup
Old Timer
PostPosted: 09:07 - 07 Sep 2017    Post subject: What connector is this? Reply with quote
This one.
https://www.bikechatforums.com/download.php?id=100240
Pjay
PostPosted: 09:18 - 07 Sep 2017    Post subject: Reply with quote
Size?
110v construction site electrical equipment has similar but that looks smaller and its not usually threaded. Could be for PA use.
struan80 - I'll go first - satisfied tick 1
Suntan Sid
PostPosted: 09:22 - 07 Sep 2017    Post subject: Reply with quote
LED strip lighting connector.
https://www.aliexpress.com/store/product/50-pair-lot-5-Pin-Male-To-Female-Waterproof-Connector-Cable-Cord-5-x-0/206780_32260648903.html
Pjay
PostPosted: 09:26 - 07 Sep 2017    Post subject: Reply with quote
Suntan Sid wrote:
The key is different, but close fo sho.
It's for outdoor use for sure though.
RhynoCZ
PostPosted: 09:34 - 07 Sep 2017    Post subject: Reply with quote
Could this fit in? Used for the welder torch.
https://cdn.eastwood.com/media/catalog/product/cache/1/image/9df78eab33525d08d6e5fb8d27136e95/p/2/p21258_2.jpg
sickpup
Old Timer
PostPosted: 09:35 - 07 Sep 2017    Post subject: Reply with quote
The key is different as are the pin positions so no, not close.
Pjay
PostPosted: 09:37 - 07 Sep 2017    Post subject: Reply with quote
Good point Smile
Looks a bit like an SP17. I don't think the centre is the same shape though.
Pjay
PostPosted: 09:39 - 07 Sep 2017    Post subject: Reply with quote
Might be a CCTV connector.
It's basically a weather proof outdoor connector, so without knowing what it was used for, the searching for it would be hard as there are bundles of those types of connectors.
sickpup
Old Timer
PostPosted: 09:43 - 07 Sep 2017    Post subject: Reply with quote
I know whats its for but that isn't really relevant to what it is.
The only thing I have seen it used on is heated clothing so low voltage and upto 20amp or so at 12v.
I have seen 3 pin versions used on LED lighting but nothing that lists the connector type.
RhynoCZ
PostPosted: 09:48 - 07 Sep 2017    Post subject: Reply with quote
It also seems like a DMX connector, but the pin layout is different to what I could find.
https://www.acclaimlighting.com/uploads/pics/5pin_xlr_01.jpg
Half a story though. If you want something that does a similar job, an SP13/17 should do nicely. They come as flying plugs/sockets and with bulkhead mounts. I use one to attach the lighting for the trailer on my Bullet. Bulkhead mount socket in the taillight assembly and flying lead on the trailer.
https://i48.photobucket.com/albums/f216/stinkwheel/Trailer/DSCN0154.jpg
https://i48.photobucket.com/albums/f216/stinkwheel/Trailer/DSCN0128.jpg
If you want the socket to plug that into or an identical one, then an application would be helpful.
Robby
Dirty Old Man
PostPosted: 18:20 - 07 Sep 2017    Post subject: Reply with quote
Ask BillyJ. He knows connectors.
The last post was made 8 years, 134 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.14 - MySQL Queries: 13 - Page Size: 77.76 Kb
