Restriction?
bobby193
PostPosted: 21:39 - 10 Mar 2005    Post subject: Restriction? Reply with quote
Hello is there any problem running a restricted bike too fast ie will it do any damage or will the restricter just cut the performance?
I don't particulary want to take the restricter out just yet.
Toady
PostPosted: 23:01 - 10 Mar 2005    Post subject: Reply with quote
Won't do it any damage it just restricts the power.............
You worry too much! Smile Although I have heard that if you twist the throttle too quickly it can come off in your hand and the brakes fail as a result of this..................... Laughing
I can see paradise by the dashboard lights....................or at least the speedo on my NSR!
mchaggis
PostPosted: 11:03 - 11 Mar 2005    Post subject: Re: Restriction? Reply with quote
You can't really run a bike too fast persay, it will go as fast as the restriction will allow it, ie about 100mph. The restrictor is generally a circular piece of metal with a hole cut in it, placed between the carburettor and the engine. The hole is a specific size to only allow up to a specific air/ fuel flow to the engine so that the engine can never develop as much power as it might be able to. This is an effect very similar to just not using the full range of the throttle.
There are problems with running any engine at high speeds for a long time, no matter what its state of tune of course. Run an engine at the redline long enough and it will drop/ bend a valve, start knocking, overheat, sieze, break piston rings etc etc.
One thing the normal restrictor won't do is cut the power at a specific point. It is restricting air/fuel flow right across the rev range.
There are bikes from specific markets which do cut the power using the CDI and/ or fuel injection, either by retarding the ignition or by cutting the fuel injection. Japan and Germany are two such countries I believe.
I must not be a troll...
Mmmm, Guinness
The last post was made 21 years, 234 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.83 - MySQL Queries: 13 - Page Size: 36.73 Kb
