Changing engine capacity with DVLA?
PostPosted: 12:14 - 18 Sep 2017    Post subject: Changing engine capacity with DVLA? Reply with quote
Anyone done this recently (say within the last 12 to 18 months)?
How did you get on? I'm considering actually telling the truth about my project bike when it's built and it will be going from 500cc to 612cc. Mainly because there will be a fair amount of money in it so actually getting proper insurance for an agreed value with the modifications listed might be a good idea. (I normally only keep bikes I can afford to lose).
I'll probably register the engine swap first (easy enough, just needs a letter from a garage) then the capacity change. That could be the tricky one. I'll have a receipt for the longstroke crank and oversize piston and barrel but it's not certain if that'll compute with the capita typing monkeys.
What I don't want is to get lumbered with an inspection and Q-plate/MSVA.
Wonko The Sane
PostPosted: 12:22 - 18 Sep 2017    Post subject: Reply with quote
would it not be simpler to be saying to the DVLA
Swapped engine, new engine is number XXXXXXX XXXXXX with 612cc capacity, thanks
PostPosted: 12:31 - 18 Sep 2017    Post subject: Reply with quote
They will want evidence of the engine swap. The engine will have been previously registered as 500cc.
Maybe I'm just being paranoid that they'll make life difficult and should just suck it and see? They always used to be happy enough to increase capacity but got shirty if you tried to lower it (presumably in case they were being diddled out of road tax).
I was thinking the engine swap itself would be more straightforward if it didn't also include a change in capacity. If it's going to be too tricky, I am fully prepared to be economical with the truth about the capacity because the only way you'd know is to physically measure the bore and stroke. Externally it looks like a normal 500 alloy barrel.
PostPosted: 12:37 - 18 Sep 2017    Post subject: Reply with quote
If you searched from now until the End Days, do you imagine you'd ever find anyone who you could persuade to measure the capacity, let alone someone who would proactively insist on it?
ThoughtContro...
PostPosted: 13:04 - 18 Sep 2017    Post subject: Reply with quote
If I was contemplating doing such a thing as Mr Borg implies then I'd first make sure all my last posts on the matter on a public forum stated that obviously to avoid the hassle from the DVLA I did the legal thing of fitting a piston/cylinder of the capacity stated on the V5, as a safeguard, just in case.
This forum is perused by both coppers and cnuts, and being a mod you never know what enemies you may have made that just love the green, green, grass of home when it suits them.
If such a matter were ever to come up don't give them written statements to help their enquiries. Your future insurers wouldn't be impressed either, apart from the increased excess and premium loadings they'll be applying.
This is no different than advice that Teffers would give some pedboy about his big bore kit, albeit less wordy.
Prize cunt
PostPosted: 15:42 - 18 Sep 2017    Post subject: Reply with quote
I could of course go down the route of writing my own engineers report, just like I did with Mrs stinkwheels restrictor kit certificate.
EDIT: Of course, I don't have a problem with it being registered as the correct cc. I'm old enough to insure a modified bike these days. My main concern is them not believing me and insisting on me jumping through hoops to register it.
I'll probably give it one go and make sure I generate a watertight chain of evidence to prove I made the attempt.
stevo as b4
PostPosted: 18:35 - 18 Sep 2017    Post subject: Reply with quote
Be interested to see how you get on with the process tbh.
On my KMX 125 I will at some point be fitting a 200cc engine when I'm bored of messing with the 125. It'll have a different engine number, so hopefully should be easy to change on the log book etc.
If I was simply fitting a 200cc top end, then I'd have to think about it before squawking as I imagine it's much like your Enfield where externally the engine won't look any different?
Keeping the same engine number, and with no visible embossed capacity markings on the cylinder block, it'd always be tempting to never mention it. There's always the old (you bought a 500cc bike, and some naughty PO converted to 612, and you were none the wiser).
Wonko The Sane
PostPosted: 20:57 - 18 Sep 2017    Post subject: Reply with quote
ah, I hadn't fully understood that the new engine you're looking at building is, in standard trim, 500cc but you're looking at altering it during the build process to be a larger capacity.
speak to them to register the engine swap and ask, how you would you go about altering the capacity as, once the engine is bedded in you're looking to do so.
if they say it's just a case of saying it's larger then you can do so once the work is done,
If they need a report then you know you need to get one when the work is done.
Shaft
PostPosted: 23:13 - 18 Sep 2017    Post subject: Reply with quote
Personally, I wouldn't bother with the capacity change, if it's visually identical to the 500, who is ever going to know?
I have an invoice detailing the top end rebuild on my XL600R, showing a rebore and a Wiseco piston kit - I know Wiseco make oversize pistons and proper big bore kits, but I have no idea what's in mine and I'm not about to tear it down and find out.
I'm guessing you aren't planning on selling this bike when it's finished, so it's not really relevant to anybody but you.
I can't imagine the circumstances where you might have an accident that would require an engine strip, enabling the insurance company to wriggle out of paying for your damage (unless you were doing 130 mph at the time, when it becomes moot anyway) so my view would be declaring it to DVLA is just causing yourself the potential of unnecessary grief.
The last post was made 8 years, 289 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.29 Sec - Server Load: 1.54 - MySQL Queries: 13 - Page Size: 65.11 Kb
