Buying an older CBR600 or ZX9r
mudcow007
PostPosted: 09:37 - 22 Sep 2017    Post subject: Buying an older CBR600 or ZX9r Reply with quote
A mate of mine is itching to buy a new bike, has £1200 from the sale of his Bandit an is desperate for something faster.
He has seen a (2002) CBR600 but i aint got a clue about them.
There is also a ZX9r (1999) that's local but again i havent a clue about them...?
anything to watch out for etc?
ta
DrDonnyBrago
PostPosted: 11:39 - 22 Sep 2017    Post subject: Reply with quote
I've had a 2001 CBR6f for 8 years.
It's a good bike, it's also from Honda at a time when that meant exceptional build quality. Mine is "well used" and still tidies up nicely.
things to look out for are the presence of a mild steel exhaust system, although by now I imagine most will have been changed. They are really particular about the design of aftermarket downpipes and will run like dogshit on the cheaper brands - you'll spot a dead spot at about 5k rpm if it isn't running great. Motads run spot on.
I've needed a new VSS (speedo on my bike stopped working) and they get through CCTs every 16k or so. Rattling around 5k suggests a new CCT is on the cards. If the clutch is rattly, don't let it put you off, the baskets get notched and they all do it - doesn't make a difference to the bike. The bike itself has been solid requiring only the bits listed and consumables. You'll read about reg/recs burning up but mine is on the original still with no issues.
The front forks are a bit undersprung unless you are a featherweight.
They were a common first bike, so check for crash damage and tacky mods.
arry
PostPosted: 11:44 - 22 Sep 2017    Post subject: Reply with quote
As above, the CBR is pretty solid. Enjoyed mine - especially when you get an opportunity to ping it up over 10k RPM where it becomes a whole lot more alive.
As with any old bike, it'll have old suspension unless something's been done about it. Rears seem to go soggy and a rebuild / replacement makes quite a lot of difference.
My only other issue was a bit of rough running when it got warm, which was fixed with a bit of carb balancing.
CaNsA
PostPosted: 12:12 - 22 Sep 2017    Post subject: Re: Buying an older CBR600 or ZX9r Reply with quote
I think, but not sure, if thats the model that eats it's own gearbox.
P.
PostPosted: 12:39 - 22 Sep 2017    Post subject: Reply with quote
Yah, C model 98 onwards, eat dat box.
CaNsA
PostPosted: 12:44 - 22 Sep 2017    Post subject: Reply with quote
There is a thread on here somewhere about a z1000 box getting put in a zx9r.
mudcow007
PostPosted: 13:00 - 22 Sep 2017    Post subject: Reply with quote
thanks boyo's
ZX is the "C" model, an weirdly has no fairings so guessing its been crashed an repaired, nothing has come up on a hpi etc.
updates to follow...
johnsmith222
PostPosted: 14:05 - 22 Sep 2017    Post subject: Reply with quote
mudcow007 wrote:
thanks boyo's
ABORT!
If it has to be between those bikes, get the CBR600F if it's been uncrashed.
Either that, or if he wants a 9R, go for an E model onwards (or a B model if wanting something heavier and more interesting).
If I was considering a 9R though, I'm not sure I'd also be considering the CBR600F, as they're a good bit different.
I'd get him to consider budget £1800 if he can. It will be worth it in the end to get something not-crashed/shit. There are good bikes for £1200, but defo more options for more.
https://www.ebay.co.uk/itm/Kawasaki-ZX9R-E1-2000-26K-miles-/232494268950?hash=item3621bd0216:g:-roAAOSwSZFZwYzP
Something like this looks nice.
mudcow007
PostPosted: 15:06 - 22 Sep 2017    Post subject: Reply with quote
Just had a message, he is going to look at a 1200 Bandit from work.....
Musketeer
PostPosted: 15:13 - 22 Sep 2017    Post subject: Reply with quote
ZX6R J1/J2 would be a decent bike for the money. I had no issues with mine except front calipers needed attention. I replaced mine with Nissin calipers.
J1/J2 is not slow.. faster than old CBR600 surely.
The last post was made 8 years, 135 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.99 - MySQL Queries: 13 - Page Size: 64.28 Kb
