Bad Knocking noise
JoshLix
PostPosted: 18:00 - 11 Oct 2017    Post subject: Bad Knocking noise Reply with quote
New noise. I really hope its not a rod. before it started I adjusted my cam chain, It was making some noise so i tightened it til the noise went away. then rode probably 80 miles and this new noise came up. other symptoms was at idle if i reved it up quickly then snapped the throttle back down it would die. I will attach a video of the noise. Any Ideas?
Just had the carbs serviced, rebuilt and synced by a shop.
Did a oil change myself.
adjusted the cam chain myself.
Bike is a Suzuki GSF600S bandit (miles 16K)
PostPosted: 19:21 - 11 Oct 2017    Post subject: Reply with quote
Why adjust the cam chain. It's self adjusting. Assume you mean drive chain...
However just sounds noisy. Any leaks at the actual header pipes, most tapping would come from that area having a slight leak.
JoshLix
PostPosted: 19:30 - 11 Oct 2017    Post subject: Reply with quote
Here are a few things I forgot to say. I just did the cam chain because it was making a rattling noise from it that the mechanic mentioned and I heard. My cam chain adjuster is not stock it doesn't self tighten. I also forgot that the mileage showing is not correct. Also I just got this bike alot of mystery.
PostPosted: 19:32 - 11 Oct 2017    Post subject: Reply with quote
So you took the cover off, measured it and adjusted....
Yeah, get the stock tensioner and leave it.
JoshLix
PostPosted: 19:33 - 11 Oct 2017    Post subject: Reply with quote
I checked all the bolts are tight. Any other way to check headers?
JoshLix
PostPosted: 01:07 - 13 Oct 2017    Post subject: Reply with quote
so I Checked all the valves and changed the clearances. I also checked the cam chain when I was in there it seemed ok and not to tight or anything. so i am starting to think exhaust. how can you tell if the gasket is bad?
PostPosted: 08:31 - 13 Oct 2017    Post subject: Reply with quote
You need new gaskets now you've removed the headers.
mudcow007
PostPosted: 10:04 - 13 Oct 2017    Post subject: Reply with quote
that's the cleanest Bandit i have ever seen Wub
if you have removed the rocker (to do the valves) did you "instant gasket" in the half moon cut outs?
if you didn't....expect oil misting like a bastard
JoshLix
PostPosted: 16:29 - 13 Oct 2017    Post subject: Reply with quote
Yes I put some gasket sealer around the half moons. I didn't check the cam chain timing because didn't know how.
Just for taking headers off instant new gasket??
mudcow007
PostPosted: 16:36 - 13 Oct 2017    Post subject: Reply with quote
You need these
JoshLix
PostPosted: 17:09 - 13 Oct 2017    Post subject: Reply with quote
mudcow007 wrote:
You need these
Sounds good ill give em a shot. It will be a few days for postage but ill let you know what happens.
ZaphodBeeble
PostPosted: 19:19 - 25 Oct 2017    Post subject: Reply with quote
When you adjusted the clearances, did you make sure each set of valves were adjusted when the corresponding cylinder was at TDC on the compression stroke?
Current bike: VTR1000F Firestorm. Previous: Firestorm (written off) - XJ600 Divvy - NSR125 - DT125 and a load of offroaders.
sickpup
Old Timer
PostPosted: 22:47 - 25 Oct 2017    Post subject: Reply with quote
Sounds like you may have overtightened the tensioner and taken out a main journal.
JoshLix
PostPosted: 16:27 - 26 Oct 2017    Post subject: Reply with quote
Still waiting for gaskets. Should be here any day. I will keep you all updated.
JoshLix
PostPosted: 18:01 - 28 Oct 2017    Post subject: Reply with quote
https://www.youtube.com/watch?v=wJC7Xrf4pnM
I attached a link to a you tube video of noise and how it sounds now. still there sounds a little better after changing exhaust gaskets.
JoshLix
PostPosted: 18:13 - 28 Oct 2017    Post subject: Reply with quote
I believe so. I followed a YouTube video Ill attach the link and you can see if this is correct or not.
https://www.youtube.com/watch?v=IVUDflAT0u4&list=PLKNKH2RHGPi0Ce93i7Prap8mjm5FZZ_i-&index=10&t=155s
The last post was made 8 years, 333 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.91 - MySQL Queries: 13 - Page Size: 93.05 Kb
