cbr 600 1989 jellymould charging problem
King29
PostPosted: 15:27 - 18 Oct 2017    Post subject: cbr 600 1989 jellymould charging problem Reply with quote
Hi all.
I have a cbr 600 1989, the problem is with charging. My heated oxford grips went cold and the battery died last week. I bought a new battery and it has lasted a day or two but now wont start the bike. I did not connect the grips back up in case there was an issue with them staying on or causing some kind of drain. If I rev the bike the headlight gets brighter so am not sure what the issue could be. I have a multi meter and with the lights on it gives 14.2 at 5000 rpm.
I can ill afford mobile mechanics rates and my local garage wants £35 per hour to have a look. Any suggestions would be most welcome.
jaffa90
PostPosted: 16:37 - 18 Oct 2017    Post subject: Reply with quote
Check if you have a battery drain on the earth side when all is switched off.
King29
PostPosted: 16:47 - 18 Oct 2017    Post subject: Reply with quote
Ok, will give that a go tomorrow. Bike is under covers on side of house and going nowhere, so I'll see tomorrow. Thank you.
jaffa90
PostPosted: 16:51 - 18 Oct 2017    Post subject: Reply with quote
Not good at explaining things (it`s an age thing) so try,
https://www.google.co.uk/search?q=checking+battery+drain+with+ammeter+on+motorcycles&oq=checking+battery+drain+with+ammeter+on+motorcycle&gs_l=psy-ab.1.0.33i160k1.9662.16204.0.18190.14.14.0.0.0.0.136.1408.9j5.14.0....0...1.1.64.psy-ab..0.12.1201...0i22i30k1j33i21k1.0.piG8ZsjpjfM
King29
PostPosted: 16:59 - 18 Oct 2017    Post subject: Reply with quote
Thank you, that was very helpful. I am hoping it's an easy fix, will work through the online tutorials and see what's what. Thank you again jaffa90.
King29
PostPosted: 21:28 - 21 Oct 2017    Post subject: Reply with quote
Fixed, it was the alarm that was playing up. Even though I had deactivated it via fob it still sucked enough power to flatten the battery.
The last post was made 9 years ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.26 - MySQL Queries: 13 - Page Size: 45.87 Kb
