Bandit 1200 - Rattling Disc
mudcow007
PostPosted: 10:13 - 19 Oct 2017    Post subject: Bandit 1200 - Rattling Disc Reply with quote
A mate of mine has just bought a 1200 Bandit, on a ride at the weekend we noticed that one of the front discs was rattling Shocked
All of the rivets (the parts that hold the outta braking surface to the inner gold disc) will turn quite freely....I've told him this is bad an he's gonna get a replacement at the weekend.
what causes this though, I've never seen it before
Hawkeye1250FA
PostPosted: 10:20 - 19 Oct 2017    Post subject: Re: Bandit 1200 - Rattling Disc Reply with quote
edit: I have one too, big suzuki rust machine. Lovely fun but expensive to maintain to a decent level. And very rattley.
1993 RF400R - 2002 Bandit 1200 - 2012 1250 FA
MCN
PostPosted: 10:34 - 19 Oct 2017    Post subject: Reply with quote
Do you not mean it is a Floating Disc?
The disc 'floats' on the rivets to allow for miss-alignment then the pads can grab it better.
This is not a fault.
https://en.wikipedia.org/wiki/Disc_brake
mudcow007
PostPosted: 11:20 - 19 Oct 2017    Post subject: Reply with quote
Oh, the LHS disc doesn't move, but the RHS does.
Could it just be the LHS are stuck?
On my 600 the brakes didnt move etc.
Just found a pootube clip thats shows exactly what its like
https://www.youtube.com/watch?time_continue=9&v=f8gy1-ECESQ
Islander
PostPosted: 11:58 - 19 Oct 2017    Post subject: Reply with quote
There are floating discs and fully floating discs. The former have a spring washer under the rivet that prevents the disc from moving laterally unless some effort is applied. The latter have no spring washers and can move quite freely - I have these on the front of my M900.
It's possible that the LHS disc has become stuck on the rivets in which case, brake cleaner and a bit of elbow grease with a brush will free it. Or it may be that the caliper on that side isn't as free as it should be...
Tokico 6 pots, just saying like. Laughing
ETA: That Youtube video shows a fully floating disc. Perfectly normal. My M900 sounds like a skeleton tap dancing in a biscuit tin when you wheel it around. Laughing
PostPosted: 12:07 - 19 Oct 2017    Post subject: Reply with quote
I good way of freeing them up is to put a bolt through the rivet with a washer either side then put a nut on it and tighten it up. Once tight it will turn the rivet freeing it.
Matt B
PostPosted: 14:41 - 19 Oct 2017    Post subject: Reply with quote
You sure it's actually the disc rattling, and not the pads moving around in the calipers?
redeem ouzzer
PostPosted: 10:33 - 20 Oct 2017    Post subject: Reply with quote
Can you rotate the disc on the carrier more than a couple of mm? If so it's fucked and needs changing. Suzuki discs are prone to this. I once sweated some solder into a couple of the rivets on a bike I was selling that needed an MOT but I wouldn't recommend it on a bike I was riding.
Be a REAL MAN!
The last post was made 9 years, 7 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.82 - MySQL Queries: 13 - Page Size: 56.65 Kb
