Weird Rubber
Commuter_Tim
PostPosted: 23:36 - 19 Oct 2017    Post subject: Weird Rubber Reply with quote
Could anybody tell me if this pattern on my tyre is normal, and if not, what may have caused it?
The middle strip around the entire tyre is raised by maybe 0.5-1mm, leaving those ridges mirrored either side of the raised strip.
https://cdn.bcf.44bytes.net/files/tyre_889.jpg
I've had squared off tyres before and this seems like the opposite of that.
The tyre is a BT45 and maybe 3 months/1000 miles old.
The PSI is set to Haynes spec and hasn't lost even 1 PSI since the tyres were fitted.
I know a lot of tyres have harder rubber compounds along the middle for us straight line heroes, but I've never seen it before. Thinking
I ride a Bandit 600... badly.
PostPosted: 23:40 - 19 Oct 2017    Post subject: Reply with quote
It's called 'antenna tread' and quite normal.
MCN
PostPosted: 00:04 - 20 Oct 2017    Post subject: Reply with quote
You can see the dual compound if you clean the Shite off the surface.
It is quite distinct.
Chris45
PostPosted: 15:58 - 20 Oct 2017    Post subject: Reply with quote
So what is antenna tread??? I have a BT45 on the rear and can't find any evidence of such. Ta.
Honda CG125>Suzuki GT185>Honda CB 250N>Suzuki GSX400>Honda CX500B>Kawasaki GPZ305> Kawasaki GPZ550>Kawasaki GPZ500S+BMW 650GS
natefz6
PostPosted: 16:26 - 20 Oct 2017    Post subject: Reply with quote
Part of the tyre without silica in it so it grounds through the tyre and not though your foot when you get off stopping electric shocks. Or so I read from a link on google.
"no I didn't steal it that's just the way I ride"
Commuter_Tim
PostPosted: 23:15 - 27 Oct 2017    Post subject: Reply with quote
Cheers all, I guess as long as it is MOTable and doesn't harm handling it shouldn't be a concern then. Thumbs Up
The last post was made 8 years, 336 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.63 - MySQL Queries: 13 - Page Size: 48.72 Kb
