how to undo battery thats been fitted wrong?
andyscooter
PostPosted: 09:10 - 21 Oct 2017    Post subject: how to undo battery thats been fitted wrong? Reply with quote
basically my battery has been bodged on with a nut rather then the small threaded square block
turning the bolt ion the top doesn't work as the nut under spins as well but there isn't any room to get a spanner on it
tried wedging a screw driver in it but the bolt has fused to the nut with corrosion over the years
https://i.imgur.com/pXco0f2.png
paint pic to help understand
so how can I get this bolt off
Suntan Sid
PostPosted: 09:28 - 21 Oct 2017    Post subject: Reply with quote
If the bolt is one of lead type things you may be able to cut the top of the bolt off with a pair of these:-
https://www.stanleyimages.co.uk/CatalogImages//1388_prev.jpg
Nobby the Bastard
Harley Gaydar
Stick a flat bladed screwdriver between the nut and the terminal wall to hold it still.
Triumph Sprint ST 1050
PostPosted: 10:03 - 21 Oct 2017    Post subject: Reply with quote
My time to be a bastard.
Did you even read the first post, faggot etc.
My advice, crowbar. Use it to rip the terminals off. Cut bolt at leisure and buy new battery.
jaffa90
PostPosted: 10:22 - 21 Oct 2017    Post subject: Reply with quote
Why not disconnect the other end of the lead (carefully without shorting) and remove the battery with the lead and then junior hacksaw the bolt head off. Or drill it as Sol says.
MCN
PostPosted: 10:28 - 21 Oct 2017    Post subject: Reply with quote
/\ You couple of pairs of tossers. /\
You need a Thermite Hammer to get that off now.
Or you could try a scoot of a thread lubricant/penetrating stuff (WD40 is not the best BTW) and (with you flat blade screwdriver wedged in the side of the nut/two screwdrivers one on each side) then try to tighten the bolt into the nut again.
More lubricant and slacken the bolt again.
That will help work the lubricant into the thread and small turns will hopefully break off any corrosion.
solemnwarning
PostPosted: 10:29 - 21 Oct 2017    Post subject: Reply with quote
If its seized, just drill the head of the bolt off.
Nobby the Bastard
Harley Gaydar
PostPosted: 10:49 - 21 Oct 2017    Post subject: Reply with quote
Bigger screwdriver.
Or you could just undo the other end of the lead.
c_dug
PostPosted: 10:53 - 21 Oct 2017    Post subject: Reply with quote
For the sake of a centimeter of cable I'd just cut it off and crimp a new terminal on, assuming it is actually that difficult to remove.
Edit: just to clarify, I mean snip the lead flush with the end of the current ring terminal. Though I do have an abundance of crimps which admittedly you may not.
PostPosted: 11:40 - 21 Oct 2017    Post subject: Reply with quote
You’ll be needing the use of car and fencing wire.
Attach wire to terminal (a couple twists around the post should do).
The other end around the rear towing eye on the car.
Next bit is vital; somebody must sit on the bike with the brakes on.
Also important for car driver to keep a consistent force on the wire ( this is achieved by monitoring the rev counter closely and not getting distracted by checking the mirrors).
Your worries about that stuck nut are but a few minutes away.
Islander
PostPosted: 12:30 - 21 Oct 2017    Post subject: Reply with quote
Give it a soak with some plus gas or similar then wedge two screwdrivers into the terminal, one each side of the nut. Make sure that they're hard against the flats of the nut and then try to undo it.
Nobby the Bastard
Harley Gaydar
PostPosted: 13:24 - 21 Oct 2017    Post subject: Reply with quote
Four screwdrivers, one either side of the nut and the other two in orifices of your choice.
andyscooter
PostPosted: 13:56 - 21 Oct 2017    Post subject: Reply with quote
battery is fairly new so don't want to damage it
wanted to get it undone to fit the compressor cable I have to it
may try plus gas and a bigger screw driver in a bit
haroman666
PostPosted: 13:58 - 21 Oct 2017    Post subject: Reply with quote
Angle-grind the top of the bolt off?
andyscooter
PostPosted: 14:00 - 21 Oct 2017    Post subject: Reply with quote
struggle to get enough space to get a socket and a screw driver in let alone an angle grinder Laughing
haroman666
PostPosted: 14:27 - 21 Oct 2017    Post subject: Reply with quote
Dremel? Laughing
andyscooter
PostPosted: 14:36 - 21 Oct 2017    Post subject: Reply with quote
haroman666 wrote:
Dremel? Laughing
that might work Shocked
hope mrs hurries home so I can get out there
Islander
PostPosted: 14:54 - 21 Oct 2017    Post subject: Reply with quote
Underpants on the head?
Wibble?
Nobby the Bastard
Harley Gaydar
PostPosted: 14:57 - 21 Oct 2017    Post subject: Reply with quote
Wibble?
Jeweller's up the japper and the bigest available handle first as a butt plug.
Speedy2007
PostPosted: 16:20 - 21 Oct 2017    Post subject: Reply with quote
Have you tried a buzz saw?
Nobby the Bastard
Harley Gaydar
PostPosted: 16:28 - 21 Oct 2017    Post subject: Reply with quote
In place of which screwdriver?
Chris45
PostPosted: 18:31 - 21 Oct 2017    Post subject: Reply with quote
Reckon the first priority is to get the battery out and on the workbench first, even if that means disconnecting the other end of the lead. At least you can work on it better.
As others have suggested, use either a couple of flat bladed screwdrivers to jam the nut, or fabricate a piece of metal to wedge in between.
Honda CG125>Suzuki GT185>Honda CB 250N>Suzuki GSX400>Honda CX500B>Kawasaki GPZ305> Kawasaki GPZ550>Kawasaki GPZ500S+BMW 650GS
andyscooter
PostPosted: 19:08 - 21 Oct 2017    Post subject: Reply with quote
Got it off
Cut side out of terminal and got spanner onto the nut
Terminal still solid enough to use and connected the charger/compressor cable
PostPosted: 19:14 - 21 Oct 2017    Post subject: Reply with quote
I've used a flat bladed screwdriver to jamb the nut and remove the bolt. It's never failed me yet, all you have to do is make sure you stick it into the closing gap as the nut turns, not the opening gap.
MCN
PostPosted: 19:28 - 21 Oct 2017    Post subject: Reply with quote
Do you stil have the screwdriver handle up your Jack C.?
The last post was made 8 years, 360 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.06 - MySQL Queries: 13 - Page Size: 127.16 Kb
