Charging system only works when i turn on headlight
Dae2830
PostPosted: 17:49 - 22 Oct 2017    Post subject: Charging system only works when i turn on headlight Reply with quote
Hi all.
First post...hoping you can get me out of a pickle here as its something probably sooooo simple but i cant find the answer anywhere.
I have a 1998 Yamaha neos yn50. It was a non runner to begin with but now its working. I have changed the stator (single phase, only 2 wires in the plug and 2 bullet connectors), new battery and R/R.
The problem i have is the charging system only works when the headlights are turned on manully with the switch.
The lights get brighter as i increase the revs as well...which i believe is normal. Could my stator be a dodgy one or am i over looking something really easy?
Thank you in advance
Nobby the Bastard
Harley Gaydar
PostPosted: 17:58 - 22 Oct 2017    Post subject: Reply with quote
Some smaller bikes have two separate charging coils. one that works all the time and one that works only when the lights are on.
Triumph Sprint ST 1050
Dae2830
PostPosted: 18:28 - 22 Oct 2017    Post subject: Reply with quote
Thank you for quick reply...
Its the charging all the time without the lights on im having trouble with, if mine has the 2 charging modes. I have checked all wiring...connections and light switch.
Could i be looking at a faulty new stator?
Or is it just the way the bike is?
Dae2830
PostPosted: 18:43 - 22 Oct 2017    Post subject: Reply with quote
Thanks mate will have a look at ignition wires etc...failing that it will make a good anchor
Dae2830
PostPosted: 19:53 - 25 Oct 2017    Post subject: Reply with quote
Hi all.
I have just changed stator and R/R again and still have same problem. The charging system only comes on when i manually turn lights on. I have checked wires and checked again. I dodnt think a 2 stroke could stress me out this much.
Does the battery (new) have to be a minimum voltage?
Could i be looking at an ignition switch problem, how do you test?
Help needed please. Thanks
The last post was made 8 years, 346 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 2.29 - MySQL Queries: 13 - Page Size: 41.87 Kb
