Hole in crankcases, JB weld?
DRZ4Hunned
PostPosted: 11:12 - 23 Oct 2017    Post subject: Hole in crankcases, JB weld? Reply with quote
I had a crash a few months ago, so I'm in the process of getting the FZS600 back on the road. Unfortunately the crank cases were cracked where the surface meets the starter clutch cover. The impact caused the bolt to rip the casting out and has left a hole.
Is this area of the engine under high oil pressure? I was thinking maybe just use some JB weld or similar to repair it? Hopefully the other bolts will be enough to prevent a leak?
https://i.imgur.com/xiWF7yJ.png
DRZ400-SM
FZS600
solemnwarning
PostPosted: 11:51 - 23 Oct 2017    Post subject: Reply with quote
Has it created a new hole, or merely pulled the threads out? If there's enough metal left, and the hole isn't an oilway or something, a helicoil might be an easy (and strong) solution.
PostPosted: 12:03 - 23 Oct 2017    Post subject: Reply with quote
Sounds like a job for aluminium solder.
If there is a crack, you'll need to drill a stop-hole to prevent the crack propogating further then fill the crack and the hole.
You can fill huge defects with aluminium solder, you can also file it back flush, drill it and tap it.
You'll need a good source of heat like oxyacetylene or MAP gas (and some practice, the old cover would likely work if it's also alloy).
Durafix is a good brand.
https://youtu.be/n1njyuPBIH0
DRZ4Hunned
PostPosted: 12:52 - 23 Oct 2017    Post subject: Reply with quote
If you look at the bottom left most bolt, you can roughly see where it's ripped the bolt out and taken a chunk of casing out with it. I'd say the hole it's made is about 1cm^2.
I wouldn't trust JB weld.
Buy my scrap engine. 50 ponds.
Tempting, but you're miles away.
Cheers, I'll look into that. [/quote]
DRZ400-SM
FZS600
Teflon-Mike
tl;dr
PostPosted: 15:57 - 24 Oct 2017    Post subject: Reply with quote
JB or Lumiweld etc can do a fantastic job, but the devil is in the detal, and like a lot of DIY not in the job, but the prep.
Crank-Cases generally don't have to stand too much 'stress' just keep the oil in, and I know of pistons fixed with Lumi-Weld, so it can stand some stress.. but its all dependent....
To do that job justice, I would probably want the motor torn down to the bare cases, so that I could first get them clean enough that I wasn't cooking oil oil and crap into the joint, and getting the heat into the case I wasn't cooking critical rubber seals or paper gaskets somewhere in there...
Full tear down, would make me ponder the merit of trying to salvage damaged crankcases, vs cost of replacing, nw or 2nd hand.
NOT tearing down... trying to fix in situ... I would be pondering the potential savings of not tearing down, vs the risk that working around whats still i situ would make the job more of a ball-ache, and likely result in it having to be done, and re-done and never getting properly done.. and in that, the merits of going a cold-cure, using a loaded epoxy, either a propriety gloop like metal-set or a home brew using araldite and aluminium filings etc, which will never be as good as an ali-weld or solder, but can do the job adequately if the wound s clean enough and the area not under too much stress.. a 'strategic' bodge basically. But even there, the prep is the key, and cleanliness next to sodliness, a full tear-down may still be in order, and alternative cases the better solution....
Your call....
Top tip... make sure there's o rocks around when you drop a dirt bike.. always look for the 'soft' landing! That's my advice... cant say I follow my own advice very well, judging by the amount of araldite and lumi-weld in my own dirt bikes over the last 30 years... bludi CoC's always find ROCKS to stick a section round! But still!
DRZ4Hunned
PostPosted: 16:19 - 24 Oct 2017    Post subject: Reply with quote
I've decided to give JB weld a go, nothing to lose eh?
My only concern is the limited space to work in, the clutch mechanism looks like a PITA to remove, so I think I'll put something like a credit card behind it, and then fill the hole with JB weld.
Hopefully there isn't much pressurised oil in that area that will force it's way out any small gaps.
My DRZ has a big skid plate and case savers so I've not had any issues yet. Although I've never really had any crashes on it yet....
DRZ400-SM
FZS600
raesewell
PostPosted: 17:47 - 24 Oct 2017    Post subject: Reply with quote
I pity the poor sod that buys the bike from the OP
Yamaha FJR 1300 Normanton West Yorkshire
monkeyman
PostPosted: 18:40 - 24 Oct 2017    Post subject: Reply with quote
I think you are going to struggle to get a seal after on the mating face. I had something similar happen to me and I couldn't get it to seal
You going to want to try and grind a flat face one it
Im not the best, but im in the top one
RM 250, Husky TE610, K1 GSXR 750
A100man
PostPosted: 21:21 - 24 Oct 2017    Post subject: Reply with quote
Not much I guess.
If it were me and this was purely a utility machine I would clean the buggery out of it with brake cleaner then first patch over from the outside with some bean can or ally sheet having made a good key first with a file then back fill from the inside..
I never tried drilling and tapping JB style epoxy like they say you can but I sure wouldn't attempt too much torque on the screw.
DRZ4Hunned
PostPosted: 22:18 - 24 Oct 2017    Post subject: Reply with quote
Why? I'd tell them about it I'm not a cunt. I've already bodged the output shaft by cutting a grove in it and using a circlip when the threads went Laughing
I have more hope in this working than I did with that.
I am only bodging it together to get it ridable, doing my test on it and then I'll probably just run it into the ground (or more likely crash it). I will update when it's done.
DRZ400-SM
FZS600
monkeyman
PostPosted: 23:29 - 24 Oct 2017    Post subject: Reply with quote
Well if you have mentioned that before, I would buy a new outer cover and JB it directly to the engine case, use Expoxy putty to fill the gap and jb over top. Will definitely work.
I saw something where someone basically cast an engine out of JB weld and that worked....
DRZ4Hunned
PostPosted: 23:36 - 24 Oct 2017    Post subject: Reply with quote
Exactly what I wanted to hear Thumbs Up
DRZ400-SM
FZS600
skatefreak
PostPosted: 09:49 - 25 Oct 2017    Post subject: Reply with quote
Dropped a generic Chinese 125 lump on the genny side and it cracked from the middle all the way up.
Got a scribe and scored a V to expose clean metal and increase the surface area.
Whacked in some JB weld and it was holding fine years after Thumbs Up
PostPosted: 10:02 - 25 Oct 2017    Post subject: Reply with quote
Should be noted that Allen Milliard uses aluminium solder to join the two crankcases he's bandsawed apart when he's making an inline 5 out of two kawasaki triples.
Hahadumball
PostPosted: 10:54 - 25 Oct 2017    Post subject: Reply with quote
he turned a friends 750 h2 tripple into a 4cylinder and you would never know it wasnt supposed to have 4 cylinders
Fin: no matter how much I look at It I can't understand what was going through my head, all I remember is going about 80 and redlining it to stop it seizing.
360 Deg... Five 1/4 turns. :- Teflon-Mike 18 Jan 2015
sickpup
Old Timer
PostPosted: 11:28 - 25 Oct 2017    Post subject: Reply with quote
That would be extremely odd with two cylinders sticking out one side and only one on the other, got any pics?
Islander
PostPosted: 12:27 - 25 Oct 2017    Post subject: Reply with quote
Allen Millyard's a bit smarter than that Very Happy
https://i.ebayimg.com/00/s/MTE5OFgxNjAw/z/RKUAAOSwr81UOVWx/$_57.JPG
Hong Kong Phooey
PostPosted: 17:21 - 30 Oct 2017    Post subject: Reply with quote
But yet he joins the 2 cranks together with JB weld Whistle Liar
I take it you've lost the missing pieces of the engine jigsaw?
DRZ4Hunned
PostPosted: 10:25 - 31 Oct 2017    Post subject: Reply with quote
Yeah, It's probably lodged in the side of the bin lorry. I've got a gear puller, so I'm going to remove the starter clutch for better access, I'll probably add a patch of metal and glue it all together with JB weld. I love a good bodge.
DRZ400-SM
FZS600
The last post was made 8 years, 353 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.58 - MySQL Queries: 13 - Page Size: 115.85 Kb
