So, this Addblu stuff...
Bike Chat Forums Index -> Politics & Current Affairs Goto page 1, 2, 3  Next
PostPosted: 12:38 - 23 Oct 2017    Post subject: So, this Addblu stuff... Reply with quote
It turns out my new van takes it. I only found out when it threatened to go on strike unless I topped the stuff up.
Now, I had noticed a nasty acrid smell from the exhaust but had assumed this was it burning off some sort of paint or coating with it being a brand new van.
Looking into it, addblu is basically urea mixed with water that gets injected into the exhaust system. It reacts with the nitrogen oxide to form ammonia. The ammonia is then passed over the catalytic converter and broken down into nitorgen and water.
So far, so good. But as I recall, a cat only works properly if it's hot (like really hot). This would explain the nasty odour on startup. It's ammonia.
The other feature of this van is it kills the engine when you stop. I can't see how this is going to keep the cat up to tempertature.
So, we're converting nitrogen oxid (which is relatively nasty) into ammonia (which is definately very nasty) and relying on a hot cat to convert it while at the same time fitting a system which kills the engine any time you stop in traffic, thereby preventing the cat from heating up properly.
So I'm awaiting the incoming ground level ammonia scandal due to the mandatory euro 6 emissions defeat system? Or am I missing something?
PostPosted: 12:40 - 23 Oct 2017    Post subject: Reply with quote
On the bright side, could you not just refill it by having a piss? Smile
Itchy
PostPosted: 12:52 - 23 Oct 2017    Post subject: Reply with quote
That's what I thought... darnit Ninja'd.
Itchy
PostPosted: 12:57 - 23 Oct 2017    Post subject: Re: So, this Addblu stuff... Reply with quote
Although it's been a decade since we met I believe it's because you're not a city dweller.
Cities have homelessness problems. Homeless people use the streets as toilets and as a result many city streets stink of hobo urine and poo (San Francisco has such a big problem there is an app for it https://mochimachine.org/wasteland/).
So when the next scandal comes along... nah mate it's just all those hobos drinking special brew and peeing on the streets, nuffink to do with vehicle emissions.
PostPosted: 13:03 - 23 Oct 2017    Post subject: Reply with quote
Can you not just fill it with any old shite?
M.C
PostPosted: 14:33 - 23 Oct 2017    Post subject: Re: So, this Addblu stuff... Reply with quote
Can't you disable start/stop?
PostPosted: 15:11 - 23 Oct 2017    Post subject: Re: So, this Addblu stuff... Reply with quote
I've never driven one but would think its horrendous. Does the engine stop only when it's out of gear or something?
Triumph Trophy Launch Edition
arry
PostPosted: 15:22 - 23 Oct 2017    Post subject: Re: So, this Addblu stuff... Reply with quote
Out of gear, clutch up - ish. Stick the clutch down and it'd fire straight back up.
Didn't like it; disabled it immediately. Much like everything else on all the new cars I've driven, including but not limited to e-braking, hill start assist, blind spot sensors, lane position sensors, 'intelligent' 4wd and any other pointless guff.
grr666
PostPosted: 15:39 - 23 Oct 2017    Post subject: Reply with quote
Had a start/stop Clio estate as a hire car in the South of France. Do not want. Hated it doing things by itself. Have some kind
of hill start assist in the Transit. It's switched off. Funnily enough, as a holder of a full UK driving licence for many years
I can cope with starting from a standstill on a hill. Who on earth needs all this rubbish on cars and stuff in order to get around successfully?
Itchy
PostPosted: 16:03 - 23 Oct 2017    Post subject: Reply with quote
You ever wonder why on a bag of peanuts there are warnings on it stating
"May contain nuts."
It's for people like this.
PostPosted: 16:30 - 23 Oct 2017    Post subject: Reply with quote
On euro 6 vehicles, stop-start is on by default. It can be switched off but turns itself back on again every time you start the engine. It's a touch screen to turn it off. It HAS left me stuck out into junctions a couple of times. Mostly when I was about to stop, the stop-start began to kick-in but then I decided to go again. Cue large van coming to a clattering halt two feet onto a roundabout.
Apparently you could just bung water in the addblu tank on Euro 5 vehicles but some reading around implies the Euro 6 will eventually have a tantrum and go into limp mode if you do.
They are also mandated to point blank refuse to start if they run out of addblu.
Not just vans. My Dads Jag F-pace also has addblu.
None of this however, is the most annoying thing. The MOST annoying thing is the ignition needs to be fully on (along with the blowers, central console nag-screen and euro-mandated driving lights) in order to listen to the radio.
Irn-Bru
PostPosted: 16:36 - 23 Oct 2017    Post subject: Reply with quote
Hill start assist is ok but on my Ducato it only works half the time so you can never trust it. It has traction+ which is a total waste of time, even with the knobbly tyres it is absolutely hopeless. Apart from that it is basic which I like. Had a new Transit for a bit and it had some weird "feature" where it would rev the engine as you let the clutch out. Not sure what it was trying to achieve but I stalled a few times too many in the first few weeks whilst I was getting used to it.
Vracktal
PostPosted: 21:33 - 23 Oct 2017    Post subject: Reply with quote
I absolutely hate modern 'driver aids' on cars. I don't need my car to revmatch for me. I don't need my car to do hill starts for me. I don't need my car to emergency brake for me. I don't need my car to call 999 for me if it thinks i've been in a crash. I don't need my car to beep if it thinks i'm near a wall while parking. I don't need my car to cut power to the wheels if it thinks i've lost traction. I don't need my car to tell me if it thinks there's something in my blind spot. I don't need my car to turn my high-beams on and off for me. I don't need my car to beep if it thinks i'm drifting out of my lane on the motorway. I don't need my car to turn on the wipers for me if it thinks it's raining. I don't need my car to automatically apply the handbrake for me. I don't need my car to tell me the speed limit.
Half this stuff is solutions in search of a problem anyway.
It's all just stuff that i'll have to switch off constantly until it inevitably breaks five years later.
https://vignette1.wikia.nocookie.net/hitlerparody/images/4/49/HitlerPencilThrowGIF.gif/revision/latest?cb=20110901130348
2007 BMW R1200R: On road
2009 BMW G650X Challenge: On road
1975 Norton Commando 850: Off road, awaiting recommissioning
Jewlio Rides Again LLB
PostPosted: 21:53 - 23 Oct 2017    Post subject: Reply with quote
Inb4 Vracktal found dead 6 weeks after going missing because he was rendered unconscious after a freak accident in the wild where he swerved to avoid a squirrel and lefft the road.
Mpd72: I can categorically say i’m Brighter than that, no matter how I come across on here.
HAHAHA HAHAHA Blew Chilly MyCrowSystems
M.C
PostPosted: 22:07 - 23 Oct 2017    Post subject: Reply with quote
How did that happen? Eh? I've only driven a couple of vehicles with start/stop but it works as arry describes; when you release the clutch with the vehicle out of gear.
The hill assist on the work van (Transit) normally* only works on really steep inclines, and doesn't always kick in the same situation. We have a steep ramp exiting the car park, and most of the time it'll kick in (about the only time it does), occasionally it doesn't which sums up my problem with driver aids (inconsistent performance).
The vans also have traction control which just kill the power at the first hint of wheel spin (when pulling away) so you stall Clapping Although my car has TC that doesn't kill the power on vigorous starts so I leave it on. Probably not necessary on a 1.6L petrol tho' Very Happy
*One van in our fleet has the hill assist kick in all the time, even when pulling away on normal inclines Confused It makes it feel like the clutch's slipping.
wr6133
PostPosted: 22:22 - 23 Oct 2017    Post subject: Reply with quote
We call it sheep piss at work.
Vile shite when some nugget spills it on the yard it leaves an unpleasant crystalline layer that is slippery as hell.
My last place we had one tit put it in the screen wash. Expensive mistake. Another put it in the diesel tank..... very, very expensive mistake.
Some marques use piping that is too thin on the adblu system and it bungs up the piping leading to costly repairs (MAN trucks Middle Finger )
PostPosted: 09:44 - 24 Oct 2017    Post subject: Reply with quote
Approach roundabout, slip into neutral from second as coming to a halt, start-stop starts to kick in, decide can go again, dip clutch and back into second (as still rolling clightly) clutch back out, stalls as was in the process of starting.
Mine also has hill start assist. It works so intermittantly it is entirely redundant as there is no way of knowing if and when it will kick in. I also have to do a small shunt when turning up into my drive (didn't in the vito, it was RWD and had a much better turning circle). I usually drive up, dip the clutch to roll back a couple of feet then drive in the rest of the way. Some days you can, some days it puts the brake on and you have to pop it into neutral (making sure you ride the clutch so it doesn't stop-start).
arry
PostPosted: 10:05 - 24 Oct 2017    Post subject: Reply with quote
That's an odd one as it should only cut out when the vehicle is entirely at a standstill. If you were still rolling, it shouldn't have happened.
As for hill start assist - garbage thing it is - it's problem amplified when you've got an electronic handbrake (why over-complicate things unnecessarily?) Which you then can't regulate like a normal handbrake and the assist decides it's not going to kick in.
Or worse, does kick in, and then the light on the dash starts flashing to let you know it's about to cut off again - of course you're not looking at the dash you're looking for a gap to pull out into. Stupid thing.
Matt B
PostPosted: 10:29 - 24 Oct 2017    Post subject: Reply with quote
Adblue is a right PITA. Our A5 uses it and the worst thing is the cost, we get massively ripped off for it over here compared to mainland Europe. Near on impossible to find on pump over here so it's £14 for 10 litres from Halfords. Every other fuel station in Holland and many in France have it on pump for literally pennies per litre.
PostPosted: 11:04 - 24 Oct 2017    Post subject: Reply with quote
Electronic handbrakes Shocked
Why oh why has some stupid twat come up with those. The one I drove I was never sure the damn thing was working. I ended up leaving the car in gear all the time I parked it and I never got hill starts mastered with the stupid thing.
Itchy
PostPosted: 11:15 - 24 Oct 2017    Post subject: Reply with quote
You should see Mercs.
The hand brake isn't a hand brake at all. It's a foot pedal tucked where the clutch should be. To release it you have to use your right hand where the mirror adjusters normally are.
PostPosted: 11:28 - 24 Oct 2017    Post subject: Reply with quote
I quite like those though, my vito had the same system. No hand brake, it's just a parking brake operated with your left foot. For hill starts, the foot brake can be pushed down past the point it bites then slowly lets itself up again. Takes about a second in reality which is plenty of time to get off the brake and on the throttle in a hill start.
Thing is, it's very predictable with a positive action, you can feel when you've applied it. Flows well when driving and in combination with the bulkhead mounted gearshift, makes a very clear footwell without a gearstick or handbrake in the way.
PostPosted: 13:12 - 24 Oct 2017    Post subject: Reply with quote
I miss my Vito foot brake - at least the boxer has it on the right of the driver's seat (Because; race-car!... or more, as I've got two single seats and no bulkhead, can easily get up and walk through to the back - if need be getting out of the rear or side doors; which is useful because it's really wide.
BTTD
PostPosted: 13:33 - 24 Oct 2017    Post subject: Reply with quote
My Merc has auto on off, and being an automatic it turns off whenever you come to a standstill and you have your foot on the brake.
It fires up as soon as you lift off the brake or hit the accelerator (it also has a brake assist thing where once stopped you give the brake pedal a further poke and the foot brake locks on until you hit the accelerator or the brake pedal again), or turn the steering wheel (requiring the power steering to work).
It just works seamlessly and has never caused me any delay or hesitancy. If you really want to race someone off the lights there is a handy button on the dash to disable it.
mudcow007
PostPosted: 14:55 - 24 Oct 2017    Post subject: Reply with quote
We had an XC90 on loan from Sixt which had every electronic toy in the universe imaginable installed
Automatic handbrake was dangerous, everytime the car stopped the handbrake would apply even just reversing out of a space an goign through traffic
Are people to think to use manual controls now?
Some gadgets are useful, like radar controlled cruise control
The last post was made 8 years, 253 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.20 Sec - Server Load: 1.54 - MySQL Queries: 13 - Page Size: 141.89 Kb
