KTM SMC 660 - diagnosis thread
DrSmith
PostPosted: 23:37 - 28 Feb 2017    Post subject: KTM SMC 660 - diagnosis thread Reply with quote
These bikes are notoriously difficult to start, but even after being fairly certain I've acquire the knack, I'm having problems.
I could get the bike running after about an hour of kicking the shit out of it - most times it would start without the choke (though I'd have to use some choke immediately after firing up to keep it ticking over until it was warmed up). Once it's warm I can start it first kick, every time. I decided it must be easier than this and that I can't do an hour of kicking every time I want to go for a ride, and so did some tinkering (foolish, I know). I took the carb off and gave it a good clean. I replaced the spark plug. Still woeful.
A couple of days ago I started messing around with the air/fuel screw and idle screw to see if I could get some sort of change. I reset the air/fuel screw to two turns out. Went through the well-schooled kicking procedure and was getting some gurgling - like it wanted to start but someone was hitting the kill switch immediately after I kick - I consider this progress after hundreds of kicks where I got nothing, but still not starting right.
I randomly decide to try kicking with the hot start button pushed in (bike's still cold) and weirdly the bike starts but then dies after a couple seconds. I then try the hot start button and the choke and it starts and stays fired up. Amazing. But I immediately realise there must be something pretty weird going on if the bike prefers to start with the hot start button and choke on simultaneously from cold.
I let the bike warm up and start investigating the air/fuel screw. I wind it all the way out and the bike is still running. Weird. I wind it all the way in and the bike still runs. Weirder still.
So what does that mean? The hot start button, the mixture screw. It's all a bit concerning. Did I mess something up when I cleaned the carb? Did I have the idle screw too high? Would that cause it to not stall when adjusting the mixture screw? What other tests should I do?
hmmmnz
PostPosted: 08:28 - 01 Mar 2017    Post subject: Reply with quote
ktm's are notorious for running lean out of the box to pass emmissions,
i think its time you took the bike to a dyno and get it tuned properly,
as for the pilot screw, it could be that the passage that the pilot screw screws into is blocked,
i think you need to pull the carb again, soak the carb in kerosene/parrafin and then blow through all the passage ways with compressed it.
my ktm would start 2nd kick with no use of the hot start.
mind you it also had electric start so i hardly ever kicked it over
the humans are dead
I kick arse for the lord
There is a gap of 236 days between these two posts...
DrSmith
PostPosted: 13:41 - 23 Oct 2017    Post subject: Reply with quote
I've discovered a routine in which I can now get the bike to start rather easily, but I can't understand why this routine works and what the cause could be.
Firstly, I know the bike will not start in the same state as it runs when it's hot. Before I do anything I will unwind the idle screw 2-3 turns, put the choke on, give it a tiny bit of throttle and this is usually sufficient to start the engine. However, since it does not like running in this state, I will have to wind in the idle screw back to where it was so that the tickover is high enough that it doesn't stall. The choke can be turned off immediately after putting the idle screw back to its original position.
What's going on here then? Why won't the bike start with a "normal" idle screw position? What's happening inside the carb that allows the bike to start with the idle screw unwound, and how do I fix it?
Here are my thoughts: Since the mixture screw (air/fuel mix screw, NOT idle screw - carefully making that distinction) had no effect on idle speed when I wound it right in, the manual suggests a smaller idling jet is then required. Would this be because it is making it too rich? If so then this makes sense about me having to unwind the idle screw in order to get it to start - I'm effectively balancing out the mixture by making it leaner with the idle screw so that it will start. Solution: install a smaller idling jet?
PostPosted: 14:24 - 23 Oct 2017    Post subject: Reply with quote
Set carb to factory default, don't touch the mixture screw, you don't have to.
Clean the carb so its spotless.
The idle should be set to 1400-1500 when warm, so get it working and up to temp, make sure its that temp then make sure absolutely everything is stock settings.
Have you had the valve clearances checked too?
DrSmith
PostPosted: 14:28 - 23 Oct 2017    Post subject: Reply with quote
This is a problem with engine start procedure, not the conditions of it running whilst warm.
Everything is already at stock.
PostPosted: 14:36 - 23 Oct 2017    Post subject: Reply with quote
But you've adjusted the mixture screw, and the idle screw? Or have I misread that fact. Stop touching screws and leave at stock Smile
The valves? No? Yes?
DrSmith
PostPosted: 14:51 - 23 Oct 2017    Post subject: Reply with quote
Valves are spot on.
It's perfectly fine to adjust mixture and idle screws to achieve nominal behaviour. A correctly adjusted carburetor strongly affects engine starting behaviour. Fuel type, altitude, and temperature all contribute to the individual conditions in which a carburetor should be adjusted to; in this sense, there is no such thing as a "stock" setting. "Stop touching screws" is not the answer here.
PostPosted: 14:55 - 23 Oct 2017    Post subject: Reply with quote
Thumbs Up Enjoy your badly starting bike
DrSmith
PostPosted: 15:01 - 23 Oct 2017    Post subject: Reply with quote
Facetious comments are neither helpful, nor make you come across as a nice person. There are better ways to deal with someone not finding your advice helpful.
monkeyman
PostPosted: 20:55 - 23 Oct 2017    Post subject: Reply with quote
There is definitely something not right with KTM
It should start reliably, you shouldn't have to mess with the screws between warm and cold
Try going up a jet on your pilot, also check the choke airway is clean
Alternatively try it on easy start, if it starts easy, indicates a lean condition
The logic being that when cold a lean condition makes an engine hard to start
Im not the best, but im in the top one
RM 250, Husky TE610, K1 GSXR 750
DrSmith
PostPosted: 22:48 - 23 Oct 2017    Post subject: Reply with quote
Haha you're not wrong! I've yet to meet a single LC4 owner that doesn't have a story about having to get the mixture and idle screws absolutely cock on for the thing to behave itself.
I know my way around these carbs reasonably well by now and I'm convinced there's something more going on, and I too think that it's a jetting issue.
Your logic sounds about right, I just needed to hear someone else suggest it. I'll give it a try, thanks!
monkeyman
PostPosted: 23:31 - 24 Oct 2017    Post subject: Reply with quote
If you could reply earlier than 236 days with the result that would be great. I need closure!
The last post was made 8 years, 355 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 2.11 - MySQL Queries: 13 - Page Size: 75.6 Kb
