Battery terminals
mikey909
PostPosted: 23:27 - 24 Oct 2017    Post subject: Battery terminals Reply with quote
When I place the negative connector to the negative point on my battery, the indicator on my charger would light up for a second, then go out. I can tap the connector on the point continuously and it'll light up and go out.
The points have been cleaned, I don't think that the battery is completely dead as the indicator on my charger would light up.
any suggestions?
jaffa90
PostPosted: 00:07 - 25 Oct 2017    Post subject: Reply with quote
What is the problem?
Are you charging the battery on or off the bike?
MCN
PostPosted: 02:37 - 25 Oct 2017    Post subject: Reply with quote
Charger FUBAR.
Check it on a 'good' battery.
Or if you have a multimeter check the volts output and or the amps output.
The charger drops 220v AC down to charging voltage 6V, 12V, 24V etc. and also converts to DC.
Rectifier or resistor or something could be fookid.
Islander
PostPosted: 09:43 - 25 Oct 2017    Post subject: Reply with quote
Check the battery voltage first. If it's badly discharged then a smart charger won't work properly - it's possible to trick the charger into starting up by putting a good battery in parallel with the flat one if this is the case.
mikey909
PostPosted: 01:54 - 26 Oct 2017    Post subject: Reply with quote
I'm charging off the bike.
I have checked my charger against another battery and it charges just fine, so it must be an issue with the battery itself.
Hawkeye1250FA
PostPosted: 12:07 - 26 Oct 2017    Post subject: Reply with quote
Its either (a) the charger
or (b) the battery
Youve checked the charger - so its (b).
well done on answering your own question Smile Smile Smile
1993 RF400R - 2002 Bandit 1200 - 2012 1250 FA
The last post was made 8 years, 343 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.34 - MySQL Queries: 13 - Page Size: 47.61 Kb
