BCF looks like this now...
PostPosted: 09:51 - 25 Oct 2017    Post subject: BCF looks like this now... Reply with quote
At work my BCF now looks like this.
At home it is fine.
This is probably because web browsing at work it pretty restrictive, however it was fine last week and I don't know how a block would cause a website to half load. Nothing else is affected.
https://www.bikechatforums.com/download.php?id=100466
sickpup
Old Timer
PostPosted: 10:32 - 25 Oct 2017    Post subject: Reply with quote
Its the firewall.
ScaredyCat
PostPosted: 10:36 - 25 Oct 2017    Post subject: Re: BCF looks like this now... Reply with quote
At home it is fine.
You're not getting the css and some javascript. CSS is loaded from 44bytes.net not bikechatforums.com - check to see if 44bytes.net is visible /usable.
Honda CBF125 ➝ NC700X
Honda CBF125 ↳ Speed Triple
PostPosted: 10:53 - 25 Oct 2017    Post subject: Re: BCF looks like this now... Reply with quote
ScaredyCat wrote:
At home it is fine.
https://www.44bytes.net/ loads fine, anything else loaded from somewhere external? How do you check?
Cheers,
Chris
ScaredyCat
PostPosted: 11:10 - 25 Oct 2017    Post subject: Re: BCF looks like this now... Reply with quote
View the source of the page or use the developer options for your browser (eg Chrome = right click -> inspect -> sources tab / Similar for Firefox) and refresh the page... you should see all the files and results (404's errors etc) at the bottom...
https://www.dropbox.com/s/uiwoylkksnk82ka/inspect.png?raw=1
Evil Hans
PostPosted: 11:13 - 25 Oct 2017    Post subject: Re: BCF looks like this now... Reply with quote
Cheers,
Chris
Loads fine if you connect to it directly, but your work proxy server is probably rejecting cross site scripting - pages from one domain trying to load scripts from another.
PostPosted: 11:42 - 25 Oct 2017    Post subject: Reply with quote
Failed to load resource: the server responded with a status of 404 (Not Found)
master.js Failed to load resource: the server responded with a status of 404 (Not Found)
spacer.gif Failed to load resource: the server responded with a status of 404 (Not Found)
gold_6.gif Failed to load resource: the server responded with a status of 404 (Not Found)
gold_9.gif Failed to load resource: the server responded with a status of 404 (Not Found)
87601472557ad6e373068.jpg Failed to load resource: the server responded with a status of 404 (Not Found)
icon_minipost.gif Failed to load resource: the server responded with a status of 404 (Not Found)
neutral.gif Failed to load resource: the server responded with a status of 404 (Not Found)
icon_quote.gif Failed to load resource: the server responded with a status of 404 (Not Found)
icon_edit.gif Failed to load resource: the server responded with a status of 404 (Not Found)
icon_clip.gif Failed to load resource: the server responded with a status of 404 (Not Found)
icon_profile.gif Failed to load resource: the server responded with a status of 404 (Not Found)
icon_pm.gif Failed to load resource: the server responded with a status of 404 (Not Found)
142197556145b7641e20fdd.jpg Failed to load resource: the server responded with a status of 404 (Not Found)
gold_1.gif Failed to load resource: the server responded with a status of 404 (Not Found)
rating_good.gif Failed to load resource: the server responded with a status of 404 (Not Found)
rating_bad.gif Failed to load resource: the server responded with a status of 404 (Not Found)
gold_2.gif Failed to load resource: the server responded with a status of 404 (Not Found)
icon_minipost_new.gif Failed to load resource: the server responded with a status of 404 (Not Found)
1076961705649fa3f38482.png Failed to load resource: the server responded with a status of 404 (Not Found)
beta_tag.gif Failed to load resource: the server responded with a status of 404 (Not Found)
uirhzlnracgcogqpab.gif Failed to load resource: the server responded with a status of 404 (Not Found)
ebay_rightnow.gif Failed to load resource: the server responded with a status of 404 (Not Found)
thumb_up.gif Failed to load resource: the server responded with a status of 404 (Not Found)
thumb_down.gif Failed to load resource: the server responded with a status of 404 (Not Found)
viewtopic.php:1 Mixed Content: The page at 'https://www.bikechatforums.com/viewtopic.php?t=322369' was loaded over HTTPS, but requested an insecure script 'https://c80ded700fccf041d00849c0570c14f4bbc9.d0452497.id.opendns.com/s/bpb.o…%22https%3A%2F%2Fwww.bikechatforums.com%2Fviewtopic.php%3Ft%3D322369%22%7D'. This request has been blocked; the content must be served over HTTPS.
viewtopic.php:1 Mixed Content: The page at 'https://www.bikechatforums.com/viewtopic.php?t=322369' was loaded over HTTPS, but requested an insecure script 'https://fc4d0c810fd2b0472d0853c0a2b8fc43a0c1.d0452497.id.opendns.com/s/bpb.o…%22https%3A%2F%2Fwww.bikechatforums.com%2Fviewtopic.php%3Ft%3D322369%22%7D'. This request has been blocked; the content must be served over HTTPS.
viewtopic.php:1 Mixed Content: The page at 'https://www.bikechatforums.com/viewtopic.php?t=322369' was loaded over HTTPS, but requested an insecure image 'https://7d7fd6d90327504b140aee707256e207d386.d0452497.id.opendns.com/s/bpb.o…327504b140aee707256e207d386_91837321f1bade666c15c35dd92302becab973d8_raw=1'. This content should also be served over HTTPS.
about:blank:1 Mixed Content: The page at 'https://www.bikechatforums.com/viewtopic.php?t=322369' was loaded over HTTPS, but requested an insecure resource 'https://519dedbe0abb404d280bb0b03c9d50bf4b5a.d0452497.id.opendns.com/s/bpb.o…tandard&show_faces=false&width=500&action=like&colorscheme=light&height=25'. This request has been blocked; the content must be served over HTTPS.
viewtopic.php:1 Mixed Content: The page at 'https://www.bikechatforums.com/viewtopic.php?t=322369' was loaded over HTTPS, but requested an insecure image 'https://e8f6681f0dcd4041ec0aab40077000655d0b.d0452497.id.opendns.com/s/bpb.o…dcd4041ec0aab40077000655d0b_adbff4a46c5d7f1bd30fa5a74756bc81ef0e6af3_raw=1'. This content should also be served over HTTPS.
viewtopic.php:226 Uncaught TypeError: Cannot set property 'value' of null
at rate_post (viewtopic.php:226)
at <anonymous>:1:2
at <anonymous>:1:2
phpbb.css Failed to load resource: the server responded with a status of 404 (Not Found)
Tracey Suntan-King
PostPosted: 12:49 - 25 Oct 2017    Post subject: Reply with quote
No......it looks like this
https://coolandcollected.com/wp-content/uploads/2013/02/monkeysonmotorcycles.jpg
(inside my head Very Happy)
thx1138
PostPosted: 12:51 - 25 Oct 2017    Post subject: Reply with quote
sickpup wrote:
Its the firewall.
and the Ste fence.
PostPosted: 14:56 - 25 Oct 2017    Post subject: Reply with quote
It's back to normal now. It had been like that all this week!
Jayy
Mr. Ponzi
PostPosted: 15:05 - 25 Oct 2017    Post subject: Reply with quote
Only just noticed that BCF does use SSL but if someone posts some content from a 3rd party, i.e. a photo, it can't be served over SSL and you get the mixed content warning.
Never actually come across the scenario but is there any way around that? ... you can't force SSL everywhere or via a script, as images wouldn't work if the source isn't SSL and you force it to be?
PostPosted: 15:30 - 25 Oct 2017    Post subject: Reply with quote
Not really, serving non secure content on secure pages means you gotta break it. It's normal though, and happens more than you'd like to believe.
Either way, unless it purchase related, fuck it.
Jayy
Mr. Ponzi
PostPosted: 15:43 - 25 Oct 2017    Post subject: Reply with quote
I've literally just been on an SSL spree over the past few weeks, probably done 30 installs / configs. In all cases though, nobody is posting content to 3rd parties, it's all uploaded onsite only, so this issue has never presented itself until I noticed it in this thread.
Interesting that there's not a way around it yet Thinking
PostPosted: 15:57 - 25 Oct 2017    Post subject: Reply with quote
I deal with the ssl and https side of stuff here for some part and the amount of sites that have https served shit and then http, then complain about their certs not being right... crazy.
However in Chris's case, the underlying side is probably this cdn now blocked on your content filter or someone has done the latest smoothwall upgrade and lunched their default policy. If you got a smoothwall/bloxx on site, there you go.
t121anf
PostPosted: 19:35 - 25 Oct 2017    Post subject: Reply with quote
Went SSL to please google iirc.
mentalboy
PostPosted: 01:07 - 26 Oct 2017    Post subject: Reply with quote
Presumably you tried turning it off and then on again? Laughing
Make mine a Corona.
The last post was made 8 years, 146 days ago. Instead of replying here, would creating a new thread be more useful?
Post new topic   Reply to topic    Bike Chat Forums Index -> The Geek Zone All times are GMT
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.73 - MySQL Queries: 13 - Page Size: 95.74 Kb
