Fitting fork gators
Ledzep1
PostPosted: 23:06 - 27 Oct 2017    Post subject: Fitting fork gators Reply with quote
Hi - this may be a daft question.... Just got a lexmoto Ranger which I want to fit some fork gators on. I can see plenty of universal ones on ebay, but it's not clear whether they have a split so you can fit them then tighten them or you have to take off the tyre and slip them on.
I don't want to have to take the front wheel off, it's only done 300 miles so that seems a daft idea with my mechanical skills - can anyone point me in the direction of something which is an easy fit without having to get the wheel off?
Many thanks - Martin
Commuter_Tim
PostPosted: 23:10 - 27 Oct 2017    Post subject: Reply with quote
No, you aren't likely to fit them over the bottom of the fork legs.
Generally its remove wheel, prop bike up so it doesn't dive right to the ground, remove forks, slip gaiters over the top of the fork stanchion, refit.
Or alternatively you could make some out of neoprene (old wetsuit?) and some velcro, no tools required to fit them.
I am curious what relevance the mileage has to whether you should take the front wheel off though. Thinking
I ride a Bandit 600... badly.
bamt
PostPosted: 23:17 - 27 Oct 2017    Post subject: Reply with quote
You'd normally fit them by dropping the forks out of the triple tree at the top, then slip the gaiters on. The lower part of the forks has all sorts of brazed on bits for brakes and mudguard fittings that will stop them going on easily from the bottom. The ones I've used are not a very stretchy rubber, so won't deform to go over them.
There are some with velcro at the back, but I'm not sure how well they hold up in use - velcro isn't noted for being particularly flexible, and the gaitors have to compress and expand.
Ledzep1
PostPosted: 00:00 - 28 Oct 2017    Post subject: Thanks Reply with quote
Thanks for the advice - basically - don't want to stuff things up as it's new so I was hoping for some kind of gator I could put on without removing anything - i assumed they had a split at the back so you fitted them then just kind of clipped them back together - if only it was that simple...
Commuter_Tim
PostPosted: 00:23 - 28 Oct 2017    Post subject: Reply with quote
I had the same concerns, so I made mine with gaps between the 4 strips up the back, so the neoprene could compress between the velcro.
I figured that would also help moisture escape, not sure if that part was just wishful thinking though.
However they held up nicely for 2 years before I stopped caring so much about my stanchions.
PostPosted: 08:11 - 28 Oct 2017    Post subject: Reply with quote
You could fit split-and-zipped neoprene protectors without dropping the forks, for example:
https://www.ebay.co.uk/itm/221936135583
They're intended for upside-down forks but I see no reason why they wouldn't work on RWU as well. You'll want to measure up your forks and find ones that fit.
The last post was made 8 years, 334 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.29 - MySQL Queries: 13 - Page Size: 48.63 Kb
