| Paulf |
 Paulf Nova Slayer
| Tankie |
 Tankie Crazy Courier
| cb1rocket |
 cb1rocket World Chat Champion
 Posted: 21:25 - 26 Oct 2017 Post subject: |
Get a new oem headgasket and give it a good clean on the head and barrel. No need to retorque these. They are too light at 27Nm
I run a fleet of them and sometimes the aftermarket gasket are shit. Even worse if an old is used but sometimes 50/50 chance.
The overflow bottle should rise as the engine warms up. If not check under the centre panel and remove rad cap and if the coolant has gone down then it's the headgasket. Check also the rubber hose pipes are done up tight too. ____________________ Honda H100S2 Rebuild - https://www.bikechatforums.com/viewtopic.php?t=253852 |
| Paulf |
 Paulf Nova Slayer
| Tankie |
| Pete. |
 Pete. Super Spammer
| cb1rocket |
 Posted: 22:43 - 28 Oct 2017 Post subject: |
Agree with Pete, except the only thing i have found with these when the head had gone is that the level never rises or blow out of the expansion bottle on these models.
Its doing exactly what the op said and that it stays the same level in the bottle but the water disappears from the rad.
Source: i run a fleet of these (over ten of them) and 3 have suffered this fate ____________________ Honda H100S2 Rebuild - https://www.bikechatforums.com/viewtopic.php?t=253852 |
| Pete. |
 Pete. Super Spammer
 Posted: 23:01 - 28 Oct 2017 Post subject: |
Empirical evidence is always best but I was talking in general terms why it happens to raise the understanding of the process. Many people don't understand the function of an expansion bottle or how it works, and many over-fill them thinking that the level is low too. ____________________ a.k.a 'Geri'
| Paulf |
 Paulf Nova Slayer
| cb1rocket |
The last post was made 8 years, 348 days ago. Instead of replying here, would creating a new thread be more useful? |
