Peugeot Speedfight 2 - No lights or electric start.
daly2834
PostPosted: 18:15 - 30 Oct 2017    Post subject: Peugeot Speedfight 2 - No lights or electric start. Reply with quote
Newbie with a noobie question!! Embarassed
My Speedfight2 lights and electric start stopped working.
The front, rear and dash lights and electric start all stopped working suddenly.
However the indicators, brake lights and horn still work perfectly.
Engine is also running fine (with kick start)
When I try to start it using the electric start only the starter relay clicks.
So far I have replaced the fuse, bulbs and swapped the battery also.
My question is, could it be the starter motor itself? And if so, would this cause the lights to stop working? Or is it more like a dodgey connection?
Any help appreciated.. Thanks Smile
jaffa90
PostPosted: 18:25 - 30 Oct 2017    Post subject: Reply with quote
Have you tried jump leads from a good / donor battery or what is the battery voltage reading?
Andy_Pagin
PostPosted: 15:49 - 31 Oct 2017    Post subject: Reply with quote
Check for a bad earth connection.
daly2834
PostPosted: 16:43 - 31 Oct 2017    Post subject: Reply with quote
I took a live feed from the battery today directly to the starter motor and nothing. I have a spare one laying around so ill get that fitted tomorrow.
But in the mean time i am just wondering if anyone knows if this electrical circuit is anyway related to the headlights? And could the faulty starter motor be the reason my headlight and rear light stopped working?
andys675
PostPosted: 21:23 - 31 Oct 2017    Post subject: Reply with quote
yes it is
check battery voltage
can you turn starter with your fingers?
daly2834
PostPosted: 16:47 - 01 Nov 2017    Post subject: Reply with quote
New starter installed and IT works perfect.
But the front and rear lights still not working.
Only brakes indicators and horn work.
.... help! Sad
Havnt been able to measure battery yet, no multimeter. But it's brand new so I don't expect it.
daly2834
PostPosted: 18:37 - 03 Nov 2017    Post subject: Reply with quote
I've checked all bulbs, fuses, connectors etc. but lights still don't work.
I'm suspecting the switch on handle bars. Is there any quick way to test this?.
The last post was made 8 years, 237 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.74 - MySQL Queries: 13 - Page Size: 50.85 Kb
