Honda Hornet Flickering Rear Lights
TimNorwich
PostPosted: 19:37 - 01 Nov 2017    Post subject: Honda Hornet Flickering Rear Lights Reply with quote
Hi BCF. I’ve recently purchased a 2001 Honda Bornet, it has one of those Powerbronze undertrays fitted with the shotgun LED style lights.
The number plate lights underneath seem to be flickering.
I’ve taken a video if it:
https://youtu.be/PO8nJkYnqwE
Any ideas what this could be?
Thanks in advance!
PostPosted: 19:54 - 01 Nov 2017    Post subject: Reply with quote
It's fucked?
Is it a replaceable bulb?
TimNorwich
PostPosted: 20:47 - 01 Nov 2017    Post subject: Reply with quote
Nah I don’t think so as they’re LED so I presume they’re built in. Hoping it might be a dodgy connection but it’s just strange.
Chris45
PostPosted: 21:50 - 01 Nov 2017    Post subject: Reply with quote
Poor connection.
Honda CG125>Suzuki GT185>Honda CB 250N>Suzuki GSX400>Honda CX500B>Kawasaki GPZ305> Kawasaki GPZ550>Kawasaki GPZ500S+BMW 650GS
ThatDippyTwat
PostPosted: 21:57 - 01 Nov 2017    Post subject: Reply with quote
No discernible pattern, so it's almost certainly a fucky connection, rather than it picking up a signal from somewhere it shouldn't be.
TimNorwich
PostPosted: 22:03 - 01 Nov 2017    Post subject: Reply with quote
Ok cool, is that dodgy connection likely to be where the wires join then? I had a little pull/push about to see but didn’t help. Thanks
PostPosted: 22:36 - 01 Nov 2017    Post subject: Reply with quote
I think it's got a dodgy bulb or the LED is actually wanged. It's too, continuous for the connection to be wonky.
ThatDippyTwat
PostPosted: 23:13 - 01 Nov 2017    Post subject: Reply with quote
LED's don't flicker like a dodgy bulb does. They work, or they don't, unless you're spectacularly unlucky.
It's a connection or trace that's dicky if it's got a PCB.
PostPosted: 23:29 - 01 Nov 2017    Post subject: Reply with quote
Logic would say that there is 1 feed for the lights. One works. However I've never seen that set up so not a clue.
Chris45
PostPosted: 23:47 - 01 Nov 2017    Post subject: Reply with quote
Eyeballing it usually doesn't help and fiddling with it usually makes it worse or fail completely. Believe me we've all been there. So it's time to start learning, get your voltmeter out and begin by testing circuits, follow the junctions, make sure you get a good healthy beep at each stage. Somewhere along the line you'll learn something and hey-ho you did it yourself!
TimNorwich
PostPosted: 11:09 - 03 Nov 2017    Post subject: Reply with quote
Initially the lights don't flicker when they're first turned on but then they start. Does this make any difference?
Nobby the Bastard
Harley Gaydar
PostPosted: 14:13 - 03 Nov 2017    Post subject: Reply with quote
That would indicate something is getting warm and moving, breaking the connection, and then cooling, remaking the connection.
I wouldn't have thought that leds would draw enough to cause that sort of heating and the flickering is very quick for that.
Triumph Sprint ST 1050
The last post was made 8 years, 234 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.94 - MySQL Queries: 13 - Page Size: 70.26 Kb
