Internet problems
Bike Chat Forums Index -> The Geek Zone Goto page 1, 2  Next
King29
PostPosted: 09:55 - 02 Nov 2017    Post subject: Internet problems Reply with quote
One for all branded electrical internet adapter plugs. My broadband router is downstairs and I am on Virgin 100 fiber. I use the plugs to get a broadband connection as PC is upstairs in back bedroom. I get random disconnections and have to take the plug out and put it in again it always connects straight away but it annoying. Would better branded or more expensive plugs stop the drop in signal? The plugs are good for 500 mbs.
Also I've tried connecting via wireless, on speed test my Laptop gets 80 meg no problem. My PC on the other hand gets 17 when a wireless dongle is attached? I've tried 2 different brands in various USB ports a MicroNEXT branded usb adapter and a TP-LINK TL-WN823N Mini N300 and neither get above 17 meg. The specs of the PC far out weigh the specs of the laptop so it's not a performance issue. Stuck for a suggestion at the mo so any help would be most welcomed.
fatjames
PostPosted: 10:09 - 02 Nov 2017    Post subject: Reply with quote
I've never had much joy with USB wifi dongles, I think the bottle neck is the speed of USB. You'd be much better of with a dedicated wifi card, one with the little aerials poking out the back.
I've also had mixed experience with home plugs, but currently use a TP link set with no issues.
Problem could be to do with the line between the two plugs, interference etc.
PostPosted: 11:12 - 02 Nov 2017    Post subject: Reply with quote
Cable really not a possibility.
Cables are tiny and houses have many places for small holes.
King29
PostPosted: 11:26 - 02 Nov 2017    Post subject: Reply with quote
Paddy.
Nah, cable routing is a nightmare. I bought 25 meters of cat 5 and ran it all casual down the stairs across the living room into the hub. Wife says "If you think that's staying like that you've another thing coming". Routing is awful, thank you for the suggestion anyway.
fatjames
I could buy a pcie wifi card, I might just do that. Cheers for the suggestion.
PostPosted: 11:59 - 02 Nov 2017    Post subject: Reply with quote
Can't tack it to skirting all the way round? Wired a few houses now and you never notice the cable.
PostPosted: 12:36 - 02 Nov 2017    Post subject: Reply with quote
Second router in repeater mode upstairs? Plug the PC into it with a cable.
Probably costs about the same as a wifi card.
ScaredyCat
PostPosted: 13:01 - 02 Nov 2017    Post subject: Reply with quote
Mikrotik hAP AC Lite would do it. Configure the wifi on it to be a client of your existing WiFi and deliver connectivity to, up to, 5 wired devices.
Honda CBF125 ➝ NC700X
Honda CBF125 ↳ Speed Triple
PostPosted: 15:56 - 02 Nov 2017    Post subject: Reply with quote
Your powerline connection may be shit because of the adaptors or because of the wiring in you house. I have Belkin 1gbps ones they were solid for me they would rarely need a reset, I'm talking months. As for speed I could always max out my 100mbps connection. If you want them they are yours for £25 delivered, I don't use them any more as I have run CAT5.
iooi
PostPosted: 19:56 - 02 Nov 2017    Post subject: Reply with quote
King29 wrote:
Paddy.
Out through the wall. and back in, in the room you need it in Thumbs Up Karma
MahatmaAndhi
PostPosted: 20:07 - 02 Nov 2017    Post subject: Reply with quote
That's what the previous owners of this house did, but with proper ethernet ports on the wall.
Pity they routed it in to what is now the kids' room, so it's useless for me. They went through the living room wall, up and in to the attic, then down through the ceiling to another port.
You could then put a switch upstairs and run multiple wired connections if needed.
2008 Aprilia Sportcity 250
Hawkeye1250FA
PostPosted: 20:46 - 02 Nov 2017    Post subject: Reply with quote
I would just take the Ethernet cable out through the wall - then round the outside of the house to the appropriate room and put it in there...
But then I like doing things quickly and easily.
1993 RF400R - 2002 Bandit 1200 - 2012 1250 FA
Loui5D
PostPosted: 12:56 - 03 Nov 2017    Post subject: Reply with quote
Use an access point instead of a repeater.
A repeater will as you can guess just repeat the signal, if the signal was dodgy in the first place it'll now become even worse.
An AP will make the connection less flakey as it'll clean the connection up a bit.
King29
PostPosted: 15:15 - 03 Nov 2017    Post subject: Reply with quote
mpd72 wrote:
Are the powerline adapters at both ends straight into a wall socket or through a 4 way strip?
Straight into the wall via a splitter plug upstairs and downstairs in via a 5 feet long cable into a splitter plug into an 8 way powerbank surge protected.
https://i.imgur.com/TGx6mTA.jpg
https://i.imgur.com/HolA6qQ.jpg
fatjames
PostPosted: 16:27 - 03 Nov 2017    Post subject: Reply with quote
There's your problem!
If you want to continue to use home plugs, get some of the pass-through variety.
PostPosted: 16:28 - 03 Nov 2017    Post subject: Reply with quote
He said he was getting 80 meg on his laptop, suggesting the problem doesn't lie in the signal strength but his PCs means of usign that signal. That's why I suggested a way that would allow him to plug the PC in.
You can buy pretty high-end, commercial quality wireless routers on ebay secondhand for about £20.
PostPosted: 16:30 - 03 Nov 2017    Post subject: Reply with quote
Wire them into the plug socket, not into a multi or surge. Neutral
Baffler186
PostPosted: 16:41 - 03 Nov 2017    Post subject: Reply with quote
Seems to have been sorted now, but I have always had limited success with dongles. My powerline adapter is TP links and was about £30, no trouble for over 3 years, plugged into a 4 gang extension but no surge protection.
Current: 2009 SV650 S, 1990 Kawasaki GT550
Previous: 2009 CBF125, 1998 GSF600, 2004 FZ6 Fazer, 1978 CB400a Hondamatic
King29
PostPosted: 17:20 - 03 Nov 2017    Post subject: Reply with quote
Yes thank you all, I plugged it direct in a standalone socket and upstairs and downstairs and it works great. So thank you all, PC world bod told me to plug into power surge as it would stop your PC blowing up in the case of a surge down the cat 5 cable so that is why I did that.
What does he know? nowt by the looks of it. So thanks everyone. Thumbs Up
PostPosted: 17:55 - 03 Nov 2017    Post subject: Reply with quote
King29 wrote:
So thank you all, PC world bod told me...
This oughta be good...
Did not disappoint Laughing Laughing Laughing
King29
PostPosted: 18:14 - 03 Nov 2017    Post subject: Reply with quote
I don't know much about computers. Carp fishing, yes. Computers, no.
Evil Hans
PostPosted: 19:04 - 03 Nov 2017    Post subject: Reply with quote
Fucksake. Do they make this shit up on the spot or do they need to have special training first?
King29
PostPosted: 19:10 - 03 Nov 2017    Post subject: Reply with quote
Sounded believable to me. The signal runs around the electricity ring in your house so I guess it's possible. I know they can be a little bit mendacious as my nan bought a laptop. She wanted something to browse the internet and send emails and ending up spending over £1300 with a quad core blue ray writing beast of a machine with antivirus and office and a years tech support.
ScaredyCat
PostPosted: 19:16 - 03 Nov 2017    Post subject: Reply with quote
It only works if you use a directional ethernet cable.
I also have some audiophile cat5 cable if you need it.
The last post was made 8 years, 286 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 0.68 - MySQL Queries: 13 - Page Size: 129.06 Kb
