| Ted |
 Ted World Chat Champion
| Stalk |
 Stalk Brolly Dolly
| Ted |
| Ted |
| Nobby the Bastard |
| andym |
 andym World Chat Champion
| Rogerborg |
 Rogerborg nimbA
 Posted: 08:30 - 04 Nov 2017 Post subject: |
Do you want to change the seals?
If you don't particularly want to, then take a thin piece of stiff plastic (a sliver of Irn Bru plastic bottle works best) shove it down under the seal, then wiggle it up and down and all the way around.
Bounce the forks, see if it's still leaking.
If it is, then you've wasted 5 minutes less the time it would take to type "Bah, I'm not wasting my time, that will never work, besides even if it did it would just be just a temporary bodge, you get what you pay for, a stitch in time saves nine, loose lips sink ships."
If it works, you can thank stinkwheel for suggesting it. I have, repeatedly, since this has worked for me on multiple forks on multiple bikes. ____________________ Biking is 1/20th as dangerous as horse riding.
| Ted |
| Rogerborg |
 Rogerborg nimbA
 Posted: 10:27 - 04 Nov 2017 Post subject: |
You could have tried the plastic in the time it took you to write that, and to read this, and to reply with why you don't think it'll work. ____________________ Biking is 1/20th as dangerous as horse riding.
| NeverAgain |
 NeverAgain Nova Slayer
| Ted |
| Skudd |
 Skudd Super Spammer
| kramdra |
 kramdra World Chat Champion
| Teflon-Mike |
 Posted: 04:24 - 05 Nov 2017 Post subject: |
The pop bottle scraper 'trick' only works if the seal isn't donald-ducked to start with, and the weep is merely trapped crap under the seal lip.. which has to go some-where, when you wedge pop-bottle plastic into the gap to un-trap it... usually into the oil beneath to scratch the forks and chew the seal some more... it's worth a try, but it's no substitute either for a proper seal replacement nor for cleaning your damn forks from time to time!
Woodscrew trick.... you have to drop the forks to get the new seal in anyway... if not get the old one off, if you dont want to be faffing about trying to cut it... and there's usually a steel washer bedded into the rubber at the top of the seal to make it rather awkward to get a wood-screw into.... often needs a small pilot hole drilling into the seal to give you a chance to get it to grip... and all told likelihood is that it makes the job no 'easier' and gives you a heck of a lot more chances to eff something up and do damage to soft and expensive aluminum, or ding even more expensive hard-chrome plating to chew up any new seals you do get 'in'.
Doing the job 'properly' (on Right-Way-Up-Forks) is no huge hassle... you pull the front axle,drop the wheel and take out a leg at a time, and if you have popped the brake caliper, first its a doddle...
IF there's a 'trick' it's to leave the fork clamped in the yoke, until you have pulled the wheel and axle; THEN you tackle the most awkward bit, which is usually the damper bolt accessed from the bottom of the fork with a long allen key.... Hint... they are usually full of crud cos no-one cleans forks... so clean well first, and use something pokeyto get the crud well out the way before you start trying to wedge allen keys in there.
A 'long' allen key is normally needed to get past the axle boss, which usually means a real allen key, not an allen socket.... and a spanner on the short end of the allen key to give it a bit of extra leverage.... a ball-end allen key wont give best purchase on the allen bolt and under big torque likely to be applied can more easily chew the head... use a plain allen, and make sure its well into the head of the bolt.
With the damper bolt dropped, THEN you can remove the stanchion cap, releasing the tension of the main-spring, which you needed to keep the pressure on the damper rod and stop it turning when you undid the allen bolt....
And then the leg removed from the Yokes and the oil drained and the slider dropped from the stanchion, the oil poured out, saig fighting with the drain screw and risk rounding the head or stripping the head of that.... and with dust cap removed from leg, the upper gubbis ad circlips ga be removed from above the seal, which IF the thing would respond to a woodscrew attack, will probably drop out when you pull the stanchion from the slider anyway! If not, the expensive bit, the hard chomed stachion is out of harms way and can be inspected to see if its dinged, chewed or rusted to cause seals to fail, or good enough to re-use... whilsy you have full access to get the seal out without the tube the way of even seeing rusty circlips holding it in, and gan get at the damg thing with 'apropriate instrument' to get it out... BFORE cleaning up the housing to take a ew one, so that that one has best chance of sealing and not succombing to premature fail either....
All up? As my Granny used to say so often, "Lazy-Man's Way is usually the longest... do it propper....it'll be quicker in the long run"... which given how un-oneruse a fork seal is more often true than not.... do right do once sort of thinking.
Biggest hassle is a long enough allen key for the damper bolt, and propping the bike up so it don't topple whilst you tackle it.. this IS to my mind one of the LEAST scary/difficult/annoying jobs there is on a motorbike! Bit a little patience and a lot of attention to detail and CLEANING is the key. ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| Ted |
| Ted |
| tom_e |
 tom_e Brolly Dolly
| Ted |
| Qyburn |
 Qyburn Renault 5 Driver
| Ted |
| Stalk |
 Stalk Brolly Dolly
| A100man |
 A100man World Chat Champion
 Posted: 22:34 - 05 Nov 2017 Post subject: |
Gaitors.. ____________________ Now: A100, SRX250, XJ598, FZ750, SL1000
| sickpup |
 sickpup Old Timer
| Tankie |
 Tankie Crazy Courier
| Ted |
The last post was made 8 years, 344 days ago. Instead of replying here, would creating a new thread be more useful? |
