1990 Suzuki TS50X fault
tsman
PostPosted: 15:11 - 08 Nov 2017    Post subject: 1990 Suzuki TS50X fault Reply with quote
Hi, new to the forum.
My ts50x starts right up and will idle but going up the road it boggs down a bit and then within 1/4 mile just dies like the ignition has been turned off, then after about 5mins it will start but then do the same again (I recently put a new standard piston and rings in as bike would not start, this did the trick), checked spark plug and that looks dry (the arm is a beige colour), any suggestions please, I'm not technically minded, so if poss, layman's terms lol.... Smile
jaffa90
PostPosted: 17:44 - 08 Nov 2017    Post subject: Reply with quote
As said, give it some fuel, (or less air).
tsman
PostPosted: 15:51 - 09 Nov 2017    Post subject: Re: 1990 Suzuki TS50X fault Reply with quote
Could be loads of things, but my first thoughts would be fuel starvation.
When it cuts out, if you open the barb float bowl drain screw, how much fuel comes out? What's the flow like from the tank to the carb?
Has a good flow to carb from what I can see, Ill check the bowl screw next time I'm on it and it stops, but what you say makes sense, as it starts again, so assume fuel gets back in when stopped for a few minutes and the cycle repeats Smile What would cause starvation like that?
tsman
PostPosted: 14:46 - 20 Nov 2017    Post subject: Found the problem Reply with quote
Thanks to all for pointing me in the right direction.
I double checked flow from tank and it had good flow but this time I let it run for about 10 seconds into a can, it then just stopped, so I repeated this and it did it again. I then turned fuel tap to reserve position and it ran and ran without stopping. Took it for a drive and did not have the previous fault. So looks like the ON position is getting blocked, have ordered a new tap!! Smile Happy days....
The last post was made 8 years, 302 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1 - MySQL Queries: 13 - Page Size: 50.87 Kb
