| A100man |
 A100man World Chat Champion
 Posted: 11:26 - 12 Nov 2017 Post subject: Fuel tank winter condensation ethanol etc.. |
I've been think about this and the fact that many people encourage use of no-ethanol fuel over winter. BUT if ethanol absorbs water(condensation) isn't that a good thing - rather than let it sit at the bottom of a tank.  ____________________ Now: A100, SRX250, XJ598, FZ750, SL1000
| Nobby the Bastard |
| Teflon-Mike |
 Posted: 12:22 - 12 Nov 2017 Post subject: |
Water doesn't make things rust. Rust is iron oxide; so its the oxygen that makes it rust.
The water is essentially just a catalyst; so it's is not so crucial, and as far as the rates of reaction are concerned, other factors such as temperature, concentration and 'agitation' start to become more significant.
In short, I don't think it makes a heck of a lot of odds!
Unless the tank is fibre-glass.... in which case I believe you are best advised to drain for ANY lay-up longer than over-night to avoid the alcohol turning the resin to jelly! ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| Copycat73 |
 Copycat73 World Chat Champion
| Kawasaki Jimbo |
| Courier265 |
This post is not being displayed because it has a low rating (Redundant). Unhide this post / all posts.
 Courier265 World Chat Champion
| Copycat73 |
| Polarbear |
 Polarbear Super Spammer
| ScaredyCat |
 ScaredyCat World Chat Champion
| A100man |
 Posted: 23:53 - 12 Nov 2017 Post subject: |
Hmm. Thanks. Topping up tank to minimise air/condensation possibilities makes sense. I do still feel there's a degree of 'pop' science based angst regards ethanol for rotting out tanks.. ____________________ Now: A100, SRX250, XJ598, FZ750, SL1000
| MCN |
 MCN Super Spammer
| Suntan Sid |
 Posted: 18:25 - 13 Nov 2017 Post subject: |
I left a 20L Jerry can with 10L of 95 unleaded in the open air for 4 years, there was no rust inside the can, after 4 years.
I put the 10L of 4 year old unleaded into a, nearly empty, Rav 4, it ran just fine, with no problems!
Make of that what you will! ____________________ "Everybody needs money, that's why they call it money!"  |
| Copycat73 |
| Kawasaki Jimbo |
| Paulf |
 Paulf Nova Slayer
| A100man |
 Posted: 23:29 - 22 Nov 2017 Post subject: |
| Paulf wrote: | Sorry for the question but do we have ethanol in our petrol. I am on a USA forum and they are paranoid about fuel especially over the winter when they don't ride their bikes. And I do up bike as a hobby and never come across a gunge or poor starting. The bike I doing up at the moment as fuel in that is at least a year old. And it runs ok. Just asking is it really a problem in UK. |
Yep. Between 5% and 10% (E10) .In USA I believe the proportion might even be higher. ____________________ Now: A100, SRX250, XJ598, FZ750, SL1000
| MCN |
 MCN Super Spammer
 Posted: 11:04 - 23 Nov 2017 Post subject: |
| Pete. wrote: |
Must be why all those sunken ships are in such great non-rusted condition. Can't be the water doing it must be all that oxygen at the bottom of the sea.
H2Oooooooooooh dear me..... |
Learn 2 chemistry.
Oxygen is water soluable. In an open system (like the sea), the water will be 100% saturated all the time, corrosion takes place constantly.
In a closed system with a limited quantity of water under a layer of hydrocarbon with little to no oxygen permeability (like the bottom of a tank under the fuel), the initial oxygen will quickly be used up and bound to the steel. Once it's gone, no further corrosion can take place.
There ethanol sitting IS an issue is on older bikes (pre '96-ish) where some of the carb, fuel tap, filter, pump and fuel hose componants can suffer from errosion/degradation. I had a fuel hose physically rot off my enfield and starty pissing petrol all over the floor.
As such, my vfr has been put away for the winter with a brimmed tank with Frosts ethanol protectant additive in it and run for long enough that the treated fuel has run through the carbs. Battery is off and I'm going to clean and push the brake pistons back in this weekend. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Copycat73 |
| Monkeypony |
 Monkeypony World Chat Champion
| Copycat73 |
| iooi |
 iooi Super Spammer
 Posted: 20:54 - 23 Nov 2017 Post subject: |
Personal experience.
My Versys has sat in the garage for 2 years and has less that 1/4 tank of fuel. Still starts and runs fine, once battery is charged.
Tank still fine inside.
Previous to that I had a diversion, that sat in the garage for 3 years. Still started fine.... Just a shame the clutch would not disengage... ____________________ Just because my bike was A DIVVY, does not mean i am...... |
The last post was made 8 years, 295 days ago. Instead of replying here, would creating a new thread be more useful? |
