Re-glassing a mirror
Pete.
PostPosted: 16:58 - 11 Nov 2017    Post subject: Re-glassing a mirror Reply with quote
I broke a mirror on my BMW and they are bloody expensive, so I had a go at making a new glass. I'd previously tried this with limited success but now being older, wiser and having better toys to play with I gave it a shot and it did turn out well.
So take one convex mirror. Cheapest I could find was this on special down the local parts place.
https://www.dropbox.com/s/8hcyqvoow0lz84p/mirror1.jpg?raw=1
Drew around the broken glass as best I could.
https://www.dropbox.com/s/iwuvd0hcqrtfkz1/mirror2.jpg?raw=1
I don't have a glass cutter so I scored it with a diamond dresser and broke bits off with a small spanner. I took care not to span across the curve too much or it would be liable to crack in an unexpected direction.
https://www.dropbox.com/s/d9wj2ap4zn6rzck/mirror3.jpg?raw=1
https://www.dropbox.com/s/psu36r8n1b5dl81/mirror4.jpg?raw=1
Ground the edges on a diamond grinder I made for a different purpose. You can use a sanding block for this but it would take longer.
https://www.dropbox.com/s/hzge910j0m9gkdg/mirror5.jpg?raw=1
Finished glass alongside the original
https://www.dropbox.com/s/m5pv8xg6r6l4p1y/mirror6.jpg?raw=1
Here's the secret to re-fitting the glass. Boil the plastic housing in a saucepan. It doesn't harm the plastic but it does burn your fingers if you're not careful. I used tig welding gloves so I could handle it easily.
https://www.dropbox.com/s/te4d6a4whbvqc29/mirror7.jpg?raw=1
Once the housing is that hot it expands a HUGE amount, but it does shrink fast as it cools. Just drop the glass in and let it cool. Glass is now a nice fit and it doesn't move or rattle.
https://www.dropbox.com/s/x26w8u605n5px63/mirror8.jpg?raw=1
a.k.a 'Geri'
Kawasaki Jimbo
PostPosted: 17:14 - 11 Nov 2017    Post subject: Re: Re-glassing a mirror Reply with quote
Nice work! But I did find this bit amusing,
Pete. wrote:
-now being older, wiser and having better toys to play with... I broke bits off with a small spanner.
Pete.
PostPosted: 17:21 - 11 Nov 2017    Post subject: Reply with quote
If you don't have a small spanner you could take your convex mirror to a glazing shop and pay them a few quid to cut it to shape Smile
a.k.a 'Geri'
dydey90
PostPosted: 18:35 - 11 Nov 2017    Post subject: Reply with quote
I'd have thought you could buy replacement glass? Both wing mirrors have separately dropped off my Astra and found cheap glass on Amazon for around a fiver.
MCN
PostPosted: 19:29 - 11 Nov 2017    Post subject: Reply with quote
So.. On reflection, would you try this task any other way?
PostPosted: 19:51 - 11 Nov 2017    Post subject: Reply with quote
I can't see myself doing this.
c_dug
PostPosted: 20:05 - 11 Nov 2017    Post subject: Reply with quote
Cracking job Thumbs Up
I actually have a box of glass cutters, remind me next time we cross paths and I'll dig one out for you, surprisingly useful things to have about the place.
kramdra
PostPosted: 12:16 - 12 Nov 2017    Post subject: Reply with quote
Good job but Id avoid grinding glass, dont want to breath in sillica dust too much...
Mirrors are cheap, couple quid on ebay for a cbr6. None that fit?
Thanks for the boiling trick I want to get the glass off mine and add a heater to the back.
Hahadumball
PostPosted: 15:04 - 13 Nov 2017    Post subject: Reply with quote
i just selotaped a shaving mirror to my old divvy... that eventually fell off when it got wet so i cut the stalk off another mirror and cable tied that mirror to the mirror... worked goodly Very Happy
Fin: no matter how much I look at It I can't understand what was going through my head, all I remember is going about 80 and redlining it to stop it seizing.
360 Deg... Five 1/4 turns. :- Teflon-Mike 18 Jan 2015
PostPosted: 15:41 - 13 Nov 2017    Post subject: Reply with quote
you seem to have a way of fixing or making anything Cool Top job.
Pete.
PostPosted: 20:51 - 13 Nov 2017    Post subject: Reply with quote
27 years concrete cutting and demolition I think that ship has long sailed Smile
a.k.a 'Geri'
The last post was made 8 years, 337 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1 - MySQL Queries: 13 - Page Size: 72.44 Kb
