Finally I can Update my signature! Pic Heavy lower down!
Bike Chat Forums Index -> General Bike Chat Goto page 1, 2, 3, 4, 5, 6, 7  Next
NutsyUk
PostPosted: 19:30 - 20 Nov 2017    Post subject: Finally I can Update my signature! Pic Heavy lower down! Reply with quote
Well finally... I have a real bike Very Happy
Really really really chuffed with it...
Kawasaki ER6F 2007 model no ABS...
Sure its no super sports I wont be winning any GP races, but its a real solid reliable well running, reasonably powered motorcycle Very Happy weeeeeeeeeeee...
Needs a tinsy bit of work done though... The tank needs repainting as the paints cracked all over and there's a crack in the fairing that I could repair, and it looks like one of the seals on the forks may have leaked. Even though it did just recently past the MOT.
But I paid 1300 for this, and ER6 bikes look like they tend to go for 2000-2500 normally when in perfect condition.
Now I just need to get my full license sorted and insurance for it (scared what it could be...)
Tomorrow I have my theory to do and then I can book the direct access... CamRiders are doing a 2 for 1 offer on the courses. So me and brother are doing it together for essentially half price... I think theirs about 2 weeks waiting for the course... But hopefully if all goes well, I might even be riding this before my renewal on the Lexmoto insurance comes up on the 18th December. Sadly i will have to at least tax the thing ... booo...
Anyway YAY I can see light at the end of the CBT shitemoto(lex) tunnel...
Yamaha FZ8/Fazer800 (split headlight one) 2014, gingerly getting used to the massive increase in HP and not killing myself in the process! That was easy to get used to.
Kawasaki ER6F 2007 650 Gonna sell as a project bike!
Lexmoto XTR S 125 Sold!
PostPosted: 19:39 - 20 Nov 2017    Post subject: Reply with quote
Cool stuff but disabling signatures makes BCF so much better (especially if using your phone) because you don't get the walls of often multi coloured text. Thumbs Up
PostPosted: 19:49 - 20 Nov 2017    Post subject: Reply with quote
An ER6 is a lot sportier than it's apparent marketing target would have you think. There are several design features you wouldn't expect to find on a mid range commuter bike such as a vertically stacked engine, casette gearbox and that slightly oddball shock arrangement.
They are pretty damned quick round a track in the hands of a skilled rider.
NutsyUk
PostPosted: 20:19 - 20 Nov 2017    Post subject: Reply with quote
Oh Add possible new bearings to the list as well... Its shockingly hard to push the bike... Its rather stiff
PostPosted: 20:22 - 20 Nov 2017    Post subject: Reply with quote
More likely to be binding brakes.
andym
PostPosted: 20:25 - 20 Nov 2017    Post subject: Reply with quote
And the easiest way I found to test that was to remove the brake calipers and try moving the bike.... 1 caliper at a time to find the problem one
NutsyUk
PostPosted: 20:31 - 20 Nov 2017    Post subject: Reply with quote
Thanks for the tip, also its no rush they could last another year no problem but the disks are a little worn too... that might be a sign of binding... will look into it more... Sadly dont do much tomorrow as im out in town for the test but Wednesday could look into that more...
One thing that i noticed thats a little odd... (design thing not fault or anything) is the running light. So turn on the bike theres a very dim running light in the headlights...
There are NO controls for the low beam lights at all... Turn engine on the Low beams turn on all the time. The only control I have is for high beam.
I know running lights are a thing but I thought running lights were meant to be low level lighting? Not just the full low angle beam?
PostPosted: 21:51 - 20 Nov 2017    Post subject: Reply with quote
That was normal by then and is mandatory now.
Falco
PostPosted: 23:22 - 20 Nov 2017    Post subject: Reply with quote
Don't be fooled by the ER6. I did my DAS on one and a bit they have more power than can be sensibly used, especially by a new rider. I found it a bit too eager to throw me through walls and the back of cars Razz
You'll beat almost every car and a fair few bikes off the line if are so inclined. They are surprisingly nimble and pretty light. Only real downside is the lack of centre stand (none of the ones I rode had one). Right pain for servicing.
No ABS and learning to ride in the dead of winter? Good man Thumbs Up
I tell you what, mathematically, I'm having it
NJD
PostPosted: 23:41 - 20 Nov 2017    Post subject: Reply with quote
NutsyUk wrote:
. . . im out in town for the test but Wednesday . . .
Your bike test? Shocked
Same on mine: Kwak ZR7S 04.
I went form an Arrow 14 to the above. Overall it's a god send more than it is a pain: it's one less switch to faff around with. It also removes the excuse I didn't see him if you potato.
NutsyUk wrote:
pushing problems
Could just be the increase in weight. I wouldn't be a spanner, get the tools out and have a look. Manuals are easily available through google "__ PDF" or manualslib -- for most models, anyhow.
NutsyUk
PostPosted: 23:49 - 20 Nov 2017    Post subject: Reply with quote
NutsyUk wrote:
pushing problems
Theory test tomorrow :p
And yeah i think the brakes are binding a littl... can hear them rubbing when i was pushing it a little earlier...
Dave70
PostPosted: 00:27 - 21 Nov 2017    Post subject: Reply with quote
If you intend to insure it on a provisional licence, I'll save you some time as only bikesure will do this and TPO only unless you have a garage. They'll also rape you for the privilege. Sad
The good news is, your premium will drop significantly when you're fully licensed.
It's a great bike tbh and has plenty of oomph until around 110 MPH, apparently Shifty Riding in 1st and 2nd gears can be a little interesting but 3rd and upwards make for much smoother throttle response.
Good luck with your tests Thumbs Up
NJD
PostPosted: 00:29 - 21 Nov 2017    Post subject: Reply with quote
Probably invest in a battery charger, put the bike on paddock stands and fill the tank since it wont be moving anytime soon.
ACF-50 and an all round service on the cards, might as well make use of the spare time you'll have.
I wouldn't leave anything to chance: everything I've took of mine -- consumable -- in the year I've had it has seen better days.
wots
PostPosted: 08:57 - 21 Nov 2017    Post subject: Reply with quote
Replace the wheel bearings, replace the wheel bearings, replace the wheel bearings!
Not expensive, but this bike can munch them and suddenly eject them all on a rideout. BCF Hastings one year to be precise.
As others have mentioned, it will likely be the brakes binding, wheel bearings don't really make it stiff, just incredibly grumbly. Those tokico 2 pot sliding calipers on the front are awful, they do need to be looked after.
It's not the most reliable, but it isn't unreliable. Watch out for water leaking into the coil packs, causes the band to rust and expand. Take them out (you are checking the plugs anyway?), make sure they haven't rusted and perhaps but a bit of WD40 around the metal band when you put them back in.
Exhaust manifold, can and will snap just before the collector. Check now to see if there are some dodgy welds, that is even worse.
Don't bother swapping the exhaust, all though it saves weight they are MUCH louder and not in a good way either.
It was my first big bike, picked it up in the snow, only just got rid of it after 4 years.
PostPosted: 09:37 - 21 Nov 2017    Post subject: Reply with quote
I can't fathom this obsession with buying before you're licensed, but here we are.
Don't forget to SORN it immediately, or else DVLA's collections goons will be sending you a blackmail demand.
https://www.gov.uk/make-a-sorn
grr666
PostPosted: 09:55 - 21 Nov 2017    Post subject: Reply with quote
It's a young people thing. Personally I'm the kind of guy who eats the cake first, then the cherry.
NutsyUk
PostPosted: 10:13 - 21 Nov 2017    Post subject: Reply with quote
I did it because of timing. I really REALLY dont want to renew the lexmotos insurance... if theres any chance I can get all this done before the 18th im taking it...
And yeah Ill be sorning as soon as the full v5 comes in...
B0ndy
PostPosted: 10:18 - 21 Nov 2017    Post subject: Reply with quote
Pics or gtfo
CBF 125 -> CB400SF -> GSX600F -> ZX6R (G1) -> GSXR1000 K4 -> ZX6R (B1H Stunt bike) -> VFR800 -> R1 5PW -> Sprint 1050 -> Fireblade 929 -> ZX10R C2H -> GSXR1000 K3
PostPosted: 11:35 - 21 Nov 2017    Post subject: Reply with quote
You can and should SORN using the number on the new keeper slip. It takes about tree minutes fiddy all in.
NJD
PostPosted: 12:53 - 21 Nov 2017    Post subject: Reply with quote
The question answers itself: his previous bike was an XTRS (as you now, I presume, a model known for being a friday fried potato).
I can share the pain, all the while not seeing it as a good investment, simply because another year on the Arrow would have sent me loopy.
Oh, OP.. You can do my A test if you want. Thumbs Up
PostPosted: 13:00 - 21 Nov 2017    Post subject: Reply with quote
I'm sure you can. Razz
AshWebster
PostPosted: 14:34 - 21 Nov 2017    Post subject: Reply with quote
Speaking from experience, you're just putting added pressure on yourself to pass the tests - and thats exactly what you need to be trying to ride without! The waiting lists for both Mods tend to be around 2-4 weeks also..
good luck however!
Honda cg125 J reg peice of shit ---> CB650F ---> 2016 CBR600RR
Ford KA ---> 93' MR2 ---> 94'MR2 ---> 98' Subaru WRX STI Ver 3 (track car)
NutsyUk
PostPosted: 14:57 - 21 Nov 2017    Post subject: Reply with quote
Passed my theory Very Happy
Just got to hope my brother passes his theory this afternoon, then we can book the direct access.
I must admit there was a couple of questions that had me a little stumped but I still ended up with 48 out of 50.
In the hazard I got 60 out of 75... With one question being discounted... Stupid really it was a video with a constantly increasing hazard and i kept ticking as it increased... And when your about to have a crash i ticked a few times too and it was discounted... which was a bit shit.
Still a decent pass though Smile weeeeeeeee
NutsyUk
PostPosted: 14:59 - 21 Nov 2017    Post subject: Reply with quote
I would have but the guy said to wait for the main v5 because If i did it before DVLA get there paper work in the post the SORN would be reset when they do my paperwork... If thats no the case and I can use the transfer slip v5c? thing Then yeah ill do that now.
Oh and as for pics of the bike... Ill do it tomorrow... Brother and dad are heading off to town to do his test. And its going to be getting dark here soon... Ill get it out tomorrow for you lot take a couple of decentish pics
NutsyUk
PostPosted: 15:37 - 22 Nov 2017    Post subject: Reply with quote
Ok here are some pics and a few questions....
https://i.imgur.com/84IAYNB.jpg
https://i.imgur.com/JHr9tk7.jpg
Having another look the brakes arent as bad as I first thought. There is about a 1mm wedge in from the outer rim. Ive tried to capture it in pictures but its not easy...
https://i.imgur.com/KOcYYIK.jpg
https://i.imgur.com/0PYHniY.jpg
The back sprockets a bit rough looking. Im sure its fine but its going to be a future replacement Smile
https://i.imgur.com/NLILt1z.jpg
Not sure how this happened to the radiator... Will try and straighten that, and probably fit a grill for it.
https://i.imgur.com/jYOEp3R.jpg
And yes the tank............ yes.......
It looks like the previous owner must have touched up with some unsuitable spray paint and this happened. Its not even black metallic like the original... nor glossy.
The dealership gave me second tank they had lying around. Has some rust issues down the bottom but looks better... Will see how far the rust goes but might repair that then place onto the bike... while i repaint the original tank
https://i.imgur.com/AG6CLrE.jpg
Leaky seals and some rust on the fork chrome... The rust is futher up so its not terribly urgent. But another replace down the line, must fix the leaky seal though...
https://i.imgur.com/Sf8J9Ul.jpg
Some scrappy bits of nothing in the under seat box. Kinda hoped to find basic tools :p Nope...
https://i.imgur.com/YkdK9YP.jpg
WTF IS THAT?!
Tbh my guess is its some kind of auto chain oiler? Its certainly after market. The zip ties dont even match...
https://i.imgur.com/JKuB1un.jpg
Not shown in the pictures are the handle bars that are bent and need replacing...
Nor did i take a picture of the crack in the fairing... but thats no big issue. Easy repair.
Top priority is replacing handlebar, I might also change the style of bar, not keen on the possession of the ones that are on there. Totally wrong angle...
Then fork seals, that has to be fixed.
Then brakes binding. While it rides fine, its a bitch to push. I do need to get used to the heavier weight (its not light) but it is a right bitch to push...
The brake disks themselves could probably go for another 6 months to a year maybe... So no desperate need to replace them. Im not flush with cash esp after buying this so no unnecessary costs...
The chrome forks again. Could go on for a while yet. The corrosion is more further up the tube than in the important areas. And theyre shockingly expensive to buy new too...
Now one last thing... How does one lower the bike a little? Not by much just an inch maybe... I can get both feet flat on the ground but esp with the brakes binding a little its really REALLY hard to move the bike while sitting on it.
While sure it needs a little work I still think I got a good bike for 1300... Feel free to tell me im wrong Very Happy
The last post was made 8 years, 289 days ago. Instead of replying here, would creating a new thread be more useful?
Page 1 of 7
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.15 Sec - Server Load: 0.35 - MySQL Queries: 16 - Page Size: 148.6 Kb
