Noisy Mito
overdog
PostPosted: 15:40 - 13 Mar 2005    Post subject: Noisy Mito Reply with quote
Just rebuilt a mates Mito after she left it standing for 2 years without even starting the thing-I know, I know!
Anyway-disconnected the coil and turned it over on the starter to get the oil pressure up before i fired it up.
There was a horrible clanking noise from the top end.It runs fine but theres a top end noise at tickover increasing with revs.If you spin the motor with the kill switch off the top end clank is still there.
Surely this isnt normal for a 2 stroke? Shocked
Im thinking rings-please tell me Im wrong!
Ooooh-thats gonna leave a scar!
cagiva gezzer
PostPosted: 15:48 - 13 Mar 2005    Post subject: Reply with quote
Ignoring the oil pressure bit..
Umm, cagiva engines are noisy. There's a vast selection of gears driven by the primary drive and clutch basket. So, a rattle from under the clutch cover is normal.
Top end rattle suggests a warm small end or piston slap.
What exactly did you 'rebuild' or change. OE parts, pattern parts?
overdog
PostPosted: 17:13 - 13 Mar 2005    Post subject: Reply with quote
LOL-All I did was strip and clean the carb and put all the b"%^$£d bodywork and tank back on-the mechanicals havent been touched.
Oil pressure light goes out when the bikes in gear.
cagiva gezzer
PostPosted: 17:49 - 13 Mar 2005    Post subject: Reply with quote
Stop with the darn oil pressure.
overdog
PostPosted: 18:01 - 13 Mar 2005    Post subject: Reply with quote
Now its getting louder the warmer the engine gets-its killed a ring hasnt it?
cagiva gezzer
PostPosted: 19:00 - 13 Mar 2005    Post subject: Reply with quote
Doubt it would run with knackered rings.
How many km's? Had a rebuild? Pistron slap should lessen as the engine warms up.
simon1221
PostPosted: 21:45 - 13 Mar 2005    Post subject: Reply with quote
What about the powervalve?
Is it possible he could have dislodged it and its whacking that.
Or, you have a hole in your air intake, carb/manifold hose and that noise is just the engine.
Check stuff like exhaust or whatever for leaks.
You cant have changed anything unless you didnt put the carb back on properly.
Another possibility is that it has nothing to do with you rebuilding it, but maybe the oil pump isnt owrking or something like that.
Is the noise like a rattle or a BANG!?
overdog
PostPosted: 23:11 - 13 Mar 2005    Post subject: Reply with quote
Powervalve does what its supposed to when you turn the ignition on.Noise is a rattling bang!If its been stood for 2 years whats the likihood fo a ring being seized and breaking when I started it?Or is the powervalve more likely(I hadnt even thought of that!)
It does sound like the piston is smacking something-I dont think its just slap.Bike has done 6000-not regularly serviced from what I can gather.
I dont want to condemn the wretched thing if it can be easily fixed but I was raised on inline fours and 2 strokes work by black magic as far as Im concerned-and it does sound fairly terminal.
Closest noise i can compare it to is a piston clattering a valve at the top of the stroke but obviously thats not the case here.
Rings catching the port edge? Brick Wall
Frost
PostPosted: 06:40 - 14 Mar 2005    Post subject: Reply with quote
Ring catching the port edge is very unlikely. Ring catching the powervavle sticking out of the port...very likely. I've had that one ahppen with 3 valves now Laughing
Check the spark plug. You probably put a new one it before fireing it up. If the plug is too long the cylinder might be hitting it...
2 Stroke singles are so easy to strip down it might be worth having a look inside, all it will cost you is a head gasket.
Check bolts too i was once VERY concerned about a loud engine noise which happend at engine speed. Turned out to be a loose powervalve cover Embarassed
PostPosted: 08:41 - 14 Mar 2005    Post subject: Reply with quote
The Mito is a 2 stroke. It has no high pressure oil system and no oil pressure warning light. The light is just to indicate the level of the 2 stroke oil.
Most likely the piston is worn or the rings are siezed. Also the power valve on the Mito has an adjustable stop position. Get this wrong (or just take it out, clean it and reassemble without replacing the gasket so it is more compressed than it should be) and it can touch the piston when it gets hot. If it is run for a while in this condition the shaft for the power valve blade snaps and then the valve drops down.
The last post was made 21 years, 250 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.04 Sec - Server Load: 1.09 - MySQL Queries: 13 - Page Size: 65.01 Kb
