| eNtak |
 eNtak Two Stroke Sniffer
 Posted: 13:18 - 22 Nov 2017 Post subject: Yamaha YBR 125 Carburettor |
I have recently acquired a Yamaha YBR 125 2007 Carb version, I have pulled the carb and can see that it has MIKUNI on it and looks relatively old. The carb has a Deicer on it.
Am i right in thinking this is a MUKINI VM22 carb ? I am unsure of what carb comes stock with the carb version of the ybr 125.
Does anyone have any ideas ?  |
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 14:12 - 22 Nov 2017 Post subject: |
Yamaha normally fitted Mikuni carbs....
Err. why does it look 'old' the bike is a decade old! And they weren't going to change something that worked, just to make it 'look' more modern, when carburettors were going to be rendered obsolete by emmision controls that begged fuel injection, were they? Especially on what was almost thier cheapest product!!
Most important question though... WHY did yo take it off?
If it aint broke don't fix it! If it is broke, tackle the job from the top, and start with the simple and easy.... the carburettor is about the most intricate bit of a motorbike engine, unless you have VERY good reason to fiddle, leave the effn thing alone!
If the bike has 'problems', the carburettor is often the fist thing pulled off and cocked up.. when it is so often almost the last thing to cause trouble!
If it dont start too well... check the battery! Check the solenoid! Check the starter! Check the compression! Check the tappets! Check the spark plug! Check the exhaust for a potatoe up ts chuff!!! If it dont run too well... see above!
Carburettors, are basically a tube in a jam-jar. They are pre-set for almost everythig at the factory, and dont easily wear out, certainly not like valve-guides, tappets, cam lobes, drive chains or clutch plates.
About the only real problem they ca have is being left unused, when the float needle may go a lttle sticky, and fuel may evaporate leaving a crust of petrol salts in the pipes.... and unless its been allowed to get very bad, and you can get the engie to run, the best way to 'wash' them and 'unstick' float needle, is to fill th thing with fresh petrol and give it a darn good long hard run to flush it through the pipes.
"Oh, you should clean the carburettor!" as first course of action for any percieved problem from the exhaust billowing black smoke to having a flat tyre is the bain of motorcycle mechanics! It really is.... SO many MAKE more problems than they ever solve 'fiddling' with the dang things, fiddling with the mixture screw, taking them off, taking them apart, loosing the needle retaning clip, putting them back on with old, hard flattened gaskets, etc etc etc....
UNLESS you have DAMN good reason to take the carburettor off, LEAVE the effing thing alone until you have!!! ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| P.addy |
 P.addy Red Rocket
| eNtak |
 Posted: 15:21 - 22 Nov 2017 Post subject: |
| Teflon-Mike wrote: | Yamaha normally fitted Mikuni carbs....
UNLESS you have DAMN good reason to take the carburettor off, LEAVE the effing thing alone until you have!!! |
I get it "LEAVE the effing thing alone".
I know not to mess with the carb unless it is needed..... i'm not stupid as that seems to be how you have come across?? Talking as if I am some total noob to the scene, I didn't ask for the history of the YBR "the bike is a decade old!" nor it's production cost "almost their cheapest product!!"
When I mentions that it was old I was talking the the terms of dirt, grime, oxidisation, been sat for a while with fuel in....that kind of old.
The carb needs rebuilding and that is why I ask the question "Am I right in thinking this is a MIKUNI VM22 carb?" If im honest I was expect a reply with "Yeah that a Mukini VM22" or something along those lines...not life lessons on how to work with carbs or how to troubleshoot a non starting engine.
Yes the carb will have oxidisation "the bike is a decade old!" I simply asked if any nice person on this forum could provide the model number for the carb so I can order a rebuild kit  |
| eNtak |
| P.addy |
 P.addy Red Rocket
The last post was made 8 years, 293 days ago. Instead of replying here, would creating a new thread be more useful? |
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.48 - MySQL Queries: 13 - Page Size: 54.64 Kb
