| TomC |
 TomC Trackday Trickster
 Posted: 17:49 - 13 Mar 2005 Post subject: Rethreading screw holes |
Ok, well I have a knackered screw thread in my engine casing Basically It needs to be retaped. Whats the best place to get something to do this from and what am I looking for? and also how do I identify the the thread that I need?
Is it going to be possible to use the current stud or am I somehow going to have to find a larger threaded one?
Thanks. |
| overdog |
 overdog L Plate Warrior
| TomC |
| cagiva gezzer |
 Posted: 18:58 - 13 Mar 2005 Post subject: |
https://www.emhart.com/products/helicoil/images/heli123.gif
Drill - Drill out the damaged threads using the drill size specified in the catalog. Drill to sufficient depth to accommodate the insert length and bolt or screw being used. Tap - Use the Heil-Coil Tap specified in the catalog. Check the size on your shank to make sure you have the right one. Tap the hole to sufficient depth to accommodate the insert length and bolt or screw being used.
Install - Use the specified installation tool. Just wind the insert into the hole until the top coil is 1/4-1/2 turn into the tapped thread.
Note: Remove tang with the appropriate tool specified.
All you need to know about helicoil kits ____________________ "because one stroke isnt enough and four strokes waste two" |
| overdog |
| TomC |
| Guest |
 Guest Brolly Dolly
 Posted: 19:12 - 13 Mar 2005 Post subject: |
What bike and screw hole is it, then we might be able to tell you the size  |
| TomC |
| TomC |
| NickD |
 NickD World Chat Champion
| TomC |
| cagiva gezzer |
| TomC |
| cagiva gezzer |
| TomC |
| cagiva gezzer |
| TomC |
| Big Pete |
 Big Pete Spanner Monkey
| TomC |
The last post was made 21 years, 205 days ago. Instead of replying here, would creating a new thread be more useful? |
