Aprilia RS50 gear selector shaft spins 360°
LewisM
PostPosted: 14:46 - 27 Nov 2017    Post subject: Aprilia RS50 gear selector shaft spins 360° Reply with quote
This morning as i was trying to bump start my bike i hopped on and shifted in to neutral from 2nd. The bike went in to neutral and i pushed it round for my 4th attempt to bump start. Went to shift in to 2nd with clutch pushed in and the leaver just spun about 45 degrees. I stopped and investigated as i could but was late for work and saw that the shifter rod is just spinning all the way around. Any suggestions for whats gone wrong as i only understand plant vehicles. Not little gearboxes on a bike Sad . Thanks
barrkel
PostPosted: 17:17 - 27 Nov 2017    Post subject: Reply with quote
The gear lever works ultimately by rotating a shift drum in a ratchet fashion. The shift drum in turn has grooves in it that control the movements of selector forks, which in turn move gears around causing gears to lock via dogs and slots.
This picture has the shift drum on the right hand side, and shows the selector forks between the drum and the gears: https://i.stack.imgur.com/kEG5S.jpg
Sounds like the ratchet mechanism is broken or disconnected somehow. I expect that would need splitting the engine to fix, but I don't know for sure.
Nobby the Bastard
Harley Gaydar
PostPosted: 19:41 - 27 Nov 2017    Post subject: Reply with quote
Or it could simply be because the bolt that holds the lever on has come loose
Triumph Sprint ST 1050
LewisM
PostPosted: 23:12 - 27 Nov 2017    Post subject: Reply with quote
After taking a closer look in the light i realised only the selector was worn. After dismantling it i saw that the teeth inside were worn to bits hence the slipping. I will be ordering a new selector in the morning. Thank you very much for the help!
The last post was made 8 years, 287 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.25 - MySQL Queries: 13 - Page Size: 39 Kb
