Held Score 3.0
daverave999
PostPosted: 16:14 - 28 Nov 2017    Post subject: Held Score 3.0 Reply with quote
Anyone got a pair of Held Score 3.0? How warm are they? Any other thoughts?
They seem relatively new so barely any reviews around!
2007 Versys 650 2001 Yamaha XJ600S Diversion
HT: Imagine a bike......A bike designed by way of crude polls, assembled by cretins using the finest hammers that Lidl had on offer.
daverave999
PostPosted: 16:35 - 28 Nov 2017    Post subject: Reply with quote
Bodyguard wrote:
You could get a set of heated grips + muffs and a pair of summer gloves for what they cost. Wink
I've got heated grips! Not sure about muffs, and I'm interested in these as they do a long finger version.
I love my Air N Dry just they aren't warm enough in sub-5°C rain on the motorway...
PostPosted: 16:50 - 28 Nov 2017    Post subject: Reply with quote
I am.
If you want to be warm and dry, you need muffs. I own 3 pairs which cost £40 (new), £9.50 (new), and £7 delivered (used). They all let me ride in summer gloves with the heated grips turned down or off.
If you want to spend... huh, 20 times as much in order to still be chilly, that's the price of looking like the coolest biker on the block. Literally.
daverave999
PostPosted: 17:03 - 28 Nov 2017    Post subject: Reply with quote
Fair enough Roger.
Are the Tucano Urbano still the ones everyone loves, or have you gone with generic ones? Assuming generic given the price point?
PostPosted: 19:42 - 28 Nov 2017    Post subject: Reply with quote
Yup, Tucano neoprene boxing glove style ones on the Enfield; BitzForBikes on the Tractor; and generic fuzzymuffs on the racebike since the fairing means that it's not as important to get a good seal at the inner opening.
The Tucanos are the best designed and made, but they all work at keeping the windchill and rain away from your hands.
kgm
PostPosted: 20:56 - 28 Nov 2017    Post subject: Reply with quote
Muffs are great. Really great, and well worth the crap looks.
I use Tucano Urbano. I have a set of the neoprene ones and a set of the bigger more solid ones. Both are equally protective but I prefer the neoprene ones as they're less clunky. Working the controls through the neoprene thumb is a non issue on my bikes.
SteveSmith
PostPosted: 14:49 - 29 Nov 2017    Post subject: Reply with quote
I've always shied away from muffs because I'm worried that they would make it difficult to take my hands off the bar if I want to. Obviously in the worst case of a crash I don't want to be attached to the bike, but I'm thinking more if I want to open my visor, wave to someone, scratch my nose or whatever.
Is that an issue, or am I worrying over nothing?
PostPosted: 15:00 - 29 Nov 2017    Post subject: Reply with quote
Easy to take off - decent enclosing moths can take a little getting used to for putting your hands back in again, but well worth it and providing you don't take your hands off just before coming to a junction etc, not going to be a problem.
PostPosted: 16:29 - 29 Nov 2017    Post subject: Reply with quote
Less dangerous than trying to work a Rainpal®.
Wonko The Sane
PostPosted: 16:53 - 29 Nov 2017    Post subject: Reply with quote
getting off the bike in a hurry, not an issue, I got punted off from behind a few years ago with muffs on, having been hit from behind the bike was shunted forwards from under me and I thought I'd dropped the clutch and launched it.
They're not a tight fit to your wrist, it's like falling out of a capsizing boat on a lake, it just simply happens.
talkToTheHat
PostPosted: 12:09 - 01 Dec 2017    Post subject: Reply with quote
Muffs. You won't regret it. My jobs for today: 1) take bike in for MOT 2) refit tucano urbano muffs for the winter.
Bandit. does. everything.
kgm
PostPosted: 14:33 - 01 Dec 2017    Post subject: Reply with quote
I take my hands in an out for visor wiping/opening all the time without even thinking about it. After a few rides it's a total non issue. I'm a total convert after using them for the first time last year.
daverave999
PostPosted: 14:32 - 28 Feb 2018    Post subject: Reply with quote
Been a while I know, but I tried fitting the neoprene Tucano muffs and they seemed way too tight to quickly access the brake lever. Enough that it was not something I was going to risk getting used to. Don't know whether it's my big hands or too much armour on my gloves or what.
Are the other type more spacious?
kgm
PostPosted: 15:10 - 28 Feb 2018    Post subject: Reply with quote
The non-neoprene Tucano's are more roomy but I've never had an issue with either type on any of my bikes.The feel odd for the first 10 mins then you forget about them. The only get irritating at speeds higher than I'm really likely to do in winter.
PostPosted: 16:05 - 28 Feb 2018    Post subject: Reply with quote
Are they cutting off the circulation to your hands? Are you giving a lot of "right turn" or "slowing down" signals that require you to take your hands off the bars? Do you need to see the brake lever to operate it? Thinking
You put your hands in, set off, ride with warm hands, stop, then take your hands out. There's no trick to it, and you'll be used to them by the end of your first ride.
daverave999
PostPosted: 16:45 - 28 Feb 2018    Post subject: Reply with quote
No, but access to the brake lever is something I'm quite keen on... It was tight enough that I was concerned I'd be able to actually brake in an emergency.
I guess I hadn't realised how tight they would be. Do they soften/loosen up?
I might have to try the non-neoprene ones if they are looser.
kgm
PostPosted: 16:52 - 28 Feb 2018    Post subject: Reply with quote
Guessing you've put them on your Versys. Have you fitted them around hand guards?
They are fine on my er6 which isn't dramatically different in terms.of levers and switchgear.
daverave999
PostPosted: 17:05 - 28 Feb 2018    Post subject: Reply with quote
Yeah, they're on the Versys. Have you got heated grips?
Are all bar end weights the same size? Just wondering if mine are longer and stretch the muff Shocked wider than intended.
I'll give them another try when I've got chance I guess.
[EDIT] No handguards fitted.
PostPosted: 17:25 - 28 Feb 2018    Post subject: Reply with quote
Ah, right.. Are yours the boxing mitt style ones? Do they have a semi rigid fnar strip that runs inside them in a curve?
Since the cheapo muffs that I use on my Tractor don't have any sort of bar end retention or stiffening... member... to hold them clear of the controls, I remove the RHS bar end and bolt in a piece of wood, pointing forward, that reaches as far as the lever. That keeps the muffs well clear of it.
It's a very nice piece of wood, with some teak oil staining. Adds a bit of character.
The last post was made 8 years, 241 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.17 - MySQL Queries: 13 - Page Size: 119.21 Kb
