oxford hot hands
bigdom86
PostPosted: 11:30 - 11 Dec 2017    Post subject: oxford hot hands Reply with quote
that time of year again when the hands go numb, thinking of giving in and just having muffs but willing to try some heated grips first, anyone used the oxford hot hands type of grip? seem to get good reviews
PostPosted: 11:38 - 11 Dec 2017    Post subject: Reply with quote
They make the grips very thick.
Personally I'd go for the sport grips which are thin and once you have fitted them you can forget about it.
If you go to the effort of fitting the wiring, just fit the proper grips at the same time.
Triumph Trophy Launch Edition
PostPosted: 11:39 - 11 Dec 2017    Post subject: Reply with quote
I still cannot understand why you would not have muffs. Wind and wet is the issue, this keeps absolutely everything off you. Add basic heated grips and you are able to ride without gloves with hands that make you feel like the human torch.
Muffs all day long with a boggo set of heated grips.
colink98
PostPosted: 12:41 - 11 Dec 2017    Post subject: Reply with quote
it can only be a "image" thing.....
its just too much for some people.
Ride it like you stole it.
Qyburn
PostPosted: 13:52 - 11 Dec 2017    Post subject: Reply with quote
Do you find any issues getting your hands in and out, for example in a hurry? I have 1/2 mile of sometimes slippery farm track before the public road and I worry that having my hands in muffs might in some way interfere with keeping things under control.
Lord Qyburn
DrDonnyBrago
PostPosted: 14:34 - 11 Dec 2017    Post subject: Reply with quote
Muffs do slow getting your hands back in down, not much impact on getting them out.
Not sure how taking your hands off the bars will help with keeping a bike under control though.
bigdom86
PostPosted: 14:48 - 11 Dec 2017    Post subject: re Reply with quote
which are the sport grips? I think it is time I change by bike and not really care anymore and just get muffs, although it isn't often both wet and cold in london these days
2Hondas
PostPosted: 14:49 - 11 Dec 2017    Post subject: Reply with quote
I believe I've got a set of those hot hands lying around somewhere.
If I can find them and all the bits then you can have them for postage cost.
They came with my Hornet and I took them straight off and replaced them with some integrated hot grips. They're like wrapping the grips in a thick sock, and feels very odd.
They're also fabric, so if you leave them on your bike and it rains, they get soggy.
Current - 2010 Kawasaki ER-6n - Green
Previous - 2000 Honda CB600F Hornet - Yellow
Previous - 2007 Yamaha YBR125 -Blue
PostPosted: 17:48 - 11 Dec 2017    Post subject: Reply with quote
I had zero issues removing my hands out.
It takes probably 2 rides max to get used to them but trust me, you'll never want to go a winter without them.
Wonko The Sane
PostPosted: 17:54 - 11 Dec 2017    Post subject: Reply with quote
Likewise, they were on my ZZR when I got punted off it, no problem whatsoever.
Taking your hands off quickly in a random motion might cause one of the muffs to come detached from the bar end weight (if they're that type) but if that's happened you're probably in a position to sort it anyway (unless you have a habit of suddenly taking your hands off while on the motorway?)
The only reason I didn't have them on my ZZR the past couple of winters was they fowled the fairing quite badly and rubbed the paint off.
No issues on the Hornet, glad to have them back on. Wouldn't mind a bit more warmth though...
Hahadumball
PostPosted: 19:32 - 11 Dec 2017    Post subject: Reply with quote
cant fit muffs on the vtr :C
i fitted those cheap shitty heat pads and they work surprisingly well with a set of under gloves.
Fin: no matter how much I look at It I can't understand what was going through my head, all I remember is going about 80 and redlining it to stop it seizing.
360 Deg... Five 1/4 turns. :- Teflon-Mike 18 Jan 2015
PostPosted: 09:26 - 12 Dec 2017    Post subject: Reply with quote
Can't or won't? Have them on the GSXR, and my old GSXR...and another GSXR, and a TL. Laughing
Hahadumball
PostPosted: 11:11 - 12 Dec 2017    Post subject: Reply with quote
fairing and tank in the way massively, cant even get near full lock on vtr unless your hands are off the bars
PostPosted: 11:12 - 12 Dec 2017    Post subject: Reply with quote
Soft muffs won't prevent that. Should be fine with a set of tucanos.
kawakid
PostPosted: 12:03 - 12 Dec 2017    Post subject: Reply with quote
I have hot hands on my commuter, which I use with muffs, I find them excellent tbh, absolutely brilliant. The hot hands come off in seconds and for most of the year they are not on.
On my Z, I have fitted proper heated grips, yeah they are thinner, but then they are much more difficult to remove even if needed.
I've a twin and a 4.
SuperMike
PostPosted: 12:39 - 12 Dec 2017    Post subject: Reply with quote
I have a set of oxford heated grips and I would give them a middling review. They are fine when it is a bit nippy outside, but when it approaches or goes under 0 they aren't all that. The problem is that they heat the palm of your hands well, but they don't do anything for the fingers. The result is that you get off your bike with frostbite on half your fingers as opposed to all of them.
I use a pair of Gerbing X12 heated gloves that are wired into my battery. Now those things are like putting your hands into an oven! The top red setting has to be unlocked it is so hot!
If I were doing it all again, I would have left the standard grips on the bike and just got the gloves straight away. They are expensive (£120 from memory), but I have had 3 blissful seasons of winter out of them so well worth the investment in my view. Thinking of also buying the heated undergarments this year too for extra smugness on the commute.
Courier265
PostPosted: 13:06 - 12 Dec 2017    Post subject: Reply with quote
This will help your fingers...
https://www.wemoto.com/parts/picture/sc-2290-83-1109/
Wonko The Sane
PostPosted: 13:49 - 12 Dec 2017    Post subject: Reply with quote
Muffs and heated grips are, I'm told, the answer as you loose the wind chill and the heated grip's heat is retained slightly in the muff so of use even as the temperature drops.
Think I could do with some heated grips for next winter along with my muffs.
evilzed
PostPosted: 14:08 - 12 Dec 2017    Post subject: Reply with quote
I've got Gerbing gloves which are great but too much faff. Muffs + heated grips + silicone lever sleeves did the job for me, the foam sleeves kept tearing eventually. IME lever sleeves make a big difference in finger pain.
SuperMike
PostPosted: 20:32 - 12 Dec 2017    Post subject: Reply with quote
What like plugging in two cables and then putting them on just like your normal gloves sort of faff? What am I missing here?
evilzed
PostPosted: 00:48 - 13 Dec 2017    Post subject: Reply with quote
I don't like keeping the wires in between my jacket liner (as it's not always sub zero temps in London) so have to pull them through the sleeves every time, then be careful not to scratch the tank with the metal wire ends hanging out my jacket when unlocking/wheeling the bike out, followed by connecting them up and trying and stuffing the cuff under my jacket and connecting the controller up then the gloves up etc. Worth it for a long trek otherwise it's a bit much
I prefer the 10 mins to install muffs early winter and the <10 seconds to turn the grips on Thumbs Up
PostPosted: 01:25 - 13 Dec 2017    Post subject: Reply with quote
My heated grips (Triumph OEM) are superb. The barn door fairing helps mind. Only 2 settings but no more really needed.
I put Oxford sports grips on my busa when I was touring Europe on it and had no complaints about their operation.
I hate having wires attaching me to the bike in any form so I won't wear heated gloves.
bigdom86
PostPosted: 10:55 - 13 Dec 2017    Post subject: Reply with quote
thanks for the offer mate, if you find them they would definitely be worth a try! Smile
kawakid
PostPosted: 11:06 - 13 Dec 2017    Post subject: Reply with quote
Thank you.
Until yesterday I had no idea such things existed.
I ride with Turco Urbano Muffs and Hot hands, but when its really cold, I can feel the metal of the levers through my gloves (I ride with summer gloves).
Anyway thanks, i've ordered a pair from ebay.
Weirdly enough I was already planning to wrap my levers in self amalgamating tape.
The last post was made 8 years, 267 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.41 - MySQL Queries: 13 - Page Size: 128.34 Kb
