40w instead of a 35w
minibuck
PostPosted: 21:25 - 11 Dec 2017    Post subject: 40w instead of a 35w Reply with quote
ive got a rieju marathon 125 pro sm it designed for a 35w halogen headlight but i wanted to put a 40w led headlight bulb would i get away with it or not
Courier265
PostPosted: 23:06 - 11 Dec 2017    Post subject: Re: 40w instead of a 35w Reply with quote
Not sure, I'm thinking you could develop a battery issue, I know it's an extra 5 watts but I'm unsure if this bike is designed to handle a higher wattage bulb. Check your manual.
Teflon-Mike
tl;dr
PostPosted: 00:04 - 12 Dec 2017    Post subject: Reply with quote
LED's are 'cold'.
Amps unfortunately are't.
Higher ampage devices like lights are likely to draw more amps through already flakey switch gear and make them and anything els the electric flows through melt...
Actual lamp housng may be quite safe!
OP? 40W LED? Thats a heck of a big current draw, around 4A for something with LED's, that usually, indiviually work on mili-amps.
They are also very directional. And questionable vis the constructor & use regs.
I would be suspicious its actually a 40W LED Array.. that would be HUGE... rather than an LED compound bulb, that has equivalent 'brightness' .... in the editors final opinion.... to a conventional 40W tungsten bulb.
If so, then the 'equivalence' is highly speculative, and a 5w increase, even if it is 'real' pretty negligible, in the scheme of stuff.
Lights are often critasised and targeted for upgrade, but I am very very sanuige about the matter
Rules of the road say ride at speed you can stop in distance you can see to be clear....
Many look beyond the road their lamp lights up, and ride far faster than they can actually see to be clear, peering into the gloom beyond.
Here a brighter lamp, does little more than encourage them to STILL 'over ride' the limits of their lamp. which will likely not light any further up the road... just light the bit they are looking over more brightly.... and go chasing ever more 'watts' of luminosity to alleviate what they 'think' is the problem...
Often far more effectve to simply make the most of what you got; clean the lens! Adjust the beam, slow down and learn to look where you are going properly!
And that's still useful, even if you DO actually make more light, and chuck it usefully further up the road, which usually takes far more than merely a higher wattage lamp bulb, that does little than over load switches, and bring other consequential problems!
HID lights, draw only 35W, properly wired they can chuck out 10 or 20x more actual light, without melting switches or lamp housings.. but still, a dirty lens, a crap or incompatible lamp reflector, bad beam aim, or lens diffraction, can see them no more 'useful'... especially if all they do is encourage rider to ride even faster into the gloom rather than watch properly where they are going.....
Your call, what you do... but I think you have stumbled onto an idea that's not really a solution, to the problem you only 'think' you have.
uberkron
PostPosted: 04:24 - 12 Dec 2017    Post subject: Reply with quote
If you believe it's 40 watts of led that's 4000 lumens.
I'd say it probably draws 2 to 3 amps so probably less than the halogen bulb.
Source. I sell some led bulbs. 95% are grossly over rated.
85% fail after a 12 hour run.
Just use bulbs. They work until they don't and are cheap/legal.
i ride a zip 50 2smoke. It overtakes a hundred times a day.
uberkron
PostPosted: 04:26 - 12 Dec 2017    Post subject: Reply with quote
Not to shit on Tef, but hid need dc, if you wire to battery you'll soon discover the weak charging system. Usually being In the dark with a discharged battery too.
Islander
PostPosted: 10:30 - 12 Dec 2017    Post subject: Reply with quote
Let's get some figures straight for a kickoff.
40W draws 3.3A (40/12 = 3.3), 35W draws 2.9A (35/12 = 2.9) which would lead to a 400mA difference - hardly likely to tax the charging system or burn out any wiring.
If it's an LED bulb then it'll be a 40W equivalent and draw less current than the original filament bulb so not likely to cause any issues.
However, quality can be a problem for cheaper LED units - some are prone to failing, some give poor beam patterns and that's what you need to base your decision on.
PostPosted: 11:10 - 12 Dec 2017    Post subject: Reply with quote
We're assuming this bike has a DC lighting system.
Does it?
Islander
PostPosted: 11:43 - 12 Dec 2017    Post subject: Reply with quote
Yes, it does. Thumbs Up
PostPosted: 12:23 - 12 Dec 2017    Post subject: Reply with quote
That being the case, I'd stick LED stop and tail and instrument panel bulbs in and you ought to free up the extra power to upgrade the headlamp bulb.
Then the question will be if the wiring is sufficiently high spec.
Courier265
PostPosted: 23:29 - 13 Dec 2017    Post subject: Reply with quote
One snag, LED stop and Tail are piss poor, too dim....
WD Forte
PostPosted: 01:04 - 14 Dec 2017    Post subject: Reply with quote
Leds aint 'cold'
Any device using more then 10W will get bloody hot
unless a heatsink is used
I have 5W leds as bench lights that are just grabbable ( technical term)
I have 20W cree security light outside that would do a 125 proud
as a headlamp and it's reliable cos it has a good heat sink
Cheap led Headlamp 'bulbs' without proper heatsinks wont last long.
having said that,
I'd definitely go for led headlamps on a 125 with their limited stator output, but be prepared do to some research and experimenting
If the OPs 40W led is true power not equivalent lumen rating the current difference at a running voltage of 14V is 2,85A Vs 2.5A for a 35W
bikers smell of wee
mudcow007
PostPosted: 02:59 - 14 Dec 2017    Post subject: Reply with quote
The ones fitted to mine seem plenty bright enough?
PostPosted: 09:01 - 14 Dec 2017    Post subject: Reply with quote
They're fine, he's stuck in a 1970s pub with Philip Glenister.
What you do have to watch out for is the difference between steady and stop being significant enough that Dozy Doris behind you realises that you're braking or else you might get breaked.
MCN
PostPosted: 09:20 - 14 Dec 2017    Post subject: Reply with quote
If one buys piss poor LEDs then one gets piss poor LEDs. 😊
Improving stuff can be done cheap but invariably it costs a bit of £ Embarassed
Get your head/arse out of Poundland/The local Asian's market stall and into a proper lamp retailer's.
I have a Fenix LED torch that would probably cause irreversible eye damage and burn your fingers too. I'm not the only person who has proper LEDs. 🤣
As suggested, fit LEDs all around and stick a good quality halogen in the headlamp. Or source a good LED equivalent from a reputable retailer.
It is not Rocket Surgery.
PostPosted: 12:07 - 14 Dec 2017    Post subject: Reply with quote
I think the problem with quite a few is that they are unidirectional. Fine if you are directly behind but off from the side at all they seem very dim.
Obviously got round by the 'festoon' type but they might not fit in a bike light.
Triumph Trophy Launch Edition
Bikeless
PostPosted: 13:01 - 14 Dec 2017    Post subject: Reply with quote
My old gullarm had 35w/35w bulbs in,I bent the tangs back on some H4 55w/60w and fitted them,never had any problems,just saying.
PostPosted: 15:39 - 14 Dec 2017    Post subject: Reply with quote
SMD ones are where it's at.
This type:
https://cdn.shopify.com/s/files/1/1109/5094/products/BAY15D_6V_new_e61c1c72-f920-4ccc-bfb0-e93bd8505b5f_1024x1024.jpg
So bright they can overwhelm the lens tints so I'd recommend self coloured ones (red for tail, orange for flashers etc.).
I use big single LEDs for instrument panel bulbs but again, self colour (green for flasher, blue for hi beam) and if they're too bright, paint the top half of them black.
I've bought them from here before and been happy with the results:
https://www.classiccarleds.co.uk/
cresad
PostPosted: 22:52 - 14 Dec 2017    Post subject: Reply with quote
I'm have a similar problem to you in that I run a Suzuki en125 ( import )
that has a crap headlight. Tried a bigger headlight bulb and ended up having to keep charging the battery up , and that's with an led stop/tail. I've just bought a led headlight unit - https://goo.gl/gE8kBh - Comes complete , smaller draw and should be brighter - havn't trie4d it yet still waiting for it to arrive. There are other types but my bikes got a 7" round headlight already with a small fairing that I didn't want to change.
Going to do the dash bulbs at the same time.
Adam
Courier265
PostPosted: 23:58 - 14 Dec 2017    Post subject: Reply with quote
In other words you bodged it.... I did that once when my bulb blew when I was working. Later on I bought adapters ment for a Citroen 2CV H4 conversion to upgrade permanently using 35W H4.
£8 a pair.. interesting.. Might get a pair, Thank you.
Teflon-Mike
tl;dr
PostPosted: 09:50 - 15 Dec 2017    Post subject: Reply with quote
WD Forte wrote:
Leds aint 'cold'
True, but an LED is't a power drawing device. It's a matter of Symantics. But....
A 'Light-Emmitting-Diode' is just that, a diode. It has zero resistance to current in one direction, infinite resistance to current in the other.
'Tehnically' it draws NO current, on its own. You need a 'load' on an LED to cause a current to pass through it, to get light out of it... The component LED shouldn't get hot, as its not drawing current, or dissipating power, the resistor that's drawing the current through it is, and only that may get hot.
Like I said, its symantics. And the confusion of calling both a component LED and a composite LED array, both LED 'bulbs'.
Well, again to argue symantcs, most High-Intensity-Discharge lamps are a peculiar form of Arc-Light... bit like a spark-plug in a Jam-Jar. To get the electricty to jump from one electrode to another and make the spark that chucks out light, they usually run at inredibly high voltages, and they usually use Alternating-Current, at a very high frequency, provided by a seperate conditioning box containing the electrickery to turn a 12vDC supply from the battery into the Kv-AC supply the actual bulb runs on.
Couple an HID 'system' to a battery? 'Should' run fine.... and in practice, usually does.
I have run an HID off a tiny 3Ah battery... briefly! Or a 4A battery charger, continiousely, before now.
35w draw from an HID circuit is no different to a 35W draw from a conventional tungsten bulb. Charging system shouldn't care whats sucking power from the battery.
Though, IME... HID set-ups are a lot more sensitive to the supply than a tungsten bulb, where, a 12v tungsten bulb will still chuck out some light if the supply voltage falls to perhaps 6 or 7v or less.... wont be a lot... but it will likely still glow!
An HID set-up can 'drop out' and refuse to light if the supply voltage drops benath maybe 10v. You may get no more than a humming noise from the bulb, or they can start to 'machine gun' flicker at around thier preffered threshold voltage, if the battery terminal voltage falls.
Actually seen that most often, when HID lamp comes on with igition, and pressing the starter, doesn't inhibit the lamp circuits, but does cause battery terminal volts to fall beneath what the HID ballast box wants.
SMD merely denotes that they use 'Surface Mount Devices' rather than older fashioned 'through hole' LEDs.
As a indvidual 'component' they are notoriousely more directional than a through hole LED. In an array? Depends on how many there are and the orientation of them.
Ditto, and that's where a lot of the benefit of LED's is to be found.
A tungsten bulb makes white light, comprised of all colours of the rainnbow; the coloured lens infront of one, then filters out and chucks away perhaps two-thirds of the light that the bulb actually makes, to just pass Red or Yellow.
Using lamp-coloured LED's then means you don't make the colours of light you would chuck away with the coloured filter, and provides huge efficency bonus before you begin.
White LED's that make all colours of light to be 'white' are on the back-foot from the off, having to make three times the amount of light to be equally 'bright'.
In a head-lamp that has to be white, you dont have this instant effcency gain to garner.
You also then have the 'niggle' that to get an equal brightness to a tungsten light-bulb, you need a lot of individual LED's working together....
Enter the Inverse-Square-Law. That says light brightness is inversely proportional to the square of the distance between light and what it lights. So, double the distance you get 1/4 the brightness.
Now, a multi LED array, is like trying to luminate a football arena by getting every one in the audience to hold up a cigarette lighter, rather than turning on a single flood lamp.
Cumulatively, the many flames may deliver the same quantity of light, but indvidually, they dont have the same 'penatration' to travel so far.
And the question, ultimately isn't how much light you have, or how bright it is, its "How well can I see?"
And in that, how many watts r lumins, candella or lux you may have, is just a small part, its getting the light out of the lamp, and putting it where it's most useful.
Which is where, if you are in the habbit of 'over-driving' your lamp, looking over the bright spot it lights, into the shaddows beyond, you are onto a looser before you begin.
More watts will make the bright spot brighter, but in 'contrast' that will usually have he result of making the shaddows you are actually looking at seem darker!
Hence, Clean the lens, adjust the aim; learn to properly look where you are going; DONT over-drive the head-lamp. And remember to ride at speed you an stop in the distance you can 'really' see to be clear...
A 'crap' headlamp, is so seldom the 'big' problem in these situations.
In my yoof, little bikes got 6v headlamps, with 25 or 30W bulbs that got brighter and dimmer with the engine revs! Whilst street-lighting wasn't 'usual' especially out in the country-side, of which there was a lot more of!
And headlamp 'upgrades' weren't often even possible, when the generator didn't make the power to light a higher wattage bulb, that starved of amps, was often dimmer, if you even tried it!
They sort of made the lesson to look where you are going and to ride to the speed you can stop, some-what more vital... especially when you only had a 4" single leading shoe drum brake and rather notorious cheng-chit tyres stretching your stopping distances!
Matter of lamp-upgrades, so often these days, is endemic of consumer culture cheque-book engineering, expecting to just 'buy' a ready made cure-all off the shelf, and do no more, and there are a lot of folk happy to take your money .. not so many so happy to simply look properly where they are going to start with!
Islander
PostPosted: 11:25 - 15 Dec 2017    Post subject: Reply with quote
Teflon-Mike wrote:
WD Forte wrote:
Leds aint 'cold'
Wrong wrong wrong.
An LED is a semiconductor, it is a load in its own right. The only use for a series resistor is to limit current through the device, not to act as a load. No semiconductor has zero resistance to current in any direction - the clue is in the name. Also, you have a forward junction voltage determined by the characteristic of the semiconductor p-n junction. For a standard silicon rectifier, this is around 0.6v, for an LED it can be around 2v. Where you get a voltage drop you get heat dissipation so semiconductors do get hot - this is why heatsinks are used.
Ignore Tef's post OP, it's made of uneducated guesswork and wrongness. Rolling Eyes
PostPosted: 11:38 - 15 Dec 2017    Post subject: Reply with quote
You piece of crap troll. LEDs don't draw any power when they emit light. In fact, if you take the resistors out of the circuit, and point the LEDs at a solar panel, you get infinite energy. Folded arms
Islander
PostPosted: 11:44 - 15 Dec 2017    Post subject: Reply with quote
Only if yo' momma is in the circuit. Tut Tut
kramdra
PostPosted: 15:24 - 15 Dec 2017    Post subject: Reply with quote
Chinese ones have a shit heatsink so they fail quickly. If you have one, drill a channel and watercool it. Passive would be adequate, and would then last forever.
www.ebay.co.uk/itm/162246801305
Modify a chinese one to fit two of these...
The last post was made 6 years, 178 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 0.06 - MySQL Queries: 13 - Page Size: 142.51 Kb
