The uselessness of power settings
TheBikerStig
PostPosted: 05:18 - 13 Dec 2017    Post subject: The uselessness of power settings Reply with quote
I just purchase a brand new Verys 1000. I could have just bought something shitty, but thats not my way. My logic is that I hate motoring, so I will minimise my torture by buying something tidy. Its still torture tho....
Anyway I my point is power!! This is controlled by something commonly known as a "throttle". 2 nights ago, as of typing this I had to ride my bike home from work. Side streets were icy as hell. (ironic analogy) Streets were brighter than my new paintwork but I was still in "full power mode". What I done while riding my new bike on icy streets was turn the throttle a very small amount. Combine this with use of the clutch and you can comfortably ride 5 mph all day (about 5 minutes actually, and then you wish you was dead or something).
Anyway what do power settings actually do? I asked the salesman this before I even bought my bike. He said you can get a few extra MPG from using a lower power mode. NO YOU CANT. At least not without felching.
I am usually naked when posting to this forum.
redeem ouzzer
PostPosted: 07:55 - 13 Dec 2017    Post subject: Reply with quote
Don’t post again. It’s like reading something from teffers only with slightly better spelling.
Be a REAL MAN!
TheBikerStig
PostPosted: 07:57 - 13 Dec 2017    Post subject: Reply with quote
To contradict your advice, I will listen to it.
PostPosted: 08:44 - 13 Dec 2017    Post subject: Reply with quote
The Versys is one of the bikes with a Spy Chip "Black Box" in it. By putting it to full power from new you've doubtless voided your warranty. That's owner abuse, that is, not covered. HTH, HAND.
doggone
PostPosted: 09:14 - 13 Dec 2017    Post subject: Reply with quote
I would imagine it's supposed to change the peak torque rpm, like having remapping presets.
PostPosted: 09:56 - 13 Dec 2017    Post subject: Reply with quote
Gearing thread.
Until we have electronomical poppet valves, all that a Power Fiddler can do is to change the fuel mix and (if fully ride by wire) the throttle opening. I'm not sure how that would change where the engine make peak torque, unless it deliberately misfuels at the revs where it would otherwise do so with ideal fuelling.
Hong Kong Phooey
PostPosted: 10:05 - 13 Dec 2017    Post subject: Reply with quote
There'll also be an element of timing retard.
Just to be clear, retard in that context was not an insult, retard.
kgm
PostPosted: 10:24 - 13 Dec 2017    Post subject: Reply with quote
The usefulness depends on the bike. On the Tracer the difference is significant. A mode is nasty with a pillion, despite how careful you are with the throttle it is very abrupt even with slight changes. I expect it would also be trickier in the wet. B mode is much smoother by comparison,, standard is also fine. A mode is awesome solo though.
A and standard are full power, b slightly reduced but it's mainly down to throttle response.
Turn the traction control off and then see if you notice a difference. You may not, some bikes are different to others.
Monkeypony
PostPosted: 10:36 - 13 Dec 2017    Post subject: Reply with quote
I have 3 'engine modes' on the Aprilia, all 3 give full power, they just change the throttle response and engine breaking.
Current bike - 2018 H2-SX, 2004 SV1000s, 2016 Aprilia RSV4 RF, 2017 Sherco SERF 300, 2003 Suzuki DRZ400 (stolen - AY53 JUU)
PostPosted: 10:59 - 13 Dec 2017    Post subject: Reply with quote
How can you change the engine braking?
Triumph Trophy Launch Edition
Monkeypony
PostPosted: 11:22 - 13 Dec 2017    Post subject: Reply with quote
Apparently, the maps give a varying level of positive torque with the throttle shut.
Or witchcraft.
owl
PostPosted: 12:14 - 13 Dec 2017    Post subject: Reply with quote
Or witchcraft.
https://i.imgur.com/iZcUNxH.gifv
Observation is the greatest source of wisdom.
chickenstrip
PostPosted: 12:57 - 13 Dec 2017    Post subject: Reply with quote
I reckon that's probably the best answer, perhaps coupled with the experience of the rider.
My carburetted Fazer is smooth at all revs, in all gears. If I want an even more controlled, or less abrupt, power delivery, I select a higher gear, since it will continue to pull smoothly down to about 2k rpm in top. Therefore, this bike doesn't need power settings. It is, however, limited to a little less than 140rwhp, so its lack of outright power probably helps too.
PostPosted: 13:21 - 13 Dec 2017    Post subject: Reply with quote
OP thinks Alanis Morrisette's Song 'Ironic' Actually is.
PostPosted: 13:35 - 13 Dec 2017    Post subject: Reply with quote
I have a mate with a Tuono V4. Three guys from my club have ridden it. All of them pretty competant club racers.
Apparently the power settings are all that stands between riding an insanely fast motorcycle while barely in control and instadeath by 100mphverticalwheelyburnout. All three of them turned it onto track mode (everything off, full power on demand), rode it about a mile then stopped and turned it all back on again.
Freddyfruitba...
PostPosted: 13:42 - 13 Dec 2017    Post subject: Reply with quote
No, he said engine 'breaking'. Reduced likelihood under low power mode Thumbs Up
PostPosted: 13:44 - 13 Dec 2017    Post subject: Reply with quote
Ah, true. It is an Aprilia Wink
PostPosted: 13:50 - 13 Dec 2017    Post subject: Reply with quote
I have a soft spot for those. I feel like it'd be a bit too much for the road though.
Monkeypony
PostPosted: 13:58 - 13 Dec 2017    Post subject: Reply with quote
They are way, way too much for the road. Just like every other modern litre superbike/super naked.
Fun though Laughing
Mine stays in track mode, but anti wheelie and traction control are a must for the avoidance of death.
secretagentmo...
PostPosted: 14:10 - 13 Dec 2017    Post subject: Reply with quote
It is an Aprilia, engine breaking is the correct term....
PostPosted: 14:40 - 13 Dec 2017    Post subject: Reply with quote
Adding fuel/air on Decelaration.
PostPosted: 14:47 - 13 Dec 2017    Post subject: Reply with quote
Don't they also have variable valve timing?
PostPosted: 15:00 - 13 Dec 2017    Post subject: Reply with quote
Maybe, I've only heard of tweaking the map to add air/fuel on Decel.
A quick check on the Aprilia website doesn't show the Tuona having VVT.
https://www.aprilia.com/en_EN/technology/aprc/
(scroll to the bottom for CAD image of engine .)
Jayy
Mr. Ponzi
PostPosted: 15:03 - 13 Dec 2017    Post subject: Reply with quote
Had a big bang R1 with a couple different modes.... didn't appear to really do anything.
1299 definitely had the fanciest shit I ever seen with the electronics package on it and you could tell the lesser modes dulled the throttle and ramped all the aides up.
RSV4 RF... don't feel much difference between the modes. The modes are so confusing that even on the forums they argue which ones do which.
I got caught in torrential rain on it, put it in "R" mode which I thought was rain mode and cained it all the way home (about 25 miles). Told my mate about it who also has one and he said that's race mode... placebo?
I turn most of it all off anyway, ride with the APRC off, anti wheelie off, only one I really run on lower settings is traction control.
Monkeypony
PostPosted: 15:14 - 13 Dec 2017    Post subject: Reply with quote
R mode on the older (pre 2014 I think, maybe wrong on that) RSV4s was "rain" Which did give you a reduced power map.
Then, just to keep things fun, they changed R mode to "race" which certainly doesn't reduce the power Laughing
The last post was made 8 years, 265 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.65 - MySQL Queries: 13 - Page Size: 132.84 Kb
