sidelight putting out 4v-5v
Hahadumball
PostPosted: 22:15 - 25 Dec 2017    Post subject: sidelight putting out 4v-5v Reply with quote
vtr sidelight stopped working ages ago, finaly got round to looking and its putting out 4-5v... using a battery, a 12v led bulb lights fine at 6v and dim as hell at 4v but in the sidelight housing it doesnt light up...
wiring is all fine as far as i can tell, i use the + connection for my heated grips which i fitted last week and theyre all good, nothing seems to have rubbed away at the wiring
im guessing it probably is a shit wire somewhere, anyone else had the same issue and solved it?
Fin: no matter how much I look at It I can't understand what was going through my head, all I remember is going about 80 and redlining it to stop it seizing.
360 Deg... Five 1/4 turns. :- Teflon-Mike 18 Jan 2015
Islander
PostPosted: 16:00 - 26 Dec 2017    Post subject: Reply with quote
Easy to tell if it's a bad earth. Connect your multimeter black lead directly to the battery, and check the voltage at the bulb. If it's still low then you have a dodgy joint somewhere, it it's normal then start checking your earths.
NutsyUk
PostPosted: 18:37 - 27 Dec 2017    Post subject: Reply with quote
sure its not just the heated grips taking up all the juice?
Yamaha FZ8/Fazer800 (split headlight one) 2014, gingerly getting used to the massive increase in HP and not killing myself in the process! That was easy to get used to.
Kawasaki ER6F 2007 650 Gonna sell as a project bike!
Lexmoto XTR S 125 Sold!
Hahadumball
PostPosted: 21:43 - 30 Dec 2017    Post subject: Reply with quote
stopped working long before i fitted the grips and the grips have an independent on/off switch
The last post was made 8 years, 145 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.04 Sec - Server Load: 0.96 - MySQL Queries: 13 - Page Size: 44.22 Kb
