A quick question - Hornet 600 (2001)
Inspire
PostPosted: 13:50 - 14 Mar 2005    Post subject: A quick question - Hornet 600 (2001) Reply with quote
I test rode one of these on Saturday. The engine note altered noticeably depending on whether the clutch was in or out. Could someone tell me whether this is normal or not?
Many thanks
Rob
PostPosted: 14:03 - 14 Mar 2005    Post subject: Reply with quote
Yes this is OK, if by noticeable you mean only just noticeable.
My SV used to do this, and G's R6 does too.
Its just the clutch plates rattling in the clutch basket. Wise man say, if engine have problems it make noise that you won't have to strain to hear - IE LOUD.
HTH Thumbs Up Smile
Inspire
PostPosted: 18:01 - 14 Mar 2005    Post subject: Reply with quote
The change in engine note was pronounced. I also had probs. getting it into 1st (which I put down to new boots!)
Eitherway, thanks for the advice.
Rob
Jon
Anyone for donuts?
PostPosted: 18:16 - 14 Mar 2005    Post subject: Reply with quote
Mine makes that noise... had it checked out by a mechanic who told me it's fine and quite common.
jay12329
Dr. Evil
PostPosted: 19:47 - 14 Mar 2005    Post subject: Reply with quote
The clutch rattles a lot on my hornet too. as for the gear chage i've found if i blit the throttle before moving from N to 1st it goes a little easer but i still need to be quite forcefull compared to the other gear changes, its a typical honda gearbox.
If you ahve any quiestions try teh nest,
WWW.hondahornet.co.uk
HTH
J
mchaggis
PostPosted: 20:02 - 14 Mar 2005    Post subject: Reply with quote
One thing I'll imagine you'll find that even with the clutch in (in gear), there will still be drive being transmitted through it; there is still pressure on the clutch plates. If it's on the centre stand, put it in 1st gear, pull the clutch in and you will see that the wheel will still rotate.
In neutral, the clutch isn't connected to the output shaft through the gearbox, (in or out) so the engine has less resistance to motion and will rev more quickly.
In gear, with the clutch out, the engine is working to move the bike so has a lot of resistance through the drivetrain :revs more slowly. With the clutch in, almost all of that resistance disappears so the engine will speed up.
I must not be a troll...
Mmmm, Guinness
Key67
PostPosted: 20:06 - 14 Mar 2005    Post subject: Reply with quote
Inspire wrote:
I also had probs. getting it into 1st .......
My Hornet (1998) does the same. I found that it was down to me Embarassed . I was new to riding and found myself constantly covering the lever with my foot. After a while, my foot used to rest on the lever and throw it out of synch somehow Confused . Much better when I started putting the ball of my foot on the footpeg!
Sometimes, it can be awkward to drop into first from neutral. I just let the clutch out slightly and it drops in fine.
Key
'98 Hornet 600 - Tahitian Blue - 'tis very nice!!!
Please visit my lads music site - Thanks! www.afhmusic.co.uk
JonB
Afraid of Mileage
PostPosted: 20:09 - 14 Mar 2005    Post subject: Reply with quote
I dunno if this the aforementioned question but whenever my Dad puts his Hornet back into Neutral from first it makes a ghastly rumbling noise. Confused
jay12329
Dr. Evil
PostPosted: 20:12 - 14 Mar 2005    Post subject: Reply with quote
Yeah thats the clutch plates jon. Nothing to worry about.
J
Inspire
PostPosted: 13:25 - 15 Mar 2005    Post subject: Reply with quote
Thanks
The last post was made 21 years, 205 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 2.01 - MySQL Queries: 13 - Page Size: 65.22 Kb
