Mk1 bandit 600 power loss
Ziggy81scott
PostPosted: 02:25 - 06 Jan 2018    Post subject: Mk1 bandit 600 power loss Reply with quote
Been having problems with power loss when pulling away.
As soon as the bike starts rolling and the load comes on the engine the revs die and I need to dip the clutch and pull away with more revs on.
This seems to happen all the time and is even worse while with the choke on.
The only way to pull away without any problem is to do it as if I’m on the start grid at the TT ie. revving a lot like a 2 stroke.
Any ideas?
Thanks Very Happy
RhynoCZ
PostPosted: 08:38 - 06 Jan 2018    Post subject: Reply with quote
Water in the fuel?
jaffa90
PostPosted: 11:23 - 06 Jan 2018    Post subject: Reply with quote
I would check what`s inside them float bowls.
Also could be air going in inbetween the carbs and engine.
redeem ouzzer
PostPosted: 13:31 - 06 Jan 2018    Post subject: Reply with quote
Crank seals.
Be a REAL MAN!
mudcow007
PostPosted: 20:26 - 06 Jan 2018    Post subject: Reply with quote
How long ago were the carbs stripped/ cleaned?
temeluchus
PostPosted: 20:52 - 06 Jan 2018    Post subject: Reply with quote
drain the float bowls, see how it runs after. Don't forget to set the fuel tap to PRIME for a couple of seconds to refill the float bowls after you have emptied them.
The last post was made 8 years, 275 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.39 - MySQL Queries: 13 - Page Size: 46.71 Kb
