| GN |
 GN L Plate Warrior
| Bozzy. |
 Bozzy. Scooby Slapper
| Islander |
 Islander World Chat Champion
 Posted: 21:23 - 06 Jan 2018 Post subject: |
If it's new then it's the dealer's problem. Get it sorted under warranty.  |
| kgm |
 kgm World Chat Champion
| NJD |
 NJD World Chat Champion
 Posted: 22:29 - 06 Jan 2018 Post subject: Re: ENGINE Management WARNING LIGHT |
| GN wrote: | Hi guys,
I got the delivery of Lexmoto Aspire 125 this morning. Everything was working fine this morning when it was brought. I tried to start it in the evening it won't start and there is Engine Management Warning Light on the dash. Anyone knows why? |
Given the cold temperatures of outside at the moment I'd expect it to be hard to start.
Given that it's new I'd expect it's probably not set up optimally and rather whatever they shipped it out of the factory with: you're probably going to need to bump up the idol speed (a screw on the carb) to increase the idol (where the needle sits on the rev counter when no throttle is applied) to ensure it runs smoothly -- do this, however, once you've been out on the road for about ten minutes and then engines warm otherwise you're giving yourself false readings. To adjust it you simply twist the screw, very slightly, in either direction.. after a rev of throttle you should be able to tell if its increasing or decreasing.
You -- that's you not the bike -- are going to need to get used to how it starts. Full choke, button and a bit of throttle until you can react to the noise of it starting and then leave it on full choke until it sounds like it wont die on you when you lessen the choke gradually. You'll learn, the more you ride, how soon or slow it starts in certain weathers.
I'd take a guess that the warning light should go out when it starts. Have you read your owners booklet for clarification?
Be careful on how many times and for how long you attempt to start the bike for: too many times and you'll flood the engine and pressing the starter for too long will eventually kill the battery. Short sprints of about ten seconds, at most, is what I'd consider overkill.
If you don't have any luck getting it going tomorrow then phone the shop on Monday -- that is if they're closed on Sunday -- and ask them to have a look at it. ____________________ The do it all, T̶h̶e̶ ̶b̶r̶o̶k̶e̶n̶ ̶o̶n̶e̶,̶ ̶T̶h̶e̶ ̶b̶i̶g̶ ̶l̶u̶m̶p̶,̶ ̶C̶h̶o̶n̶g̶ ̶N̶o̶o̶d̶l̶e̶ |
| Bozzy. |
| NJD |
| P.addy |
 P.addy Red Rocket
| Rogerborg |
 Rogerborg nimbA
 Posted: 03:00 - 07 Jan 2018 Post subject: |
£5 says it's got no fuel in it. ____________________ Biking is 1/20th as dangerous as horse riding.
| Polarbear |
 Polarbear Super Spammer
| Wafer_Thin_Ham |
 Wafer_Thin_Ham Super Spammer
 Posted: 09:36 - 07 Jan 2018 Post subject: |
Is it in gear? Kill switch?
Will the OP ever return?? ____________________ My Flickr |
| grr666 |
 grr666 Super Spammer
 Posted: 09:52 - 07 Jan 2018 Post subject: |
ABS light? (I'm guessing) Mine comes on upon startup and goes out at 6mph. ____________________ Currently enjoying products from Ford, Mazda and Yamaha
| J4mes |
 J4mes World Chat Champion
| ADSrox0r |
 ADSrox0r World Chat Champion
| bamt |
 bamt World Chat Champion
| Rogerborg |
 Rogerborg nimbA
 Posted: 12:12 - 07 Jan 2018 Post subject: |
If OP never answers, I'm going to assume "OTR costs cover PDI, first registration, number plate, and a full tank of fuel" was the correct lie.  ____________________ Biking is 1/20th as dangerous as horse riding.
| ADSrox0r |
| Johnnythefox |
 Johnnythefox Traffic Copper
| Rogerborg |
 Rogerborg nimbA
| Wafer_Thin_Ham |
| MCN |
 MCN Super Spammer
 Posted: 17:02 - 07 Jan 2018 Post subject: |
Why is this thread not ded yet?
The OP disnae gie a fcuk anymore so why should we?
 ____________________ Disclaimer: The comments above may be predicted text and not necessarily the opinion of MCN. |
| Wafer_Thin_Ham |
| Pjay |
 Pjay World Chat Champion
| GrumpyGuts |
 GrumpyGuts World Chat Champion
| andyscooter |
 andyscooter World Chat Champion
The last post was made 8 years, 285 days ago. Instead of replying here, would creating a new thread be more useful? |
