Let's talk about bent downpipes...
Snop Doog
PostPosted: 02:22 - 10 Jan 2018    Post subject: Let's talk about bent downpipes... Reply with quote
https://i.imgur.com/PSclLCW.jpg
A car pulled out on me a couple of months ago and my bike hit the curb HARD so I guess that's how it happened, only noticed it when doing some maintenance on my bike on the weekend. No cracks and I've been riding it around how it is without any problems... It's resting on the oil cooler though so perhaps that could be an issue when the weather gets warmer? Replace sooner, later or not at all? (Bike is due to be turned into a track bike next year)
TheMadRatter
PostPosted: 03:30 - 10 Jan 2018    Post subject: Re: Let's talk about bent downpipes... Reply with quote
Up to you and your financial situation really. Keep an eye on the oil temperature if you leave it.
Check this out if you wanna know how it may affect performance
Motor Trend Channel wrote:
You might find more help posting this in the Workshop section of the forum though...
TheMadRatter | Lurch .:. Afghan Heroes ✓, RTWR ?,Rainpal ?
CM125 X|GZ125 X|Cagiva Elefant X|GL1200 ✓|Aprilia Classic X|GSX400T X|Kymco Hipster ✓|Kymco Zing X|XV535 X|VL750P X|FZ6 ✓|FJ1100 X|Desperado ✓|Countless Chinese imports ✓|Rialto Trike ✓|Countless forgotten rides
DrDonnyBrago
PostPosted: 10:22 - 10 Jan 2018    Post subject: Reply with quote
I'd replace it and hope to jeebus that the studs aren't seized.
Are you also missing a clamp between your downpipe and the mid/collector pipe?
PostPosted: 10:31 - 10 Jan 2018    Post subject: Reply with quote
I'd be slightly concerned about extra force on the oil cooler mounting points. Laughing
Keep an eye on eBay for a suitable set of downpipes as they don't go for huge amounts of money.
What other damage haven't you noticed? Razz
Generally you'll get more bike for your money if you buy a track bike rather than converting your road bike. Plus you can use the opportunity to get yourself something faster than your v twin commuter. Wink
Islander
PostPosted: 10:33 - 10 Jan 2018    Post subject: Reply with quote
Both of these^^
Also, have you inspected for other damage?
PostPosted: 10:35 - 10 Jan 2018    Post subject: Reply with quote
Theres pretty much no doubt that will affect performance. Whether that bothers you is a different matter.
Personally, I'd replace it, sell the bike and buy a prepped Minitwin. Or if I'm not racing, I'd buy a 10 year old 600 and do trackdays on that.
Oh wait, that's exactly what I did! Smile
If you're racing in Minitwins then you'll want a professionally prepared bike. If you're doing trackdays then you'll want a bit more go than an SV650 ideally.
Buuuut, this is BCF and it's just advice. As the song says 'you're free to do what you want to do'.
fatjames
PostPosted: 13:22 - 10 Jan 2018    Post subject: Reply with quote
Stick a potato in the end can, turn the engine on and the dent will just pop back out under the pressure.
PostPosted: 13:24 - 10 Jan 2018    Post subject: Reply with quote
fatjames wrote:
Stick a potato in...
https://i.imgur.com/qHRLU5P.gif
colink98
PostPosted: 13:49 - 10 Jan 2018    Post subject: Reply with quote
is there supposed to be an empty hole in the engines case ?
Ride it like you stole it.
Snop Doog
PostPosted: 14:21 - 10 Jan 2018    Post subject: Re: Let's talk about bent downpipes... Reply with quote
Check this out if you're wanna know how it may affect performance
Haven't been here for a while, completely forgot about that section. Ah well. £35 for a new set so I may as well, that's a hefty bend so I can only assume performance will have been somewhat affected (I haven't noticed it though)
Yep
That's the thing, bought this last February for £1900 with 17k miles, almost on 25k now and it's been down the road a few times. The mounting point on the frame that the nose cone fairing bracket bolts on to is bent so the clocks/mirrors will never be straight. The OEM nose fairing is cracked and broken in many places and the rest of the fairings are Chinese. The front wheel's got a few grinds on it. I won't be fully converting it, I'll just be taking it off the road so that my road bike won't be at risk of getting binned on the track. At this point I doubt I'd get a lot for it if I sold it??
Heh..
Yep, it's there on every SV engine I've seen.
PostPosted: 14:50 - 10 Jan 2018    Post subject: Reply with quote
Damaged fairings and bent fairing brackets are just cosmetic, a bent downpipe putting force on the oil cooler has the potential to go very badly wrong. Laughing
I seriously doubt that anything like that will happen but apart from whatever the effect has been on the power, the oil cooler is what I'd be concerned about.
If you take it off the road so that your road bike won't be at risk of getting binned on track, your road bike will still be at risk of getting binned on the roads and it sounds like your bike is already getting damaged on the roads. Razz
You say you won't be fully converting it but you'll still have to spend money on it. Exactly how much you'd have to spend is something to worry about next year and at that point, what MarJay says about buying a 10 year old 600 and using that for doing trackdays will still be sound advice.
Replace the downpipes and then put possible trackbike plans aside for the moment. Mr. Green
Tdibs
PostPosted: 15:14 - 10 Jan 2018    Post subject: Reply with quote
They are cheap on ebay (the header) would be taking a look the studs too if the crash has put a bunch of stress on them. Sacrifice a goat to the stud god for good measure.
wristjob
PostPosted: 18:48 - 10 Jan 2018    Post subject: Reply with quote
kerb
Snop Doog
PostPosted: 19:35 - 10 Jan 2018    Post subject: Reply with quote
Hmm the thing is it's not the fairing bracket but the actual mounting point on the frame (it's been pushed into the frame, try to imagine the top of a bottle being pushed in on itself). Doesn't that count as frame damage or does the future buyer not have to know that Twisted Evil
But I appreciate all of the advice, I did contact someone before posting this thread and it'll cost me £35 posted for the downpipes. I may as well order new gaskets and new studs in case things go wrong.
TheSmiler
PostPosted: 02:19 - 11 Jan 2018    Post subject: Reply with quote
Aww you call that bent Laughing
https://i.imgur.com/FrpG4Bj.jpg
PostPosted: 04:07 - 11 Jan 2018    Post subject: Reply with quote
I think you already know the answers to both of those questions. Razz
Vracktal
PostPosted: 00:20 - 12 Jan 2018    Post subject: Reply with quote
I wouldn't worry about a dent like that too much, headers can get pretty beat up without hurting performance badly.
EDIT: Didn't realise Ratter linked to the MT header bash video...
2007 BMW R1200R: On road
2009 BMW G650X Challenge: On road
1975 Norton Commando 850: Off road, awaiting recommissioning
The last post was made 8 years, 255 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.17 - MySQL Queries: 13 - Page Size: 100.87 Kb
