Fzr400 knocking engine
Chuckyfzr
PostPosted: 01:37 - 14 Jan 2018    Post subject: Fzr400 knocking engine Reply with quote
Can anyone tell what mite be up with this 400 engine ? Sorry it's just sound but you can hear a slight knocking sound . It's continuous on neutral but it goes when you rev . Then when you let go of accelerator it seems louder
redeem ouzzer
PostPosted: 05:06 - 14 Jan 2018    Post subject: Reply with quote
Big end.
Be a REAL MAN!
Chuckyfzr
PostPosted: 08:26 - 14 Jan 2018    Post subject: Reply with quote
Does it sound like cam chain tensioner or is it only running on 3 cylinders ? Major problem ?
RhynoCZ
PostPosted: 13:09 - 14 Jan 2018    Post subject: Reply with quote
Start the engine, warm it properly up, then squirt some water onto the headers, one by one. The one that doesn't boil the water right away is the dead cylinder. Spitting onto the headers works as well, don't burn your face.
That is the simplest test. From that audio clip of yours I can't tell if it runs on 3 cylinders. There could be some leaks in the exhaust system making it sound like it.
I would say it runs on 3 cylinders, but I'm not 100% sure. I've heard engines sound like that before and they were perfectly fine.
MCN
PostPosted: 15:59 - 14 Jan 2018    Post subject: Reply with quote
Buy a new oil filter.
Whip the old one off.
Carefully cut the top off it. Carefully so you do not cut your self or get any cutting int eh filter.
Pull the guts out the filter.
Separate the pleats and spread the paper out.
Look for jewellery in the paper/cloth.
Jewellery is bright shiny expensive metal.
If you have metal particles in the filter the engine is gubbed and needs pulled apart.
It's a sure fire way to tell if you have bearing damage. Big ends, mains, small ends do not make a noise without shedding lots of metal. The filter pick it up.
Chuckyfzr
PostPosted: 16:35 - 14 Jan 2018    Post subject: Reply with quote
Thanks , i have not yet brought the bike . I'm planning on buying it today , it's going very cheap .
ThatDippyTwat
PostPosted: 19:05 - 14 Jan 2018    Post subject: Reply with quote
Budget the time and money involved in swapping the motor out - Then see if it's still cheap.
PostPosted: 19:11 - 14 Jan 2018    Post subject: Reply with quote
Sounds like someone has already decided that the cost and hassle of fixing a knackered engine outweighs the cost of replacing the whole bike. You might want to consider that.
Chris45
PostPosted: 23:10 - 14 Jan 2018    Post subject: Reply with quote
Ah, the enthusiasm of youth and naivety Very Happy All bets are off gentleman, it's a heavy loss whatever the outcome.
Honda CG125>Suzuki GT185>Honda CB 250N>Suzuki GSX400>Honda CX500B>Kawasaki GPZ305> Kawasaki GPZ550>Kawasaki GPZ500S+BMW 650GS
PostPosted: 09:51 - 15 Jan 2018    Post subject: Reply with quote
Then I'd suggest leaving.
bladerunner
PostPosted: 02:17 - 18 Jan 2018    Post subject: Reply with quote
bang in an FZR600 motor and go racing Laughing Laughing
The last post was made 8 years, 274 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.95 - MySQL Queries: 13 - Page Size: 67.35 Kb
