Going up 2 on the main jet as a last resort Z500b
Dabura
PostPosted: 00:57 - 15 Jan 2018    Post subject: Going up 2 on the main jet as a last resort Z500b Reply with quote
The z5 hasnt been running right so stripped the carbs(tk22s) down for a nice clean. Went to put them back together and snapped the main jet Brick Wall
After 2 hours searching i can find a replacement #90 on its own and all the replacement kits have a #92 main jet in them(for the kz550) it doesnt help that i dont have a proper part number, its 92063-xxxx
So would going up and putting #92 mains in all four carbs be a bad idea? Its all standard except for a aftermarket pipe which is no way performancey.
Any help appreciated
Past: Peugeot Speed Fight 50 - couldn't handle winter.Gilera Sc125 - Crashed and burned(literally).Aprilia Rs125 - Fell apart and Sold. Mk1Bandit Stolen
Present: Kawasaki Z500-B
PostPosted: 01:29 - 15 Jan 2018    Post subject: Reply with quote
Could you get smaller ones and drill them out (you can buy jet drills)?
Although going up 2 probably isn't the end of the world on a bike of that era.
That said, even wemoto are listing #92 jets for your bike. Sure it's supposed to have 90s in it?
The best bit will be when you find it was running badly because of a poor coil earth or similar.
Dabura
PostPosted: 01:43 - 15 Jan 2018    Post subject: Reply with quote
Coils were brand new when the bike was rebuilt last year as were the plugs leads and caps.
buying smaller wouldn't be a bad idea however teikai jets seem few and far between
i looked at the wemoto listing amongst others and they all have 92 - 94 mains which is for the 550 and 550-d flicking through KZ riders boards 90 is the right size. the 550 was the main model so there is an abundance of spaces but the 500 was only made for 3 years. even seen the 92s marked as replacements for the z400 which i cant believe.
how difficult would drilling out a smaller jet be? would it be worth fitting 92 and sticking a free flowing filter in and/or modifying the pipe or would i need bigger pilots,needles and even more cocking around.
PostPosted: 10:34 - 15 Jan 2018    Post subject: Reply with quote
I'd expect #90 to #92 to be within the margin of manufacturing error, fuel quality[*], altitude, air temperature, humidity and density.
Carbs aren't an exact science, and I'd rather be running a touch rich than too lean.
[*] Designed for (e.g.) leaded 2 star, running on some ethanol secret-sauce.
PostPosted: 21:14 - 15 Jan 2018    Post subject: Reply with quote
*Initiates badly dubbed lip-synch*
Of all the styles, my google-fu is the most powerful.
https://www.motorradbay.de/kym01bxxx-c-207_312_315-6.html
Dabura
PostPosted: 23:43 - 15 Jan 2018    Post subject: Reply with quote
https://i.imgflip.com/182q34.jpg
Thank you very much Mr stinkwheel. Your Google-fu is indeed the most powerful.
The last post was made 8 years, 278 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.94 - MySQL Queries: 13 - Page Size: 51.54 Kb
