rattle / Knocking noise at low revs
colink98
PostPosted: 15:35 - 19 Jan 2018    Post subject: rattle / Knocking noise at low revs Reply with quote
i'm going to give the bike a good look at this weekend.
there is a bit of noise from the front sprocket area when pull away in first and also if i'm off the gas in a higher gear and then get back on the gas.
it only happens at low revs (1-3k) and isnt apparent at higher revs.
I regularly oil the chain but i have not adjusted the chain slack for a while.
i will pop the chain off and check for any play on the front/rear sprockets and also have a look at the chain.
anything else to keep an eye out for ?
the bike is a 2004 CBF600
Cheers.
C.
Ride it like you stole it.
fatjames
PostPosted: 17:10 - 19 Jan 2018    Post subject: Reply with quote
How slack is the chain?
colink98
PostPosted: 19:23 - 19 Jan 2018    Post subject: Reply with quote
that is something I'm going to check tomorrow.
However when getting ready to leave work and i noticed this
https://i.imgur.com/dUbOwUA.jpg
the center stand is actually making contact with the chain.
when i move it off the side stand there is a gap of half an inch between the center stand and the chain.
while the chain may be a little slack i cant help but suspect there sound be more than half an inch clearance.
i will correctly tension the chain tomorrow and also see if there should be a mechanical stop on the center stand.
Chris45
PostPosted: 21:26 - 19 Jan 2018    Post subject: Reply with quote
Please tell me that is not green mould on the links Sad
Honda CG125>Suzuki GT185>Honda CB 250N>Suzuki GSX400>Honda CX500B>Kawasaki GPZ305> Kawasaki GPZ550>Kawasaki GPZ500S+BMW 650GS
Pigeon
PostPosted: 22:57 - 19 Jan 2018    Post subject: Reply with quote
Guessing the chain may be skipping/flexing due to stiff links possibly (with a loose / tight spot).
And hitting the centre stand.
Doovie, thinking of you buddy.
colink98
PostPosted: 08:48 - 20 Jan 2018    Post subject: Reply with quote
i use organic chain oil.
Very Happy
colink98
PostPosted: 13:18 - 21 Jan 2018    Post subject: Reply with quote
With the bike on the side stand the slack was 40mm.
the manual says 30-40mm so i have adjusted it closer to 30mm.
the rubber stopper on the center stand was all but fallen off.
i have replaced it with a bolt and a couple of nuts so it can be adjusted.
Let see how it is on the way to work tomorrow.
Courier265
PostPosted: 15:30 - 21 Jan 2018    Post subject: Reply with quote
Losing the stopper makes a lot of difference because the center stand is too high unless you are sitting on the bike.
I have a CBF 500 and I lost my stopper, don't bother with an original part, make your own, I found a bung, made a hole in it and bolted it on.
However even with a locknut it managed to loosen so if you make your own like I did, check on it now and again.
I would of said something earlier but I wasn't aware the CBF600 had a stopper after checking the microfiche
colink98
PostPosted: 09:49 - 23 Jan 2018    Post subject: Reply with quote
i make you right....
replaced the failed stopper with a bolt and two nylock nuts.
i will check it at the weekend to make sure its secure.
its a lot less noisy now...so job was jobbed.
The last post was made 8 years, 251 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1 - MySQL Queries: 13 - Page Size: 60.52 Kb
