Earth wire electric bods need your advice.
TheSmiler
PostPosted: 09:56 - 22 Jan 2018    Post subject: Earth wire electric bods need your advice. Reply with quote
After a problem on the bike I'm needing a new earth wire. Now I'm wondering what is the best type of wire to use and ampage. Never liked or got along with electrics hence the question.
c_dug
PostPosted: 10:27 - 22 Jan 2018    Post subject: Reply with quote
There isn't really an earth wire as such on a bike, what exactly do you need?
PostPosted: 10:40 - 22 Jan 2018    Post subject: Reply with quote
The thicker, the better.
If the starter solenoid connects directly to the battery negative with a big fat wire, the frame earth needs to carry up to 30A (usualy size of the main fuse). I'd go with at least 4mm^2 multicore cable.
If the only connection to the battery negative is the frame earth, it needs to carry starter motor current. So it needs to be about as thick as a jump lead. You'd want to buy a pre-made earth strap because conventional crimps etc wont be up to the task. So in the region of 15 to 20mm^2. Especially if it's for your brick engine BMW because they'll draw some serious cranking amps.
It is not wrong to use a thick earth strap in either case. Loads of them on ebay, all different sizes. This is just a random example: https://www.ebay.co.uk/itm/9-Classic-Car-Earth-Strap-Battery-Lead-Cable-Flexible-Tinned-Copper-Braid/121930637020?epid=651851216&hash=item1c63a1dedc:g:EQwAAOSwv-NWaFQw
TheSmiler
PostPosted: 11:40 - 22 Jan 2018    Post subject: Reply with quote
The only connection to the battery is the negative from the frame its about 850mm in length worth of cable. I know now for a fact that if a certain problem happens that you can disconnect the earth cable save it going fully on fire.
You can see how lucky I was on the old standard earth cable. I'll have a look on ebay see if i can find an earth strap that meets my requirements.
The last post was made 8 years, 258 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.76 - MySQL Queries: 13 - Page Size: 41.25 Kb
