What oil BMW Boxer ?
JackDaniels
PostPosted: 13:49 - 25 Jan 2018    Post subject: What oil BMW Boxer ? Reply with quote
Hi Guys,
I have a 2003 BMW R1150GS and I need to top up the oil but im yet to find a definite answer as to what oil I need, looks to be either 15w50 or 20w50.
the best I can find locally is a semi synth 20w50 from Halfords.
this seems to be what James Sherlock stock for the 1150 boxer engine.
Thanks
THEORY TEST - PASSED! - 02-08-11 CBT Passed - 09-08-10 MOD 1 - 09-08-2011 - MOD 2 - 28-09-2011
2006 Yamaha JOGRR>2010 Yamaha Ybr>1995 Honda CB400 Superfour >2005 Honda hornet>1999 Suzuki Bandit 1200 > 2002 BMW R1150GS > 2013 Tiger Sport 1050 > 2007 GSXR 1000 > 2005 GS500E
PostPosted: 13:53 - 25 Jan 2018    Post subject: Reply with quote
Yep that semi 20w50 is fine.
oh you want that qualified....BMW say use a semi 20w50.
Last edited by Howling TerrorOutOfOffice on 13:54 - 25 Jan 2018; edited 1 time in total
kgm
Does the owners manual not tell you?
kgm
PostPosted: 14:11 - 25 Jan 2018    Post subject: Reply with quote
Page 3/75. Either 20w50 or 15w50 look fine.
https://www.dropbox.com/s/fcoc1drndi1bwim/BMW%20R1150GS%20Maintenance%20Instructions.pdf?dl=0
PostPosted: 14:25 - 25 Jan 2018    Post subject: Reply with quote
BMW are one of the more sensible manufacturers in this respect. I suspect it's down to the TUV insisting owners do not deviate from manufacturers recommendations. So they make very broad recommendations. They generally do the same with tyres, because it is not permitted to deviate from the OEM recommendation, you get a long list in the handbook.
Here, BMW oil chart.:
https://bmwmotorcycletech.info/BMW-Oil-Recommendations.jpeg
So take your pick. You could make a good argument for 20w-50 in the summer and 10w-40 in the Winter.
If it was me, I'd bung 15w-50 in. My Enfield takes 20w-50 and it's increasingly hard to come by and often lower quality. That said, it's effectively a WW2 tractor engine you're putting it in so they're not terribly fussy.
EDIT: Beaten to it, the chart in the above dropbox is more up to date than the one I found.
JackDaniels
PostPosted: 16:00 - 25 Jan 2018    Post subject: Reply with quote
Thanks
Il pickup the 20w50 semi synth tonight, I'm planning on doing an oil and filter change soon so may consider 15w50 then, I don't have an owners manual and there is so many conflicting opinions but after seeing this chart it makes sense.
Thank you
PostPosted: 16:03 - 25 Jan 2018    Post subject: Reply with quote
My pleasure.
[edit] Mr. Green
Last edited by Howling TerrorOutOfOffice on 17:52 - 25 Jan 2018; edited 1 time in total
kgm
PostPosted: 17:49 - 25 Jan 2018    Post subject: Reply with quote
The link I posted is to the owners manual if you need a copy.
The last post was made 8 years, 248 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.65 - MySQL Queries: 13 - Page Size: 58.19 Kb
