| Tigerlea |
 Tigerlea Nitrous Nuisance
 Posted: 21:33 - 25 Jan 2018 Post subject: Battery issues query.. |
So I reinstalled the Duc battery after recharging it using a mains power charger thing. Started her up before putting the tank panels back on and all was good. Let her run for about 5 minutes then shut her off so I could finish cleaning and putting everything back as normal.
https://farm5.staticflickr.com/4658/38998124195_6fe61a3d9b.jpg
Started her up again to go for a ride but a neighbour began talking to me, so I turned it off. Checked the lights with the engine off and then when I tried to restart realised there was no charge whatsoever.. No panel on (like earlier in the week), nothing. So I now have a completely flat battery. Checked over everything just to make sure the kill switch hadn't been hit, but all seems fine.
This is my first experience charging the battery up, as it was never an issue before.
Did I short it somehow? Or is it dead because I ran it twice without going for a ride?
I'll be taking her apart again and putting the battery on charge.. again.. but I want to know why this happened so there's no repeat..
Also.....
Discovered this while I was reinstalling the battery:
https://farm5.staticflickr.com/4652/25025617307_e8b7f6941d.jpg
Think it may be an external charging source?
What would I plug into this?! Didn't even realise it was there as everything was under the tank. Have now left it out so that it could be used.
PS ~ TV table makes for a great tank prop  |
| raesewell |
 raesewell Traffic Copper
| Kawasaki Jimbo |
 Kawasaki Jimbo World Chat Champion
| Howling TerrorOutOfOffice |
 Howling TerrorOutOfOffice Super Spammer
 Posted: 22:08 - 25 Jan 2018 Post subject: |
@raesewellWhich does what..EXPLAIN MAN.
OP
Without using a multi meter you won't know much.
No you haven't shorted it otherwise you'd be watching a nice sparkly display of sparks. ____________________ Diabolical homemade music Bandcamp and Soundcloud
The Harry Turner Project |
| Islander |
 Islander World Chat Champion
| raesewell |
 Posted: 12:05 - 26 Jan 2018 Post subject: |
| Howling Terror wrote: | @raesewellWhich does what..EXPLAIN MAN.
OP
No you haven't shorted it otherwise you'd be watching a nice sparkly display of sparks. |
It's a two pin connector that can be used for a variety of connections.
It is also an early Optimate charging fly lead connector. Optimate now use SAE connectors. ____________________ Yamaha FJR 1300 Normanton West Yorkshire |
| Copycat73 |
 Copycat73 World Chat Champion
| colink98 |
 colink98 Could Be A Chat Bot
| Polarbear |
 Polarbear Super Spammer
| Robby |
 Robby Dirty Old Man
| Nobby the Bastard |
| MCN |
 MCN Super Spammer
 Posted: 08:55 - 27 Jan 2018 Post subject: |
Fucked battery. Google lead acid battery
https://en.m.wikipedia.org/wiki/Lead–acid_battery
You can get a rough estimate of condition via a hydrometer sg test or a voltage test bit the only real test is by a discharge test. Places who sell batteries can sometimes test and most bike/car/truck workshops 'should' possess a High rate Discharge tester. (Or they are not really serious )
Batteries can fail over time due to aging or through neglect. ____________________ Disclaimer: The comments above may be predicted text and not necessarily the opinion of MCN. |
| P.addy |
 P.addy Red Rocket
 Posted: 09:47 - 27 Jan 2018 Post subject: |
Ollie just had exactly the same. Battery swap fixed it. Weird you get absolutely zero too.
Put ign on and wiggle both cables gently. Robby could be right with a dodgy cable. otherwise, battery. |
| Tigerlea |
| Nobby the Bastard |
| Polarbear |
| MCN |
 MCN Super Spammer
 Posted: 16:52 - 31 Jan 2018 Post subject: |
I have had hundreds of volt meters.
The only warning with cheap shite is that the leads can melt and cause the next apocalypses or worser.
And the lead plugs may not be as secure as you would like them to be which may indicate 0 volts on a live circuit.
Just a word of caution. I use a shite one at work but I am aware of its peculiarities now.
I have a nice Durite one for real work on bike, car, hoose. ____________________ Disclaimer: The comments above may be predicted text and not necessarily the opinion of MCN. |
| Fizzer Thou |
 Posted: 11:19 - 01 Feb 2018 Post subject: |
I bought my £11 digital multimeter from B&Q and it is more than adequate for everything.The leads work okay but I have supplemented those with some longer ones that I made up  ____________________ Just talk bikes.What else is there?
Always have a 'Plan B' |
| trevor saxe-coburg-gotha |
 trevor saxe-coburg-gotha World Chat Champion
| Polarbear |
 Posted: 20:42 - 01 Feb 2018 Post subject: |
Flukes are really the industry standard. I have a couple from when I was at sea and they are lovely bits of kit but obviously for a DIY person totally over the top. Mine had to be calibrated every year for my job and that cost way way more than a cheap meter though.
I would be happy if I picked up a working Fluke for £30. ____________________ Triumph Trophy Launch Edition |
| Fizzer Thou |
The last post was made 8 years, 223 days ago. Instead of replying here, would creating a new thread be more useful? |
