| ChipUK |
 ChipUK L Plate Warrior
| Nobby the Bastard |
| ChipUK |
| stevo as b4 |
| ChipUK |
| cb1rocket |
 cb1rocket World Chat Champion
| P.addy |
 P.addy Red Rocket
 - Super Spammer
 Posted: 10:35 - 26 Jan 2018 Post subject: |
| ChipUK wrote: | Thanks for that. I did run it after the belt and roller change and everything was fine. It ran it to full speed. The problem has only surfaced since the idle was fixed |
Not only has someone already answered this for you, you've even answered your own question here.
"We played with the carb and now it..."
Have a guess, go on....
My personal opinion is that the carb will need dismantling and cleaned thoroughly. It doesn't sound like you're up to the task, so you'll need someone to do it for you.
The idle problem was probably a blocked pilot jet or some other dirty carb issue, which your mate worked around by dicking with carb settings. In working around and not fixing the problem, you've created another. ____________________ TZR250 2MA road, TZR250 1KT road, TZR250 2MA race, TDR250, YZF-750R Boost colours.
Jaguar S Type 3.0 V6 Sport R, VW Transporter T5 GP LWB Shuttle 140ps DSG. |
| craigT19 |
 craigT19 Jolly Green Giant
 Posted: 11:40 - 26 Jan 2018 Post subject: |
Hi,
The carbs on the 250 Maj were always abit of a pain in the arse.
Its a long shot but off the top of my head you will hit 45 on one of those at about half throttle and from memory i had a similar issue with a customers majesty which turned out to be a hole in the diaphragm stopping the carb from opening up fully . But that particular customer hadnt touched the carb them selves.
As said above the problem wasnt there before the chock change but is after so u have almost certainly upset the carb. I second the above as far as taking it off, strip it, clean it, back to factory settings and then try it.
Good luck  ____________________ Bikes owned :- 2001 nsr125, 1999 zx6r, 2006 yzf-r1, 2009 xmax 250, 2012 yzf-r1, 2015 MT-07
Current bike : - 2016 MT-10
BCF member pops. sadly missed 1945-2003 |
| bassmastergen... |
 bassmastergen... Nitrous Nuisance
| Nobby the Bastard |
| ChipUK |
| Nobby the Bastard |
 - Super Spammer
| bikenut |
 bikenut World Chat Champion
 Posted: 13:17 - 27 Jan 2018 Post subject: bike |
Hi,
Good luck Thumbs Up
I don't know this bike, but, if as above says, and the carb is the diaphragm cv type, then a punctured diaphragm would give the lack of performance indicated, just like the old days of Stromberg car carbs, remember them ??
So, chip, make it possible to see the carb intake and the piston therein.
Using your finger or similar with the engine off, gently push up the piston. There may some light resistance and some hissing, but did it go up all the way ?? and drop down all by its self ???
Yes is a good sign.
Next, start the engine and gently increase revs, did the piston rise, and rise further with more throttle ??
No, then a punctured diaphragm ( or air leak problem, but most likely a diaphragm problem. Was the diaphragm fitted correctly and able to rise and fall freely ? )
Hope its not summut daft like a rag under the saddle
Will try and post a diaphragm type cv carb for you so you know what a basic one looks like, and what's involved.
Get a manual, which always helps.
You know of cmsnl for the exploded views ? you do now ! :D :D :D ____________________ nuts about bikes
| bikenut |
The last post was made 8 years, 244 days ago. Instead of replying here, would creating a new thread be more useful? |
