New to me GS500 stumbling and dying
FollowingGhos...
PostPosted: 21:31 - 30 Jan 2018    Post subject: New to me GS500 stumbling and dying Reply with quote
Hi all,
Just got myself a GS500 cheaply with 7500 miles on it, so it's barely moved since 2002 when it was first registered
However, it's been sat for a few years, then serviced, then sat again and I think it's suffering for it.
I was going along the motorway when suddenly I started losing power and it was chugging and slowing down. I pulled onto the hard shoulder with the clutch in and it just died.
It started up after a few goes cranking, then started stumbling and died about a mile later
I've taken it out for a run after draining the carbs and it seems better. There wasn't much/any gunge that came out of the carbs. For obvious reasons, I didn't fancy taking it on the motorway again, especially in the dark, but it was happy in 6th at 50
Does anyone know what else I should check?
Both plugs look pretty much bang on normal (as per the picture guides etc), oil is reasonably fresh.
It is booked in for a full service on Friday, just to get it checked over as much as anything else, but I want to ride it in the meantime.
Kawasaki Jimbo
PostPosted: 21:40 - 30 Jan 2018    Post subject: Reply with quote
Sounds like carb icing. Try a bit of Silkolene Pro-FST in the tank.
FollowingGhos...
PostPosted: 21:49 - 30 Jan 2018    Post subject: Reply with quote
Would it happen after only a couple miles on the motorway?
It was fine until then and rode okay afterwards too. It didn't ice up when I took it out for a later run either
Kawasaki Jimbo
PostPosted: 22:10 - 30 Jan 2018    Post subject: Reply with quote
Yes to all that. I can't promise it's carb icing but it sounds classic. Given a few minutes to thaw it might not happen again, or it could return within a couple of miles. You'll only get it with a particular band on the temperature vs humidity chart. It can be colder or wetter and it won't happen, so it's hard to predict. I wasn't out today but I can well imagine that the conditions were right. I wouldn't spend a lot of money on workshop hours trying to solve a mechanical problem unless it does this a lot, which might suggest you have another problem.
PostPosted: 11:28 - 31 Jan 2018    Post subject: Reply with quote
Set the tank to PRI as well. Remember to turn it off when stopped. Basically check the fuel tap as its a common failure point.
Once that is fixed, chuck it up for sale and buy anything else.
PostPosted: 12:22 - 31 Jan 2018    Post subject: Reply with quote
I'd also go with fuel starvation under load, so fuel tap, sticky floats, tank breather.
What Paddy said, or strip and clean the carbs, then what Paddy said.
PostPosted: 13:42 - 31 Jan 2018    Post subject: Reply with quote
As Paddy said Fuel Tap to prime see if it still does it. The Fuel taps on them ALWAYS go wrong.
Chris45
PostPosted: 20:33 - 31 Jan 2018    Post subject: Reply with quote
Yup. Fuel tap clean and/or replace. Also check tank breather pipe.
Honda CG125>Suzuki GT185>Honda CB 250N>Suzuki GSX400>Honda CX500B>Kawasaki GPZ305> Kawasaki GPZ550>Kawasaki GPZ500S+BMW 650GS
The last post was made 8 years, 234 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.07 - MySQL Queries: 13 - Page Size: 61.1 Kb
